Question about Canon LaserCLASS Office Equipment & Supplies
CLC5151 PAPER JAM
PAPER JAM
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Canon clc5151 color print unit error
Hi! I think you should try to reinstall drivers for your printer
Canon Printer driver download update drivers
Feb 06, 2014 | Office Equipment & Supplies
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
Oct 20, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Oct 20, 2009 | HP LaserJet M4345 MultiFunction Printer
Rear Paper Jam - No paper present.
Look for a small piece of paper that may be stuck in the switch indicating a paper jam.
Jun 01, 2009 | Canon PIXMA MP610 InkJet Printer
Error code on Ricoh FT5733 copier
Open ALL paper jam locations on the machine. The jam code only means the paper jam is somewhere BEYOND the paper drawer. Check ALL jam locations including duplexer, bypass, and ALL paper drawers.
Nov 12, 2008 | Office Equipment & Supplies
23 people viewed this question
old marine
old marine
