Question about Hotpoint Aquarius WF000 Front Load Washer
Wf000 flashing light
I have flashing lights. Energy save, time saver and power on/off. Machine is buzzing sound. Please advise of fault.
5 Suggested Answers
gittos73
  • 244 Answers
SOURCE: Hotpoint Aqaurius WF000 - Flashing Energy save and on/off switch
check your pump for any blockages it may not be pumping out fast enough the tomer only gives the pump a certain amount of time to pump all the water out if has got some blockage than clean out and this should sort the problem out always check pockets if this is no help let me know and ill let u know what else it could be m8
Posted on Aug 28, 2007
  • 27 Answers
SOURCE: Wf000
whare the option buttons are if you number them 1 to 5 from top to bottom if led 2 and 4 are flaching this is a time out draining and you will need to check your waste hose for twists traps and kinks also check Filter if there is a user servicable one on the applionce and check plumbing. This is a comman fault and if you get hotpoint out to it even if it is only a day old they will charge for the call out as it is classed as user error or faulty instalation this works on all WF,WD & WT modles with 5 option buttons on the left habnd side the applionces with digital displays will show F-05 insted but it all means the same
Posted on Feb 22, 2008
  • 20 Answers
SOURCE: On and off light and energy save and reduces creases lights flash
Hi Snarey, it sound like your door lock has passed away, you will need to make sure the appliance is unpluged, empty the water out of the drum, and check the vacuum switch which opperates the lock.
Posted on Mar 10, 2009
bozcro
  • 867 Answers
SOURCE: on/off light and energy save lights are flashing
for sure electronic control issue, nothing mechanical. the cpu seems confused, may need new board
Posted on Aug 09, 2009
How do I turn off the time saver option?
You should just be able to press the button. Has the machine stopped working with the START light flashing and the time saver light on? If so, this is an error code indicating a motor fault. Please describe any other lights that are on and if they are flashing or solid
Sep 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
Hi - reference our washing machine WF000G - the energy save light is flashing along with the on/off button and the machine wont run its cycle - can u help?
Do a search on Google using 'diagnostics, hotpoint, flashing lights'. There must be a manual which will identify what this fault is
Dec 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Panafax UF-8000 not responding, energy saver light flashing.
It sounds like the operation panel is bad or has a loose plug.
Remove left and right top screws that hold the left and right panels on.
Wiggle the op panel towards you and up, check the white wire harness.
Good Luck!
Jul 07, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Mar 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Flashing on/off switch flashing energy saver light
I had the same problem with our hotpoint aquarius WT540P , I contacted EMW electronics who told me it was most likley the Computer board. They supply reworked replacedment boards on an exchange basis. I installed the replacement and the machine's been washing away merrily since. Here's a link to there web site. http://www.emwelec.co.uk/ .
Regards.
Nigel
Apr 22, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Wf000
Jan 21, 2008 | Hotpoint Aquarius WF000 Front Load Washer
May 15, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
16 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
