Question about JVC Televison & Video
JVC AV20920 TV. No audio. Menu does not bring up TV SPEAKER ON/OFF
  • d_lukas Jun 23, 2009
    The MTS section does not come up on the menu either. I thought that was only for stereo versions of the 20920, was not sure that mine was stereo. Why don't these come up on menu ?
    yes it has audio out
2 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: Lost sound on JVC TV
http://www.amazon.com/JVC-AV-48WP30-Widescreen-HDTV-Ready-Rear-Projection/dp/B000066R7X
Cut and paste this link. Amazon's page has a link to the JVC manual. That'll tell you what you need to know
Posted on Feb 28, 2008
Can I connect a 3.5mm audio cable from my TV to this JVC RX705V receiver?
So if you're trying to amplify the sound coming out of your TV to an amplifier you need to connect the output on the back of your TV on the receiver to the end audio input on the back of your receiver you might need different types of connections on each end but as long as you take the output on the TV and input it into your receiver your receiver will amplify the sound another way you could do it is to go inside the TV and connect two wires off of each of the two wires of each speaker leaving the internal speakers connected and then plug them in to the audio inputs on your receiver also if you're using one of the audio outputs on TV make sure you go into the menu and tell it you're using external speakers Good Luck Chuck
Mar 28, 2018 | JVC Audio Players & Recorders
Where can I find parts for a JVC C-1455CA tv?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Sep 29, 2015 | JVC Televison & Video
Telefunken TLC037fhda no sound picture good
take a look at the speaker,use a multimeter see if the speaker have the rated resistance.( eg .8 ohms) if speaker bad replace if.if speaker good. see if your audio amp is getting power (multimeter needed) set to d.c volts.have voltage then look for the input pin that brings audio into the amp,use a 16 -32 ohms speaker across gnd pin and input pin(bring volume up hi on tv) if audio replace audio amp.
(also look for cold solder) on p.c board before replacing amp.
May 23, 2014 | Televison & Video
No sound from the audio speakers
by audio speakers i assume you mean speakers that you plug INTO the tv, some tv's if you plug in speakers they play instantly but some tv's you might have to go under the menu ON the tv so just bring up menu, click on audio, and it should say some where to swith to external speakers then while with speakers pluged in select external speaker (or whatever your tv might say) and i hope that solves your problem, thank you, jamie.
Dec 15, 2012 | Sony BRAVIA KDL-46EX720 46" 3D LED-LCD TV...
JVC RX-8030V, I have TV Audio hooked to back of receiver (TV Audio In) but I cannot get any sound from TV to Receiver, I can hear the speakers humm when I plug the cables in but then it goes away and no...
First of all, it is bad form and potentially dangerous to be changing cables with speaker power ON. Second, IS the unidentified TV passing audio out those jacks? Its own audio menu and controls may be between the sound and the jacks.
Oct 02, 2011 | JVC RX-8030V Receiver
Ipurchased an LG plasma tv and now a JVC dvd/cde home theater. The dvd works and I get surround sound but the tv does not come throught he sound system. The JVC folks say I have it set up incorrectly but...
You may have to set a speaker preference for the TV. Look in the Audio section of the Setup menu to see if you can turn off the TV speakers and route the output through the jacks
Oct 06, 2009 | Audio Players & Recorders
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
No sound
possibly speakers of in audio menu? or speaker switch at back of set?
Apr 21, 2008 | JVC AV-27D305 27" TV
Jan 21, 2008 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
162 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
