Question about Oreck XL® Classic Bagged Upright Vacuum
Oreck xl classic won't roll - Oreck XL® Classic Bagged Upright Vacuum
Agent Don
  • 310 Answers
SOURCE: Oreck XL
I would advise you to ALWAYS to FIRST UNPLUG THEIR VACUUM before beginning any service procedure. The motor has 5 wires to the motor as stated in the Oreck owners manual, tow are for the headlights, one is a ground wire, and the other two are for the motor. There are two screws that hold in the Oreck motor and a good suggestion is to use tape the wires leads and mark the wires so that you will not make a mistake as you take it apart and reassemble the motor. That way you will not make any mistakes, whether or not you have wires for a headlight or not, the rules are the same. Also refer to the owner’s manual schematic and the exploded view. Questions? 1-800-989-3535
www.Oreck.com
Posted on Apr 09, 2008
reddevil6
  • 1673 Answers
SOURCE: replace belt on my oreck xl
Either have to take the bottom plate off, or there is a small door with one screw to remove to replace the belt. Then it goes around the motor shaft and then over the pulley on the brush roll.
Posted on May 09, 2008
SOURCE: Oreck XL Classic
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=703827
Oreck XL Classic
posted by balis on Jun 24, 2008
The belt is on properly, however the brush will spin, then stop.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Classic. It sounds like the belt may be stretched out and my needs replacing. The average belt change is every 4 to 6 months and to store the extra belts in a Ziploc bag in the refrigerator. Also check the brushroll, the gray bearing ends with say on either side the words NEW or OLD and both ends need to be identical – new/new and old/old NOT new/old, if the belt and the brushroll are OK then it may be the motor but I don’t think so. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 25, 2008
  • 4 Answers
SOURCE: how do I replace the brush roll on my oreck xl??
Turn the vacume upside down. Remove the 5 screws on the bottom plate. 3 are near the brush roll, and 2 are near the back. Remove the bottom plate. take the belt off the motor end. pull up on both ends of the brush roll. Put new brush roll on making sure that you put both ends to the new position, not old. ( it is marked on one end, and there are marks on the side that goes up so the can match.)(If putting back the old brush roll you can switch to the old position. After a year or two you can switch the new brush roll to the old position.) Put the bels back on the motor shaft and then stretch and start the belt on the brush roll and rotate the brushroll by hand untill the belt is all the way on.
put the bottom plate back on and tighten the 5 bottom screws.
Posted on Apr 24, 2009
  • 121 Answers
SOURCE: Oreck XL hard to push
yes. it might be broken. you will need to remove the 5 screw on the bottom and see if the belt is burned. it more that likly is.
Posted on Oct 16, 2009
Testimonial: "Quick answer and the same thing I found out after I posted from an Oreck repair site. Thanks."
The roller brush on my Oreck XL Classic has only center bristles. Both sides have been worn down to nothing. It is hard to push.Why are the bristles wearing down?
Sounds as if the wheels are collapsed on one side and the brush is harder in contact on one side. In correct alignment the brush should just kiss the top of the carpet causing the bristles to flex a little.
Oreck will fix it for you under warranty;
http://www.oreck.com/oreck-xl-classic-limited-edition-bagged-vacuum/UK2200.html
The XL® Classic Limited Edition is confidently by Oreck®'s warranty and 9-point free service tune-up inspection plan to ensure optimal performance for years to come.
Returns information is here
Returns
Oct 30, 2016 | Oreck Vacuums
I have to replace a motor on an xl classic. The bad motor is out and i do not know exactly where the wires connect on the new one. I need a wiring diagram.
Hi, it's Jeremy from Crucial Vacuum.
Below you will find a link for many different models of the Oreck XL Classic Bagged Upright Vacuum. I hope you find the link useful.
http://www.oreck.com/PUG/76054-01-REV-A-U2251-CLASSIC.pdf
If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
http://www.crucialvacuum.com
May 22, 2014 | Oreck XL® Classic Bagged Upright Vacuum
How can you do a height adjustment on Oreck XL Series vacuum
Oreck makes two different attachments for putting on the bottom of your vacuum to raise it up. They have one for the older Classic styles and one for the newer XL models. This is the only way you can raise the brush on an Oreck.
Jul 18, 2012 | Oreck Vacuums
Oreck XL Classic User's Manual
The manual for the Oreck XL Classic Upright Vacuum U2251 is located on the site below.
Mar 03, 2011 | Vacuums
The roller on my Oreck XL won't roll when it's on carpet.
That means that the belt is stretched. You need to replace it. Here are the belts you need:
Oreck XL Belts
Mar 09, 2010 | Vacuums
Oreck XL Classic
Oreck XL Classic
Go Ahead. Use Us.
Jun 24, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Replace belt on my oreck xl
May 08, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL® Classic Bagged Upright Vacuum Logo
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
