Question about Yamaha Music
How to take apart a ypp-50 piano - Yamaha Music
2 Suggested Answers
guitarmanjoe
  • 336 Answers
SOURCE: On my new (2nd hand) Yamaha YPP-50 piano, the
There is a narrow padding strip that runs under all the keys going across. It is made of a type of felt. It is worn or torn in that spot. If you are careful and have some mechanical skill at opening the unit, you will see it, it should be a pretty simple fix to glue the felt back (if torn) or even to glue a small piece of felt in that spot to raise the key, which will allow full movement again so it would feel pretty close to normal again.
Posted on Mar 30, 2013
I have a Technics PR-305 Digital Piano in which I play on. I took apart the Digital piano to get to the rubber contact to clean them. later on I went to turn on the piano and it didn`t work.
Attempted to clean? Not a good idea obviously...Take it apart like you did before and look at the wiring and imagine that you can divine the thing to reveal some logical explanation. If you used a contact cleaner or spray to clean, that could be death to that piano my friend.
Dec 12, 2015 | Music
I have I Technics PR-305 Digital Piano. I took it apart to try to clean the rubber contacts with rubbing alcohol. It improve some what, then later on I turned on my Technics R-305 Digital Piano.
I would suggest taking it into the nearest factory authorized repair center. Go to the Technics web site to find one in your area.
Dec 10, 2015 | Music
Middle C on my Model #SGP-151G piano is dead. How can I fix it?
I have taken keyboards apart and reattached springs that hold keys in position, also use electronics contact spray cleaner to free up the key and switch point that activities the sound
hope this helps?
Mar 20, 2015 | Music
Piano one key loud
Depending on which model you have, the contacts aren't difficult to locate. If you have removed the keyboard bed (which I hope you have...and not ripped out the guts behind the piano! :) the sensors usually sit to the rear and uppermost. They may be covered by a thin plastic (don't remove the plastic tho)
Nov 04, 2013 | Casio Music
I have korg pa 50 fd my screen say korg pa 50 i get only one thing my paino work only
i have korg pa 50 fd when i turn on the power on screen says korg pa 50 only thing work just piano that is it my menu all freez to download the floppy disk is any body has any idea thanks
plz help me out
Aug 14, 2013 | Music
On my new (2nd hand) Yamaha YPP-50 piano, the middle D key is slightly lowered and requires a lot of strength to get sound from it. I'm wondering if its possible to fix? Maybe without going to a Yamaha...
Mar 29, 2013 | Music
Key doesn't work properlyon yamaha p95 piano
take it back, its still under warranty. That means the key has a contact problem in the circuit. you have to take it all apart, clean it, check the contacts....probably lint. You can try vaccumming it and it might fix the problem. I bought one too and it wasnt good
May 07, 2012 | Yamaha P-95 P95 DIGITAL PIANO BLACK
Digital Piano has sticking key
Typically LOTS of screws... concentrate on those around the edge. USE GREAT care and force nothing when removing the cover...and great care of cables between the cover and the base. Mark the cables so you remember the direction they attach.
When you get edge screws out, then gentle lift and see where it seems to be held...
Some of these synths have 50 to take out to get apart. MOST are in plastic bosses and keep track of the size and length as you can put too long a one in the wrong place and crack the boss.
I use a compartmented plastic tray to keep the screws in order.
Jan 06, 2010 | Yamaha NP 30 76 Key Lightweight Digital...
Keys not sounding as loud as others
Hi, BHOWDY.
Probably the best thing to do is call the Yamaha service center nearest you. I live in the Los Angeles area, and the Yamaha service center closest to me is in Buena Park. I called them on the phone and told them what the problem was, and they knew immediately what parts were needed and they shipped them out that same day.
The contacts that seem to wear out the fastest are the ones near the middle of the keyboard. On my CLP-170, it's the keys between middle C and the G above that -- probably no more then 4 or 5 keys. However, I ordered replacement contacts for all 88 keys because once you take the piano apart to replace the contacts, you may as well replace all of them.
Good luck, Howard
Sep 29, 2008 | Yamaha Full-Size Keyboard
Music Logo
44 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
