Question about Samsung CLP 315 Laser Printer
How to empty waste - Samsung CLP 315 Laser Printer
Reset Waste Toner
If your machine is displaying "replace waste toner container" then you can empty the waste toner box & reset the machine.
If you open the front door you will see a large black box & above this a small rectangular green button. Pressing this button will release the black box. The box will then lift upwards from the machine. At the bottom of the box you will see a round, clear plastic bung, remove the bung & empty the waste toner into a suitable bag or container. Once emptied, the bung can be re-fitted, the waste box can be inserted back into the machine. Locate the waste box into the 2 slots then push the waste box firmly back in place until it latches. Turn the machine off & on using the switch located to the left of the waste box in the bottom left corner of the inside of the front door. This should reset the machine. Be careful when disposing of the waste toner, it is flammable so do not dispose of in a fire. Hope this helps.
Dave.
Feb 19, 2016 | Sharp MX-3501N All-In-One Printer
Hoe do I empty the toner waste on an old Lanier 5645?
Its the brown belt thing on the right door, take off the 2 springs and remove the belt assy and empty, very messy...-Carl
Oct 16, 2014 | Lanier Office Equipment & Supplies
Emptying waste toner BizHub C250
It has the facility to empty the waste toner cartridge manually.You do not need to buy new one.
May 15, 2012 | Konica Minolta magicolor 5430 DL Laser...
Getting a false error message that the ink/toner is empty and wastebin is full when i print to my phaser 8860 from a macbook on 10.6 (networked printer)
The waste bin full error can occur if the waste bin was not removed from the machine for over 10 seconds when it was emptied. Please remove the waste bin and wait for a full 10 to 20 seconds before replacing the Waste bin.
If the message still displays turn off the machine and leave it off for 1 minute then turn the machine back on.
Then run software update to make sure you have the latest OS updates.
Then delete the printer and re-add the printer.
Aug 04, 2011 | Xerox Phaser 8860MFP Printer
How do you empty the waste toner bottle? And where is it located?
on the cf2001 the waste bottle is located on the left side door but to empty is going to be difficult and messy, there is an auger that you after turn while you angle the opening of the bottle toward a garbage container to empty it, the bottle is really a rectangular container with a notch in the top middle portion that needs to be clear of toner because a optical sensor sees through it, or else it will still give you the message empty waste bottle, it is easier to have an extra empty waste bottle to replace it.... hope this helps
Dec 29, 2009 | Minolta CF2001 Copier
Empty the waste ink
Take the printer to a qualified technician.
He/she can "empty" or "replace" the waste ink collector
*AND* "reset" the printer's internal software, to say that it has been serviced.
Nov 27, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Empty waste bucket on cannon 3050
If this is on a Canon NP3050 copier, the waste toner is stored in the drum unit. The developer unit needs to be released away from the drum unit before removing it (drum unit). There is a plastic lid to remove to empty waste toner. Use caution when emptying, it is easy to make a mess.
Nov 23, 2009 | Canon Office Equipment & Supplies
I have Canon ir5075 and it asks me to change waste bottle. I empty the bottle. But do not know how to tell the printer that it is empty.
I am not familiar with this model but usually Canon waste bottle has:
1. Check if the waste toner botlle has some clear portion near the neck, (as in IRC3200) or other part of the bottle ,even the waste toner was removed but if this portion is still clouded by toner the sensor will still detect the waste is full
2. If the situation is not like this some Canon Ir machine needs to reset waste toner counter in the service program mode even the waste toner bottle was emptied
Jun 09, 2009 | Canon imageRUNNER 5000 Copier
Estudio 3511 empty waste toner problem
Hello sir;You have to empty waste toner container, it located at the end of the drum unit.
Jan 05, 2009 | Toshiba Estudio 200L Copier
Samsung CLP 315 Laser Printer Logo
42 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
