Question about Magic Chef 9122 Gas Single Oven
Gas smell oven does not light
My Magic Chef gas oven does not work in the baking mode. The broil burner lights, but the baking burner does not light. The range top burners all fire. There is gas odor when the oven burner is turned on. The temp does not go up. What do I need to do?
  • 11,896 Answers
You may need new coupler on pilot system
Posted on Jun 23, 2009
2 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: Gas range won't work
Hi, Even tho the ignitor is glowing, it can be bad. It has to pull enough amps to open the gas valve. This is very common problem. I can get you the part and or prices if you could get me the model#
If I can help further, please let me know.
Thanks
Vic
Posted on May 15, 2009
Magic chef oven with uniburners oven will not light. igniter gets red hot but seems like no gas coming at all. burners on top work fine.
Since the bake burner does glow yet no flame that means that the igniter is weak and should replaced...the way the igniter works is that it comes on and get very hot where upon getting hot it draws a certain amount of amperage which will allow the gas valve to open resulting in a flame. The igniter is indeed coming on yet its not getting hot enough to draw the proper amp drqaw to open the gas valve...by replacing it with a new fresh igniter it will draw the correct amprage and let the gas flow.
GENE
Oct 02, 2011 | Magic Chef Ovens
Magic Chef oven won't lite. The ignitor glows red hot but no flame. After about 10 minutes of being on I start to smell gas. Not a strong smell but its in the air. I'm thinking gas valve. I did a...
The problem with your oven is that ignitor is weak and not drawing enough amprage to open the gas valve, the gas you smell was since the ignitor does come on it allowed the gas valve to open a wee bit but since ignitor is weak it wont allow gas valve to open fully. I know you going to doubt that what i'm telling you is correct, i base my diagnosis on my 30 years experience as a appliance repair technician.Replace ignitor and enjoy your baked meal
Gene
Jul 30, 2011 | Magic Chef 9122 Gas Single Oven
Oven won't light, even with ignitor getting red
If your oven won't bake, check these:
Bake igniter
Other causes
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
May 23, 2009 | Magic Chef 9122 Gas Single Oven
Thanks
Vic
May 15, 2009 | Magic Chef 9122 Gas Single Oven
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Won't heat up
You have two ignitors one for bake and one for broil your bake is not working
Nov 09, 2008 | Maytag CWG3100A Gas Single Oven
Magic chef oven wont turn on
yes oven ignightor to confim this try broil if it lights then its bottom oven ignightor get back wit me ill outline procedure
Dec 29, 2007 | Ovens
Magic Chef Oven won't light
Your oven bake ignitor is becoming defective. Even though it is glowing, the resistance is not great enough to "pop" the gas valve open and is slowly seeping gas into the oven cavity. With a strong ignitor, the oven should light within 30-45 seconds. Because this is a gas oven, I DO NOT RECOMMEND FIXING IT YOURSELF. Call an experienced technician.
Sep 27, 2007 | Ovens
Magic Chef 9122 Gas Single Oven Logo
718 people viewed this question
Top Magic Chef Ovens Experts
Sal De
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
