What is endemic? - Computers & Internet
Where do platypus live please tell me i need to learn
"egg-laying mammal endemic to eastern Australia, including Tasmania"
Good luck,
Paul Platypus Wikipedia
Apr 13, 2017 | Homework
What does endemic mean
According to http://www.merriam-webster.com/dictionary/endemic
en·dem·ic:
: growing or existing in a certain place or region
: common in a particular area or field
Oct 30, 2013 | Computers & Internet
Tv flicking
Usually power supply related (voltage changing) and endemic on some Samsung models----most of those a jumper on the power board needs to be removed.
Google the model number to see what is available on your model to see if common on it or not.
Aug 27, 2012 | Televison & Video
Is there a charging problem with the 96 Vulcan 750? I bought the bike and ever since I have had a hard time getting it to charge while driving. Is there some problem that is endemic to this bike? Bob
Sounds like u have a open cell in your battery , replace it , you said you had issues charging not lighting or running so this answer is based on the assumption there's voltage coming from stator is this accurate?
May 01, 2011 | 1996 kawasaki VN 750 Vulcan
My frontloader EWF1090 will not spin / drum doesn't move around
if its not spinning and the drum is siezed there is a coin or a forighn object jamming it, it can be removed but would have to go into an electrolux repair shop, if its in warranty no probs if its 2 years or less outta warranty they will repair it under a endemic failure, which in english means the bill would go to the manufacture hope it helps
Jun 19, 2010 | Electrolux Washing Machines
I cannot remove the grinder from my cuisinart Grind and Brew Coffeemaker. It still makes great coffee, but I want to clean the grinding mechasim and cannot remove it.
Common with the DGB-600 - you can try icing it down for 10 minutes - once removed, clean exterior with vinegar applied to a rag to get oils off - endemic to this unit - replacing it with exact same model will not help.
Oct 13, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Tv not turning on from standby goodmans lcd 32"
problem is with power board, it seems a problem that is endemic to these sets, you can sometimes manage to reset by unplugging set for 30 mins repowering and sometimes it will come back on otherwise look at replacing board
Jul 23, 2008 | Televison & Video
Ipod capacity
Yes, that is true - there is no fix - it is endemic to the unit - movie files greater than that size will have to be broken up.
Unless you are saying it won't let you add any more songs after 100MB are used? In that case, you need to reformat your player and reload the songs.
May 25, 2008 | Apple iPod nano
My camera will turn on but then turns off after I play the pics
This sound like an endemic fault with this model- contact Samung re replacement
Jan 17, 2008 | Samsung Digimax A7 Digital Camera
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
