Question about JVC KW-NX7000 Car DVD Player
How do I detach the face plate after I have put in on wrong?
The bottom clamps are locked BUT the top is not, I cant attach it, I need to take it off and start over by putting the top on first then the bottom, but I cant get it back off. please help
GARYDALE
  • 15 Answers
SOURCE: JVC KD -S680 needs help
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Posted on Sep 25, 2006
  • 125 Answers
SOURCE: cd player in van not working properly
Is it always 20 minutes or is it random. If it intermittently switches off, i would say that the power button has a problem. Maybe there is dirt, or moisture simply tha the switch has no 'spring action' anymore that it touches the contacts.
Posted on May 15, 2007
proton77
  • 1183 Answers
Thanks for the description of your problem. At the face of it , it looks like the problem is only the face plate. Coz the unit lights up fine and there are no blown fuses. I recommend replacing the face plate first and checking. If the that not working , we have to open the unit and check internal connections.
Also do check all your relay cables, just to make sure you are getting proper current to the unit.
Thanks
Proton
Posted on Jun 18, 2008
zappanut
  • 959 Answers
SOURCE: the face plate of the jvc car stereo doesn't stay tight and radio
I suggest some two sided sticky tape. Carpet tape , I thnk it's called.
If you don't plan on ever removing the face again...°¿°
Posted on Nov 18, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: my jvc cd player goes off and i have to remove the
Try cleaning the copper connecting pins with some rubbing alcohol. This sounds like it is a issue with the face no fully locking into the deck anymore
Posted on Jan 02, 2010
Why does my bobbin thread tangle around my bobbin plate
try changing the needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
try rethreading the machine top
Jun 10, 2012 | Brother Sewing Machines
Tip
How to take apart a wii
Disassembling the Wii<br />Method : Taking it Apart<br /><br />There are plenty of reasons to take apart a wii, whatever your case may be here's a guide to doing it.<br />REQUIRED TOOLS AND ITEMS<br /><br /> * A Nintendo Wii ( of course )<br /> * A Tri-wing screwdriver Size 3 (please save us all the trouble and don't try and use a flathead)<br /> o This NEEDS to have a long shaft. There is a part of the wii that has recessed screws.<br /> * A mini Phillips screwdriver<br /> * A small plate or container ( to hold the screws in )<br /> * A couple pieces of tape ( use the tape to keep track of what screws belong to part of the wii)<br /> * Soft Working surface ( the wii scratches very easily )<br /> * A razor blade and a pair of tweezers will help remove items<br /><br />Step 1. Removing the Battery<br /><br /> <br /> * Remove it and pull the battery tray<br /><br /><br />Step 2. Removing 5 screws /w plastic covers<br /><br /> * When the battery was removed it revealed 1 screw. There are four more hidden underneath plastic stickers and rubber feet. Refer to the picture for their locations<br /> * Peel up the plastic stickers with a razor and pull it away with a tweezers. (place the stickers neatly away from your working area if you plan on putting them back on. )<br /> * Remove the screws ( fix the 5 screws to a single piece of scotch tape and put it in your container. )<br /> * For reference the black screw is the one on the top left, the two longer screws are located on the bottom and the shorter ones on the top.<br /> * This is important to remember because you don't want to put the screws in the wrong holes when reassembling the unit.<br /><br /><br />Step 3. Removing Rubber Feet and removing screws<br /><br /> * Position the wii like in the picture. ( use the notch as a guide )<br /> * There are 2 rubber feet on top and 2 plastic stickers on the bottom that you need to remove. ( do not remove the rubber feet on the bottom. Not necessary )<br /> * Remove the screws and fix them to a second piece of tape.<br /> * Take note that the two black screws go into the faceplate/bottom and the two silver ones go into the top/recessed holes.<br /><br /><br /><br />Step 4. Removing GameCube port covers and screws<br /><br /> * There is a section of the wii that houses the ports for the Gamecube accessories. The 2 covers to this section will flip open and easily detach. If you look there's a sticker on the inside depicting how to remove the covers. They snap off with light pressure. Remove them now.<br /> * Now remove the 3 black screws here and attach them to a 3rd piece of tape. Notice that the screw closest the front/face of the wii is the longest of the 3 screws.<br /><br /><br />Step 5. Removing the face and detaching the cable<br /><br /> * Now position the wii with the face upwards with the dvd tray on the bottom.