Question about Omega 1267.1 ( ) : Quartz(1456 Omega) Watch for Women
I need a circuit for movement 1456
Please can you suggest sites
Need to order new movement.
Hi craig, I suggest that you search online using something like this "your make and model + replacement movements"
Jul 12, 2015 | Watches
Need correct replacement battery
the watch movement deters which battery the watch needs it is very important you do not put a battery in that doesn't suit the watch as it can short out the circuit however you can get the correct size in a gold seal quality which should not leak, also the older the watch, the more demanding the watch becomes on the battery as the movement components start to experience wear and tear
Apr 16, 2014 | Wenger Swiss Military Alpine Diver...
My watch stopping intermittently
When a quartz watch is no longer actuate with a good battery that means the movement needs a service (typically it's a bad circuit somewhere on the movement). It's fairly simple actually even I can do it and I'm not a horologist. Typically the service runs between $50-$100. Being that this may exceed the watches retail cost I would suggest concerning getting a new watch.
Dec 31, 2013 | Timberland QT7929201 Watch
I need to take the movement out of my ladies rotary lb77835 has to come out of the front but not sure how thats done
Don't know why this is posted under a Rolex issue or why you would be taking the movement out of this watch. I would suggest taking the back off if you haven't already.
The movement is connected to the crown, so basically if you're going to take out the movement, you're going to end up breaking the watch.
If you're trying to replace the battery, this can be done without removing the movement. I would suggest bringing it to a jeweler. They can replace the battery for ~$10.
Oct 29, 2013 | Rolex Submariner 16618 Wristwatch
I have a C.G.Iliffe - Barrow in Furness, 18k solid gold pocket watch with sn:69043. 18k Solid gold case marked FT. This watch was presented to my great grandmother by the Transvaal Government, for her...
At that time, it was common practice that jewellers shops would have their name put on watches that they sold.
I would suggest that it's almost certainly a Swiss movement - are there any numbers or characters stamped on the movement (you might need a loupe or magnifying glass to see them)?
An 18ct case would not have been used to house a low quality movement!
Aug 30, 2017 | Watches
Rolex Yatchmaster 2 second hand is not moving. Please help
Hi John,
Your Yachtmaster likely has one of three problems:
1) the hand loose on the pinion, or
2) the movement needs to be serviced
3) there is an issue with the button/gear for that function within the movement.
Automatic watches must be serviced every 3-5 years as the oils dry out and dust and debris in combination with the dried oils create excessive wear on the parts within the movement. As one must change oil in a fine automobile, it is the same with a Rolex.
We use the same processes as Rolex and are able to attain discontinued parts Rolex no longer supplies.
My suggestion is to use a Certified Master Horologist for your repair. We can certainly assist you with your repair at a much better price than Rolex. Thanks for the rating!
Sep 14, 2013 | Rolex Watches
Bulova has mechanical day/date display near 3 o'clock position, electronic watch (quartz I presume) less than 3 yrs old. Started losing time. I assumed the original battery needed to be replaced. Battery...
I believe you are just outside your warranty. Its time to see a watch maker/technician about repairing the watch. Often times slowing is as easy to fix as lubricating the movement and forcing the gear train through the use of a cyclonic device. This fix takes minutes and is very cost effective. If the slowing is due t circuit board issues or a more sever gear train problem then the movement will need to be overhauled. I suggest comparing this cost to the cost of a replacement movement.
Sep 22, 2009 | Bulova Watch
Watch doesn't talk anymore
If the battery is not visible by removing the back then this is not a battery change that I recommend for the layperson. I suggest taking this to a watchmaker or technician. This is because the battery powering the circuit board for sound maybe under the circuit board and not easily accessible without removing the movement and separating the circuit board from the movement. Also you should know that these sound boards are sensative and can easily be damaged.
Sep 18, 2009 | Avalon Ezc Low Vision One Button Talking ,...
I have a Citizen Aqualand Promaster 200M circa 1991 and the analog has stopped working. It was sent back to Citizen repair facility in CA last year and they said it cannot be repaired because movement is...
First of all they should be giving you explanation why the watch needs whole movement replacement and what is the cause.
As the watch movements are upgraded and made more sophisticated every year, some of them are discontinued and the next generation movements are replacing them. Watch manufacturing companies usually try to produce interchangeable movements, so, the newer one can replace the older.
In your case (if there is no newer version replacement) you have no option, but to shop around for exact new movement for replacement.
All you have to do is to find out your watch's movement number (that Citizen facility in CA should give that) and then shop for it. Plenty of movemevts on ebay, not to mention specialized watch part supplier companies. All available over the internet - just takes some time and nerve.
Rate, please.
Jul 23, 2009 | Citizen Promaster Cyber Aqualand Nx Dive...
What type of battery goes into Casio G shock MTG900, Module 2638
CTL is the designation for a rechargeable secondary battery. The CR is a primary disposable battery and is a 3 volt cell. The CTL1616 while the same size as the CR1616 function completely differently and are not interchangeable. The CTL1616 is 2.3 volts and is recharged by solar or light or kinetic movement. The CR1616 is 3 volts is not rechargeable and will not function properly in a time piece designed for a 2.3 volt circuit. There is only one manufacturer of the CTL1616, Panasonic and they sell through Casio parts distribution.
Jan 22, 2009 | Luminox 3102 (Size: ) Watch for Men
Omega 1267.1 ( ) : Quartz(1456 Omega) Watch for Women Logo
22 people viewed this question
Top Omega Watches Experts
DROPNDEAL
DROPNDEAL
Geoff
Are you an Omega Watch Expert? Answer questions, earn points and help others
