Question about Heat Controller Comfort-Aire Condensing Unit, AC, 5 Ton, 58000 BtuH - RSG1360-1A
How do you reset heat controller RSD1060? - Heat Controller Comfort-Aire Condensing Unit, AC, 5 Ton, 58000 BtuH - RSG1360-1A
No heat
One of 4 things to check.
First remove the cover on the back and then...
1.) Check the Bottom Thermostat for a Red Reset button in the middle Push it and see if it clicks and resets.
2.) If no reset button (Not all models have em) then use a multimeter to check the Thermostat. If faulty then the heating unit is bad and will need replaced. If its good then
3.) There is a NTC on the front behind the control panel. Uou need to check this.
If that's OK then it's probably the the main control board but...it's usually the heating unit. or the reset button so check those first.
Mar 11, 2014 | Dryers
Stovetop elements not heating and oven not heating
You will need to replace the control board. Here is the part to order.
Control Oven black
Jan 30, 2014 | KitchenAid KERC506HBS Electric Kitchen...
Comfortmaker furnace model GUH075 requires resetting for flame to light?
Is this an oil or gas fueled furnace? All heating appliances have several safety switches in the controls. Flicking the on/off switch (assuming you mean the emergency toggle switch) is not resetting the burner. If you pressed a button near the red light,that MAY have been the primary control reset.
Your problem could be anything from the main power switch to one of the many controls with a wiring or sensor issue. Or even a t-stat wire problem.
Regardless, a thorough technician should be checking the entire circuit, from the t-stat to every control in the circuit. Including every wire.
Lastly, a qualified licensed technician should never diagnose without being in front of the appliance. Hope this helped :)
Jan 30, 2013 | Heating & Cooling
Error 1 on kenwood dishwasher
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 05, 2011 | Kenwood KDW243A Builtin Dishwasher
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Reset code for dishwasher
In order to reset the dishwasher you need to key in this sequence rapidly within 6-8 secs.
Hi Temp/ Heat Dry/ Hi Temp/ Heat Dry/ High Temp/ Heat Dry
All lights should turn on if reset is successful. Press Cancel to exit.
If this does not happen then most likely the controller or the keypad is faulty.
Oct 18, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Amana #PTC153b50AJ ser 0410686783 Customer heard a pop in unit and it went off. Breaker was tripped. Reset breaker and unit runs in a/c mode but does not heat in heat mode. This is not a heat pump but...
I'm seeing a master switch on the control board, try a reset there. But, sounds like a bad element. You need to test continuity through your heater components. When testing a component unhook wires first, as they will still have continuity even if bad with wires attached.
Jun 04, 2017 | Amana PTC153B50AJ Electric Heat Air...
Rinse Only light blinks
Try pushing high temp wash>heated dry>High temp wash>Heated dry   that should reset the control but it will most likely come back count the number of flashes before a pause.it's an error code could be a heating cycle failure.
 If the control doesn't reset you have a control or touch pad issue.
Sep 16, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Tub heater kicking out
sounds like a part is bad on the control pack. Whatever gets 'jiggled' when you slam the door down is most likely the bad part.
Oct 27, 2008 | Home
Sunbeam Heating pad will not reset
I have a Sunbeam heating pad with the SW204 controller that the High light blinks when it is plugged in. I called Sunbeam and the first thing they said is it cannot be plugged into a surge protector. Next, to reset it unplug it from the wall, then unplug the controller from the heating pad. Wait 30 seconds, then plug the controller back into the heating pad and then into the wall. It did the trick. However, when I move it to the bedroom plug it does the same blinking. Sunbeam is sending me a replacement heating pad. They appear to be very good with Customer Service since it is more than a year old.
Mar 21, 2008 | Heating & Cooling
Heat Controller Comfort-Aire Condensing Unit, AC, 5 Ton, 58000 BtuH - RSG1360-1A Logo
35 people viewed this question
Top Heat Controller Heating & Cooling Experts
jdthefixer
JonSnell Electronic
JonSnell Electronic
Tom Chichester
Are you a Heat Controller Heating and Cooling Expert? Answer questions, earn points and help others