<br /> * Flip the wii face upwards and away from you SLOWLY and look for the connection marked in the picture.<br /> * Use a flathead of tweezers to pull the WHITE connector out of the socket.<br /> * Set aside the face plate in a safe location.<br /><br />disassemblin the wii image<br /><br /><br /><br />Step 6. Removing the GameCube black cover and screws<br /><br /> * The black covering you saw earlier should lift out easily now. (Although it only goes one way)<br /> * Remove the 4 screws and attach them to a 4th piece of tape and set them aside.<br /> * If the position of the wii is like in the picture then the top screws are tri-wing and the bottoms screws are Phillips. <br /><br /><br /><br /> <br /><br /><br />Step 7. Opening the Wii up and removing 4 screws<br /><br /> * Position the wii with the notch on the bottom right.<br /> * Lift the right side of the wii up and the cover should detach<br /> * Flip the cover over to the left<br /> * The heat sink may or may not come with the cover ( if not just remove it )<br /> * Remove the 4 screws marked in the picture. Fix them to a 5th piece of tape. (although these screws are much different than the rest you've encountered.)<br /><br /><br />Step 8. Disassembling DVDROM drive<br /><br /> * Be extremely careful with this step. Slowly flip the top portion of the drive like in the picture. Notice how short those wires are?<br /> * Remove the White connection first. It's similar to the one earlier on the face of the wii<br /> o TAKE YOUR TIME ON THIS STEP<br /> * Now the thicker cable is removed by flipping the brown plastic tab upwards<br /> o The cable will just slide out now<br /><br />Step 9. Do what you need to do!<br /><br /> * You're all done! Enjoy!<br /> * The marked area is an ideal spot for a modchip<br /><br />o Not that we condone the use of modchips for illegal activities or anything. <br /><br /><br /> i could not upload the pictures with this post so please email me if you need the pictures on the removal of the, hopefully you should be able to understand from the instructions above but if you get stuck just drop me a message on<br />pauldonp@msn.com<br />
on Nov 24, 2010 | Video Game Consoles & Games
How do I install a brush cutter on my 128LD trimmer?
The 128LD is a detachable shaft machine, there are a number of attachments, hedge trimmer, brush cutter, brush, blower etc, there is a alloy clamp at the bottom of the machines tube, just push the attachment tube into the clamp, there is a locating hole so as you know it is fully home, now screw the clamping screw fully down to lock in place
May 12, 2011 | Husqvarna Garden
I changed my brakes on rear put on new drums,pads and springs but now i get clunking noise when i put on the brakes on the passenger side.please help
Jack up the rear end, spin each wheel to determine which side needs to come off, have someone else apply the brakes while you are spinning the wheels. Take that wheel off and pull the drum, inspect the spring at the bottom of shoes to determine if it is on or on properly, they are only supposed to go on one way, but can go on wrong and appear to be correct. Otherwise, attach a clamp such as an Irwin 12 in. clamp Model 5412 and clamp it onto the shoes (I've also used duct tape wrapped several times around the brake shoes). Have your friend apply the brakes and watch the backing plate and wheel cylinder to see if they or anything else moves that shouldn't. Make sure your shoes are seated properly at both top and bottom. 6357227b-1ffe-4078-b5db-5c4d4d846cb2.jpg
Dec 30, 2010 | 2003 Pontiac Aztek
I am looking for directions on changing the starter
1. The Upper Bolt is easily accessed from the front of the vehicle going OVER the right side of the radiator. It is partially hidden by a black brace. There is a black ground wire going to where a nut(s) are located. This first nut will allow you to take off the ground connection, however the bolt has another nut further in (to the left) which is totally hidden. Remove this first nut.
2. After the first nut is off, remove the ground wire, then using a deep socket 15mm socket remove the second nut which is welded/attached to the bolt.
3. Go under the vehicle to remove the wires from the Starter. The first wire is the positive cable (should be red) attached on the solenoid portion of the starter. Remove the nut and lock washer and detach the wire. The second wire (single small gauge) goes to the solenoid and is connected using a slide lock - press release connection. It is difficult to see the slide lock and the press release located on the top side of the connection. Slide the red slide lock out and press the release, and pull out the connection straight out. Do not force it, or it may damage the connector. Note the placement of the bottom bolt position on the Starter. DO NOT remove the two (2) small, but long connector bolts on the wire connection end of the starter.
