Question about Emerson Quiet Kool 12HT13 Air Conditioner
How may watts is the emerson quite Kool 700 need to run
We are purchasing a generator. want to get the right one.
SOURCE: Emerson Quiet Kool Drips Water into the house
depends on the unit. you will probably have to slide it out of its case and clean the outside part . there should be a hose that goes from the inside to the outside for the water to go out. this hose may be clogged, trapping the water inside. as i always say a picture of the unit always helps so i can identify it and tell you what to do to try and fix the problem. email the pics to eyg2181@yahoo.com
Posted on Aug 05, 2007
ACTECH
  • 80 Answers
SOURCE: Emerson Quiet Kool A/C Filter
YOU CAN GET THE FILTER MATERIAL FROM ANY HOME DEPOT OR LOWES AND CUT IT TO FIT YOURSELF. JUST BRING A SAMPLE OF THE MATERIAL WITH YOU AND GIVE IT TO THE SALES ASSOCIATE
Posted on Dec 07, 2007
ACTECH
  • 80 Answers
SOURCE: Need new filter for Emerson Quiet Kool
GO TO HOME DEPOT AND BUY A CUT TO FIT FOAM FILTER FROM THEM IT IS THE SAME MATERIAL AND COSTS ALOT LESS BRING YOUR OLD ONE WITH YOU SO THEY CAN HELP YOU FIND THE RIGHT ONE. IF YOU WANT AN OEM FILTER I NEED THE MAKE AND MODEL# TO HELP YOU
Posted on Jan 14, 2008
If you know where to find a filter for a Emerson Quiet Kool--Model # 18DD4H-EE
Serial # 21A 927552 Please let me know
beverleyed@yahoo.com
Thanks
Ed Beverley
Posted on Jul 07, 2008
tebot
  • 15 Answers
SOURCE: Emerson Quiet Kool 700 roof mount air conditioner
It should have a drain so that it runs down off the roof instead of into the motorhome. All a/c's have a drain somewhere and they all plug up occasionally. A/C techs always carry coat hangers.
Posted on Mar 30, 2009
Need manual for emerson quiet kool air conditoner model 12HT13?
I found this I hope it helps.
Performance BTU/H Cooling: EER: Voltage: Amps: Watts: Cooling Area (Sq. Ft.): Pints/Hour: Room Air Delivery (CFM): Plug Cap Amps: Plug Type: Dimensions Width: Depth: Height: Net Weight: Shipping Weight: http://www.appliancefactoryparts.com/airconditioners/emerson/12ht13.html#Manuals
Jun 02, 2014 | Emerson Quiet Kool 12HT13 Air Conditioner
I need a replacement condenser fan for model# EQK 1350 part #F12021 any idea where I can find one?
I was looking for the same condenser fan blade, for my emerson quite kool 1100. F12021-02 can be found on ebay for 24.95 + 15.00 shipping hope this helps, and good luck......
Jul 10, 2011 | Emerson Quiet Kool 10MW42K Air Conditioner
12,000 btu emerson quiet kool 220/230 about 9 years old, need to know $$ per hour to run with total kw/h cost $0.30 (this includes all taxes and fees). Sorry can't provide wattage or amps (no manual...
If your device doesn't list wattage, but it does list amps, then just multiply the amps times the voltage to get the watts. For example:
amps x volts = watts x .30 if you dont have any information you are sol.
Jul 06, 2011 | Emerson Quiet Kool 10NW16K Air Conditioner
Generator will not start
If your generator does not start and you have followed manufacturer's directions that came with your owner's manual purchase, there may be a problem with the motor, the points or the spark plug. Try removing the spark plug and checking the gap, then check the start process again after putting it back in. If still no ignition, check the points to make sure they are not burnt. If they appear all right, check to see if you have good compression. If there is not good compression, the rings would need to be changed. If this fails, and there is sufficient gas, it might mean that your motor is inoperable, due to wear and tear of everyday use.
Dec 15, 2010 | Briggs & Stratton Briggs Stratton 30208...
Ive got a homelite 720 watts generator and after a month from my purchase it wont start at all. i asked the dealer and they told me that the ic inside of the genset is busted. i told them if they have...
Please list your model number when posting and I might have found part number for you.
Go to homelite.com service and support, find parts, parts locator, model # if you cannot find model number go to product line, homelite, then select generator, without model number you will have dozens of generators to look at.
Jul 09, 2017 | Homelite Garden
Where can I purchase muffler for 5000 watt powermate generator?
YOU LOCAL LAWN MOWER SHOP. YOU WILL FIND THAT THE HOT DOG MUFFLERS ARE THE CHEAPEST.. THAT MOTOR SHOULD HAVE THREADS SO IT WILL SCREW RIGHT IN.. TA-DA FIXED FOR WELL UNDER 10 BUCKS.. COOL HUH//
DO ME A FLAVOR, IF'N I WAS OF ANY HELP LET ME KNOW OR VOTE
TRY TO BUY PRODUCTS MADE IN THE GOOD OLD USA ... Jay
Sep 12, 2010 | Coleman Powermate Powermate 5000W...
Problem with a ef1000 generator running rough. starts easy, gets to operation rev range, lasts for 5 to 20 sec, then runs rough, changed oil, air filter and plug cleaned carby, made little differance run...
I purchased a Propane Generator from Central Maine Diesel a few years ago.
20 HP Honda engine, Italian generator head.
Paid about $2300 plus shipping via Paradise Freight which was a few hundred.
I see the price is just a bit higher now... But the one I want most is Yuchai which i saw from a website.
Recently it blew a capacitor. Central Maine sent me 2 for the price of one even though it is out of warranty. $39 total for two.
I looked at generators on island but a similar Honda at Quality electric was close to $6000 and it wasn't even a 13750kw. More like 8 or 9000kw if I remember right.....
They have many generators at great prices but this is the one I settled for.
However, it is said that the Cummins generator is more popular than others.
Cummins Generator Cummins Generator Set Supplier and Manufacturer in China
Nov 12, 2017 | Yamaha EF2400iS Portable Generator
Just purchased Tomtom ONE XL GPS , does it have
yes, but you have to use one of the computer generated voices, because it not capable of announcing street names with human voices.
tap the map screen, then the little wrench icon, then scoll to the page with the voice options (chance voice) and select a computer generated one.
if you can find it, let me know...its also possible someone has deleted the computer voices, in that case, youll have to download tomtom home to get them back.
bill
Mar 09, 2010 | Tomtom ONE XL GPS
Emerson Quiet Kool 12HT13 Air Conditioner Logo
27 people viewed this question
Top Emerson Heating & Cooling Experts
Tim Whalen
Jay Finke
Jay Finke
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
