Question about Bang and Olufsen Beocenter 9300 Shelf System
Why does the cd door on my BeoSound 3200 not open?
The cd door on my BeoSound 3200 will not open so I cannot load a cd. Any assistance greatly appreciated.
  • Hadi Wibowo
    Hadi Wibowo Dec 27, 2016
    The rubber band that connect the motor and the door broken. You need to replace it. Find the broken rubber band, go to electronic component shop, use the broken ruber band as reference.
    Problem Solver:
  • 8 Answers
4 Suggested Answers
  • 122 Answers
SOURCE: fixing beosound 2000 door
clean/lube door guide rails
Posted on Jan 11, 2010
  • 122 Answers
SOURCE: HI THERE I OWN THE BEOSOUND 3200.... THE GLASS
this is a fiddly job even for someone who has done it before.expect to pay around an hours labour.£60 £70
Posted on Jan 22, 2010
  • 122 Answers
SOURCE: Bang & Olufsen BeoSound 2000 door doesn't open (disconnected)
Push the door to the left this normally engages the door to the mech.it is designed to detach if the door is jammed or too stiff to move.Cleaning of the guide rail and door carrier is usually the cure.this can only be done properly be removing the central cd clamper and control panel assy.
Bang and olufsen beosound 3000 does not read cd and loading stops. Can you help? Thanks
I never had like that. But "normally" there may be two reasons: CD fault or control board fault. Sometime main control keeps memorized wrong data and (in my Ouverture) CD unit simply is not responding and not loading - standing still. No way to move on except plugging off the power, press CD start on remote with no power, plug in power and try again. It clears bad data. I suspect it happened few times when I stopped CD player by remote or local main switch off.
Aug 19, 2014 | Bang and Olufsen Beosound 2000 Shelf...
I HAVE A BEOSOUND 3200 THAT I HAVE'NT USED FOR YEARS..I WANT TO HOOK IT UP TO MY AMPLIFIER TO PLAY THROUGH THE SPEAKERS CONNECTED TO AMP..HOW DO I HOOK UP TO THE AMP?
take the output from the beosound and place it to the input of the amp and then switch it to the front of the amp. eg. if the put the beosound output into cd, tape, phono, aux or game etc you must highlight it to the front of the amp so the sound can come through.
May 01, 2014 | Audio Players & Recorders
Bang & Olufsen Beosound 3200 CD Door won't open
Could be the PCB9 light and motor control have the problem its on the upper left side of the player.
Feb 25, 2013 | Audio Players & Recorders
Hello is there a way to connect a sony 52EX700 to a beosound 3200 system? regards Laurent
You can use the aux out or get yourself a beolink cable.
However the 3200 is not surround sound capable it was designed for audiophile CD enthusiasts, My advice is to get a home theatre system and leave the 3200 for those special music moments.
Aug 14, 2010 | Bang and Olufsen Audio Players & Recorders
My old bang&olufsen beosound 2000 is working except the cd doesn't want to play - it loads and even moves but quickly opens back up.
My old bang&olufsen beosound 2000 is working except the cd doesn't want to play - it loads and even moves but quickly opens back up.I have the same problem. I don't understand. Cristian
Jul 07, 2010 | Audio Players & Recorders
How do I change the light bulb(s) on a BeoSound / overture
Remove glass doors,black panels 8 screws lift up cd clamper and detatch from drive bar at top l/h corner.Lift operating panel to gain access to cable connector behind keypad,this should provide enough room to work on lamps.
May 06, 2010 | Bang and Olufsen Beosound 2000 Shelf...
Dec 31, 2009 | Bang and Olufsen Audio Players & Recorders
Glass door will not open and cd player will not rise to place cd in position
Glass door and cd clamper operated by same motor belt and mechanism,remove l/h sp. grille (2 screws) and this mech is easily visible.
Nov 27, 2009 | Bang and Olufsen Beosound 2000 Shelf...
Owners manual
Below are links to the manuals. I also have this system with the original manuals.
Basically, press the "load" button to open up the CD mechanism, put a CD on the spindle, and press load again to close the CD mechanism. Press the "CD" button to start playing the CD. Page 12 in the User's Guide has instructions on configuring the radio presets.
http://www.beocollectors.com/usermanuals/beosound4000.zip
http://www.beocollectors.com/usermanuals/beosound4000guide_en.zip
Dec 18, 2008 | Bang and Olufsen Beosound 4000 Shelf...
102 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