4. Remembering the noted postion: remove the lower 15mm bolt from the Starter. The bolt head is located on the back side of plate moving towards the left side of the Van. It is easily accessed from underneath in front of the transmission. Near the end of removing this bolt, support the starter or it will fall out.
5. Remove the Starter, noting the position of the starter. There should be a separate starter facing plate. If if didn't come down with the starter check up in the starter to flywheel opening and remove the plate.
6. Installation is Reverse of above. The facing plate is a little tricky getting it to stay in place. By starting with the bottom bolt it is easier, Make sure you continuously support the Starter in position to save crossthreading the bolt or starter. Hand tighten only the bottom bolt as you want to be able to turn the starter slightly to get the top bolt in.
Starter Bolts are tigthen to 35 ft-lbs.
Let me know if it helped or if you need additional help at fixya.com
Jan 17, 2010 | 2002 Dodge Grand Caravan
No more steam from my Solis SL-70
Hi
You have a thermostat on top of the boiler that is out. There are 4 thermostats in top. The two you want to replace are the one in the center (136C)and the one towards the front(117C). The one in the center is a screw in thermostat and it holds a clamp that holds the others down. There is a fuse also, so make sure that when you put it back together the fuse is under the its clamp. You only have to remove the wires on the center thermostat until you need to remove the wires for the steam. That way you won't get them mixed up.
The top comes off by removing the screw on the top back where the water tank locks in. Once the screw is removed the put both hands on the side of the machine near the top and with your 2 index fingers push the top forward. This will push the top of the face plate forward also. The top of the face plate locks into the bottom of the front part of the top, so when you put it back together slip bottom of the face plate into the machine, then put the top on the face plate so the front of both is flush whit each other. Then push down and back on the top and it will lock in. then put the screw back in and your done. Contact 1-877-855-4540 for parts.
Jan 27, 2009 | Solis Crema SL-70 Espresso Machine
Power steering rack
jj, here's the procedure:
turn ignition key to locked position and turn steering wheel to the left until the wheel is locked. Remove key.
While vehicle still on ground disconnect the steering column shaft coupler from the steering gear intermediate coupler. Remove the cotter key the nut and the pinch bolt.
Loosen wheel lug, raise vehicle support securely w/ jack stands, remove the wheels.
Raise the insulating wrap on the power steering return hose to expose the hose clamp. Remove the hose clamp and detach the hose, Drain ps fluid thru the hose.
Remove both tie rod ends from steering knuckles.
Remove the 2 bolts and loosen the 3rd attaching the anti-lock brakes Hydraulic control Unit (HCU) to the suspension cradle.
then rotate the HCU rearward to allow access to the cradle bolt and nut just forward of the hcu.
Remove the nuts and bolts attaching the cradle plate to the bottom of the front suspension cradle, then remove cradle plate from cradle.
Remove bracket attaching power steering fluid line to the front suspension cradle.
Detach ps.fluid pressure and return lines from the ps gear.
Remove the 3 bolts and nuts mounting the steering gear to the front suspension cradle.
Lower the steering gear from the suspension cradle enough to allow access to the intermediate coupler roll pin. Install a roll pin remover/installer tool (they always get u with that darn special tool, don't they?) or equivalent set up. Pull the roll pin out of the intermediate coupler. Separate the intermediate coupler from the shaft of the steering gear Remove the steering gear assembly from the suspension cradle. Well, it's too late to give the install procedure, but u seem to have it under control, so let me know if u need more info and how u make out! Merry Christmas!
Dec 18, 2008 | 1998 Dodge Caravan
Not turning on
That Red light is saying that the front panel is not attached. This is the "Security Indicator" and is to warn crooks when you have removed the face plate. If this is on, and the plate is attached, I would remove and replace the front detachable plate once to ensure a good connection. That's a simple thing to try and only requires a quick operation.
Hope that helps. (If not, more info is needed for me to be of any help.)
Jul 22, 2008 | Panasonic CQ-C7103U CD Player
Nothing works
try taken face plate off if detachable then put back on sounds like the face plate clip might be weak and or missing spring inside
but if face plate stays attached just need to clean and put back on right to deck no easy way to say that
May 09, 2008 | Pioneer DEH-P850MP CD Player
Face plate
the face plate is not removable it only folds down
Apr 10, 2008 | Pioneer DEH-P6600 CD Player
JVC KW-NX7000 Car DVD Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
