Question about LG WM8000HWA Front Load Tumble
DE2 error code - LG WM8000HWA Front Load Tumble
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
• Loose electrical connections at Door switch and
PWB Assembly.
• The DOOR SWITCH ASSEMBLY is out of order.
Posted on Jul 07, 2015
    New Friend:
This is a door error, following the list of diagnostics, check the area around the door to make sure there is nothing preventing it from closing securely. If there is nothing, try unplugging the washer then holding the start/ pause button for 3-5seconds. If that doesn't work listen for when the washer starts, if you hear the door attempt to lock two times when you press start, it probably is a faulty door switch. Simply take off the metal ring around the seal, (there should be a spring on the bottom) then pull back the seal/ gasket where the door connects to reveal the the start switch. From the outside remove the two screws holding it in place, then unplug the the start switch by pressing down the tab holding it to its connection. Now you can try and test the switch by using an ohm meter to see if the connections are good, but it most likely is out if you hear the two clicks. Test points 2 to 4 and the ohm meter should read between 750-1500 ohms, points 3-4 should be 70-90 ohms (though I could never get that reading on old or new switches). If when you replace the old switch with a new one which should cost you between 30-50$ and it still doesn't work, look at the connections in the wire plug and make sure they are ok, and double check the door latch. If none of those seem to be the problem it is mostl likely a problem with your PCB board and there should be a video on YouTube to see how to replace and check that, replacing that will cost you between $100-160.
Posted on Jun 28, 2015
My LG front loader is displaying de2, what can i do ? thank you
The dE2 error code indicates that the washer door is closed, but not locking.
Nov 29, 2016 | LG Washing Machines
2005 Chevy Aveo want start and is reading. De2.
What is De2 ? No such code for OBD2 on a Chevy Aveo ! How did you come up with this .Your best bet would be to take your vehicle to a qualified repair shop .
Aug 01, 2016 | 2005 Chevrolet Aveo
De2 error code already replaced door switch sensor still getting samecode
possibly the door seal or the door itself could be misaligned causing the door not to close properly.
May 16, 2016 | LG WM8000HWA 5.1 Cu. Ft. Mega Capacity...
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Erorr code 4003 zebra zxb8
Error Code 4001
System error code 4001 means "The local WINS cannot be deleted." This error code may also display as "ERROR_CAN_NOT_DEL_LOCAL_WINS" or as the value 0xFA1.
Error Code 4002
System error code 4002 means "The importation from the file failed." This error code may also display as "ERROR_STATIC_INIT" or as the value 0xFA2.
Error Code 4003
System error code 4003 means "The backup failed. Was a full backup done before?" This error code may also display as "ERROR_INC_BACKUP" or as the value 0xFA3.
Error Code 4004
System error code 4004 means "The backup failed. Check the directory to which you are backing the database." This error code may also display as "ERROR_FULL_BACKUP" or as the value 0xFA4.
Error Code 4005
System error code 4005 means "The name does not exist in the WINS database." This error code may also display as "ERROR_REC_NON_EXISTENT" or as the value 0xFA5.
Error Code 4006
System error code 4006 means "Replication with a nonconfigured partner is not allowed." This error code may also display as "ERROR_RPL_NOT_ALLOWED" or as the value 0xFA6.
System Error Codes
Sep 15, 2013 | Zebra ZXP Series 8 Thermal Card Printer
What does de2 mean on samsung washing machine and how can i fix it?
Hello
It is an error code. To confime it,I want to know the exact modlel number of it. Please send me that number.
Feb 01, 2012 | Samsung Washing Machines
BLINKING BUTTONS OF DE2 AFTER REFILLING After refilling water to the boiler of the machine. automatic buttons blink. indicating No. 3 at the board.
Machine is not able to get water fast enough, there might be a blockage in the inlet solenoid or the filter, and the safety is turning of the machine, because it is not at operating pressure, that is the only thing that comes to mind.
Feb 19, 2010 | Rancilio Epoca ST
2004 sony wega 37'' plasma tv not turning on.
You most likely have a power supply problem. but the problem may not be the actual power supply. The drive cicuits for the plasma panel can load down the power supply and give you the symptoms that you are having. Without being able to be there and take voltage measurements, I'm afraid I can't narrow it down more than that. My first suspect is that one or more of the sustain boards (the boards that drive the plasma panel) have failed. That would explain the lack of display. It is likely one of 3 boards that has failed, PSU (power supply) logic (the main control board for the set) or DE2 (panel drive board). There is a chance that the panel itself is bad, but that is not the most likely cause of your problem
Nov 18, 2008 | Sony WEGA KE-37XS910 37 in. HD-Ready...
LG WM8000HWA Front Load Tumble Logo
1,563 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
