Question about Maytag Dependable Clean Top Load Washer, MAV3955EWW
Exessive noise when in spin cycle?
Our Maytag Mav 9501EWW washer is making a kind of whistling sound when it is in spin cycle. This just started a few days ago.
  • 11,896 Answers
Could be dirty bearings. As long as it is still spinning, it is nothing to worry about. If it suddenly stops one day, it is probably frozen bearings or the brushes in the motor.
Posted on Jun 23, 2009
Hi, I have a Maytag Alantis Washer (model: MAV
Does it not spin just in the final cycle or not at all during the wash cycle? Also, does the wash cycle agitate normal?
Regards,Richard
Nov 07, 2011 | Maytag Washing Machines
Maytag MAV-35 Roars during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 23, 2011 | Washing Machines
Wash machine model mav 7600, started making tremendous noise, first in spin cycle only and then in wash cycle also. After running a few loads with the noise the machine just stoped running....
This sounds like collapsed/broken drum bearings. Check for movement between inner and outer drum. Also rotating the drum by hand will be hard (or immpossible), and noisy. It could be the motor and belt, but most times it is bearings.
Aug 11, 2010 | Maytag Washing Machines
Maytag MAV 9600 grinding noise/no agitation. Tub
sounds like a transmisson problem expensive to fix
May 17, 2009 | Maytag MAV9600 Top Load Washer
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Maytag Mav-1 Slow Spin
hi thanks for the question with any washer if you use a hi sud zing detergent it really slows down the spin cycle check this just fill & drain 2or 3 times use some veniger try this thanks the appliance doc
Jul 17, 2008 | Maytag Atlantis MAV6451 Top Load Washer
CLOTHES STILL SOAKED AFTER SPIN CYCLE
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine, parts are not that expensive, 50-80for bearing kit, here is my site on how to do it http://maytagwasherrepair.googlepages.com/index.html
Apr 05, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Loud noise during spin cycle
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Dependable Clean Top Load Washer, MAV3955EWW Logo
375 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
