Question about Samsung DV350AGW 7.3 cu. ft. Steam Gas Dryer
Why does my samsung steam dryer model DV350AGW/XAA SHUTS OFF AFTER TWO MINUTES
  • 382 Answers
SOURCE: how do i fix a belt that slipped off my samsung
There is a tensioner in the pulley that should keep the belt from slipping off.n most cases they work very well at keeping the belt tight.In your case the belt may be stretched too much ,I would check it and replace it if necessary
Posted on Mar 07, 2010
rickead1
  • 1998 Answers
SOURCE: samsung dryer dv317aeg/xaa has code on display
http://www.washingmachinereviews.org.uk/fault-codes/errors-and-solutions/ use this site try this solution is what the company suggests simply folo down the list till u see your error code with there solution if this does not work u willhave t call a tech to do test on your heater as well as the wiring going to the heater
Posted on Jul 26, 2010
SOURCE: My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
Posted on Sep 18, 2010
  • 291 Answers
SOURCE: have a samsung dryer model DV209AEW/XAA. I "hand
Check to make sure your child lock is off first. Hold the time and signal buttons simultaneously for three seconds. Unlikely, but do check. Some of these dryers have a safety switch that the idler pulley has to engage to allow the dryer to run. I tried to find a schematic for this model but could not get one to tell if you do have a safety switch. Look at the arm of the idler pulley and see if it is contacting the switch actuator correctly. When a belt breaks or pops off, sometimes the arm of the pulley will move to the other side of the switch actuator and will not allow the dryer to run once a belt is reistalled. I would also look to see if a wire was knocked off of the motor switch when your belt came off. Good Luck, Appliance Specialists
Posted on Dec 03, 2010
SOURCE: My Samsung steam dryer (model DV448AEW/XAA) has
This is for the ELECTRIC MODEL Only. I have the DV448AEPl and had the same problem... I cleaned all of the lint from every nook and cranny and ordered a "repair kit" from Sears (http://www.searspartsdirect.com/partsdirect/part-model/Samsung-Parts/Dryer-Parts/Model-DV448AEPXAA/1482/0151200?searchedModel=dv448&blt=) there is even a blow up of the parts there - I ordered part numbers , DC47-00015A, thermostat, DC47-00018A - thermostat and DC47-00019A - dryer heater. The heater is relatively easy to get to if your not squeamish about removing some screws and taking the front off the dryer. Once the front is off you can clean even more lint from the dryer. Remove the heater unit by unscrewing the single screw accessed from the front of the dryer and then disconnecting all of the connectors.
Lastly - once I took the heater assembly out I found that a dime had made its way into the heater coil and was shorting it out... Probably could have got by by just removing the dime and cleaning the coil but I figured that since I was elbow deep in the thing I might as well clean it all up and install the new parts.... Cost of parts was about $80.00 w/shipping. Cost of a repairman to knock on my door here is $150 so I came out ahead on this one... Good luck.
Posted on Dec 08, 2010
I get the nf halfway through the cycle. ALWAYS with 26 minutes remaining after opening and shutting the door several times and can get it to resume the cycle.
SAMSUNG WF331ANW/XAA TROUBLE SHOOTING GUIDE ...
www.manualslib.com > ... > Washer > WF331ANW/XAA
View and Download Samsung WF331ANW/XAA Trouble Shooting Guide technical information online. 3.7 cu. ft. High Efficiency VRT Steam Front Load Washer (Neat White). ... DC68-02834A-03_EN. 2011-09-28. 4:00:29. Previous page ... SamsungWF337AAG · Samsung WF338AAB · Samsung WF331ANR/XAA · Samsung ...
Support - Washers WF431ABP/XAA ' Samsung Washers ...
www.samsung.com > ... > Washers
Samsung Electronics
Dec 08, 2015 | Samsung WF338AAB 4.0 cu. ft. Front Load...
WHY DOES MY SAMSUNG MODEL DV448AEP/XAA SENSOR DRY MODE RUN FOR TWO MINUTES AND THEN WILL GO TO COOL DOWN MODE, ALL OTHER DRY CYCLES MANUEL AND STEAM CYCLE OPERATE FINE!
Sensor is screwed or the timer relay for that part of it is not working . Go to an appliance store to get wiring diagrams ordered and might even know about the problem w that model
Feb 19, 2015 | Samsung Dryers
I own a Samsung dryer model DV218AEB/XAA. In both the sensor and timed cycles it shuts off early and goes dead for about 30 minutes before it comes back to life and the load can be restarted, only to
I have a good idea that it may be the following;
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
You can check out other possibilities and order parts here using the following link;
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/2---/Dryer-stops-turning-during-cycle
Good Luck!
Rich Lilja
Oct 29, 2014 | Samsung DV218AEB/XAA 7.3-CuFt Electric...
Dryer does not dry. Wont heat up.
I am directing you to Repair Clinic.com as that will help you diagnose the issue that you are having as there isn't enough info for me to get specific info for you!
The link is; http://www.repairclinic.com/Shop-For-Parts/a8b160d1420640-x73616d73756e67206476353437316165702f786161/Samsung-Dv5471aep-Xaa-Model-DV5471AEPXAA-Samsung-Dryer-Parts
Good Luck!
Rich Lilja
Oct 06, 2014 | Samsung DV5471AEP/XAA 7.4 cu. ft. Capacity...
DV350AGW/XAA will power on, but does nothing when you push start
i have a bsch was3274 does the same turns on here the relays click 2 or 3 times and water dosent start going in to the machine
Feb 14, 2014 | Samsung DV331AEW Dryer
My Samsung dryer DV2C6BEW/XAA will only run for 10 minutes then shuts off and wont come back on for 20 minutes and I have no codes
Your dyer has several "overheat" switches or thermostats built in to prevent overheating and possible fire. You will be needing to "tear the whole thing apart" to find the problem. Start with the air ducting. Easy way to check it is to disconnect the hose from the back and see if it still shuts off too soon. If it does not, your vent to the outside is plugged and is causing the problem. If it still happens, you will need to clean the whole machine of accumulated lint by taking it all apart. Big job.
Then try it. If it still misbehaves, you have a bad "fuse" or "switch" inside the back or the bottom. There are as many as 6 on some models. An electrical tester will help you find the "tripped switch".
Be blessed.
Sep 01, 2013 | Samsung Dryers
My dryer model DV2CBEW/XAA heats up for 10 minutes then shuts off and wont come back on for 20 minutes and does not have any codes
wires to thermostat loose or broken,or thermostat needs replacing,check that all piping is kink free and clear of dust bunnies,use recommended size outlet flue,metal is best,less length and bends make for better flow
Samsung DV350AGW 7.3 cu. ft. Steam Gas Dryer Logo
42 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
