Question about Pentair IntelliChlor IC15 Chlorine Generator Cell Kit
All lights off. checked power supply there is power
Hisense 32k20dw backlight not powering on. Power supply good
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electronicshelponline.blogspot.com/.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Jul 21, 2015 | Hisense Televison & Video
Does a solid green light mean the power supply is ok when disconnected from motherboard and drives, ATX-300-12Z
Not necessarily. The green light usually just signifies power to the power supply. Amazon sells a cheap power supply tester that can verify everything on a power supply from old to new.
Jul 21, 2014 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
No Display, No Response
Do you hear any fans? You may need to open the computer case and look inside to see if you have any led's or fan's functioning. If you do not see any lights on the mother board or working fans, check the fan inside the power supply by looking through the fan guard. If you do not see the power supply fan working, make sure you have the computer plugged into a live outlet, and the power cord is good. Furthermore, look for a switch on the back of the power supply to make sure it is switched to the on position. If you still have no working functions of the computer, go to a computer store like Comp USA or Best Buy and purchase a power supply tester which you may find for under ten bucks. Touch the metal case of the power supply while removing the main power connector of the mother board. Always touch the metal case of the supply to discharge any static, or you could cause immediate or future damage from weakened static sensitive components. Plug the power connector into the power supply tester and make sure all lights light up. If no lights light up, you can check the fuse on the supply if it is external, or you will have to open the power supply to check the fuse. Alternatively, you can buy a new power supply which you will need to do if some of the lights on the power supply checker light up.
If the fans work on the computer and the power led's work then you may have a bad video cable connection, video card, or monitor, which will need to be checked individually. If you hear any beeps, check your manual for the description of the number and duration of the beeps which will indicate bad video or memory sticks.
I hope this helps but you can reply if you have any other questions. I think it could be the power supply with all the storms this time of year which could have killed the Power Supply which is easily replaceable.
Jul 13, 2011 | Computers & Internet
Orange light 3 flashing
Check your power supply cables Your power supply cables may not be fully secured. Let's unplug and reconnect your power supply
  1. Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and the power supply unit.
    Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit
  2. Make sure that all three connections are firmly secured.
  3. Turn your console back on.
Check the light on the power supply. If this solution worked, your power supply light will be green
Dec 29, 2010 | Microsoft Xbox 360 Console
Computer will not turn on....how do I check to see if power supply is faulty? I have power supply removed and have a tester to check for dc voltage etc
I just went through a heap of troubleshooting with power supply issues before swapping psu's and finding this was the solution to my problem. Had a closer look at my psu that was faulty, the green light was flashing on the psu, unplugged all components and thought that I now had a non-flashing green light on my psu, on closer inspection the light was actually flashing very fast so appeared to be an almost solid light...the psu was stuffed so replaced it and no more issues. If your power supply has a green light check to see if it is flashing when plugged into voltage with nothing connected to it. If it is a solid light then it is probably ok.
Jun 16, 2010 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
Three red lights flashing
Three red lights flashing means that there is a hardware fault.
Check your power supply light 1. Turn on your Xbox 360 console. 2. Take a look at the light on the power supply.
The power supply light is located on the end of the rectangular box in the middle of your power cord. If your power supply light is green
Solution 1: Check your power supply cables
Unplug and reconnect your power supply. Here’s how:
Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and from the power supply unit
Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit.
Make sure that all three power supply connections are firmly secured.
Turn on your console.
Before you perform solution 2, I would suggest you to go through following links.
http://support.xbox.com/support/en/us/nxe/kb.aspx?ID=907534&lcid=1033&category=hardware
and
Following link is an interactive troubleshooting link.
http://support.xbox.com/support/en/us/xbox360/hardware/console/troubleshootingconsoleproblems/flashinglights.aspx
Solution 2: Submit a console repair request
Your console needs to be repaired. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: I am a U.S. customerI am a customer outside the U.S.
This solution is absolutely FREE, so please rate and give positive feedback.
Thank :)
May 09, 2010 | Microsoft Xbox 360 Console
Well mainly it is down to overheating, and as you play your games the motherboard flexes ever so slightly and the soldering snaps off and that is when you are left with the red lights of doom.
Step 1: Turn on the console, and check the light on your power supply
The power supply light is located on the black box that is in the middle of your power cord.
Step 2: If power supply light is green, try this solution
Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutions:
Solution A: Unplug your console, plug it into a different outlet in a different room, and then turn it on
This will help determine whether the problem is with your power supply, your power outlet, or your console.
Solution B: Request a replacement power supply
If the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply.
Mar 27, 2010 | Microsoft Xbox 360 Console
3 red lights on
Step 1: Turn on the console, and check the light on your power supplyThe power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution 3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutions 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support
(source: www.microsoft.com)Kind Regards
Mar 23, 2010 | Microsoft Xbox 360 Console
Tree lights in red
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutionsuparrow.gifBack to the top 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support(source: www.microsoft.com)Regards
Nad amp failure
Check fuses mounted near transformer . If blown check output transistor. Also check transistor transistors on small heat sink . they will cause fuse to blow.
Mar 10, 2008 | NAD C350 2-Channel Amplifier
Pentair IntelliChlor IC15 Chlorine Generator Cell Kit Logo
Top Pentair Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Pentair Electrical Supply Expert? Answer questions, earn points and help others
