Question about Salter #1200 LCD Wall Mount Aquatronic Kitchen Scale and Clock
How to change digital clock on scales - Salter #1200 LCD Wall Mount Aquatronic Kitchen Scale and Clock
How do I reset my clock in my 2002 s type Jaguar?
Press and hold the mode button with the radio on. This will bring up a screen, select 12 or 24 hour scale, depending on what your preference is...press mode again...now enter the time with the keypad, using a "0" before the hour,if the hour is not in double digits. Press mode again...Now use the # button to change from AM to PM. Hope this helps!
How do you set the clock on 2003 jaguar type
Jul 10, 2015 | Cars & Trucks
I have a health o meter scale that shows kgs not lbs how can i fix that?
There must be a button where this can be changed in the same way as when changing from 24 hour clock to a pm/am clock.
You can also use arithmetic.
1pound is 0.453 kgs.
The thumb rule is two pounds to a kilo plus a bit, or 0.906 kgs
Good luck
kolbrun
May 30, 2012 | Health-O-Meter Health & Beauty
On my "Ideaworks" wireless electronic display
After playing with the remote on this scale for about 30 minutes, I finally found out how to change this display from kg to pounds or stones. Since this scale doesn't come with an instruction manual, I know a lot of people are totally lost. OK, first click the user button once, so that the weight and goal weight show. Then hold down the clock/set button. After a few seconds the kg on the screen will start blinking. Then use your arrow buttons to switch to stones, then to pounds. The lb will show at the top of the display above where the kg was. You can also set your goal weight by pressing the set button and scanning through after setting the lbs setting. Hope this helps!
Aug 22, 2011 | Jobar International Ideaworks Remote Read...
Just purchased the Ideaworks Large Capacity Bath Scale with infrared receiver and I can't get it to display the weight. The receiver seems to be working (can set clock, lbs, etc. . . ) but nothing happens...
If it's any consolation, my Jobar/Ideaworks JB5413 has developed the identical symptoms, although occasionally it will start working briefly. Batteries are new, and no corrosion in the battery compartments. I am thinking about just junking this nicely styled scale; what a shame.
Apr 22, 2010 | Jobar International Ideaworks Remote Read...
Setting the clock on salter scale model 5007
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h option.press the g-oz key to set the time.
And your done.
Oct 06, 2009 | Salter Bakers Dream Aquatronic Kitchen...
Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Aug 25, 2009 | Health & Beauty
I have a chefmate digital kitchen scale and I do not know how to reset the clock.
I have the same problem. The only way I can figure out how to reset the clock is to take out the batteries and put them back in at 11:59 pm or midnight. Replacing batteries reset the clock to 12:00 am. So if you do it at midnight, you'll end up with the right time. But for the life of me, I cannot figure out how to actually set the clock using the availble buttons.
Apr 13, 2009 | Health & Beauty
How do I set the clock on the Elite Home digital scale
On the display, hit "set" for 3 seconds. The hour setting will blink. Press the up or down arrow to increase or decrease the hour number. Press "set" again. The minute setting will blink. Press the up or down arrow to increase or decrease the minutes. Press "set" when finished.
Nov 30, 2008 | Elite Home Electronic Personal Bathroom...
2002 jaguar x type clock
I found this on a wiki search...it worked for me on my 03 X-Type
"Press and hold the mode button with the radio on. This will bring up a screen, select 12 or 24 hour scale, depending on what your preference is...press mode again...now enter the time with the keypad, using a "0" before the hour,if the hour is not in double digits. Press mode again...Now use the # button to change from AM to PM. Hope this helps!
Sep 08, 2008 | 2003 Jaguar S-Type
Digital scale question
Digital scales purport to measure your body fat through a process called BIA, or bioelectrical impedance analysis. Essentially, it clocks the speed that electricity travels through you. The scale runs a low-level electric current through your body, using your feet as positive and negative electrodes. The current encounters different levels of impedance, or resistance, from fat versus muscle. The scale measures this impedance, and throws it together with other factors (age, sex, height) to come up with your BMI, or body mass index.
Aug 27, 2008 | Detecto 253 Baby Scale Mechanical Infant...
Salter #1200 LCD Wall Mount Aquatronic Kitchen Scale and Clock Logo
55 people viewed this question
Top Salter Health & Beauty Experts
traccie
Level 1 Expert
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
