Question about Rheem EcoSense by 7.4 GPM Tankless Water Heater Natural Gas High Altitude
How to clean flame rod/electrodes on Rheem Ecosense tankless water heater Code c7 76 flashing, water is cold and power won't come back on
mrhotandcold
  • 248 Answers
SOURCE: rheem tankless water heater error code C4 13??
check diaphrapm valve or micro/switch best of luck
Posted on Oct 31, 2009
  • 244 Answers
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
Posted on Nov 01, 2009
  • 67 Answers
SOURCE: rheem gas tankless water heater with error code c4 13
problem is inside burner compartment o2 sensor dirty or block..need to have a qualify technician clean it.
Posted on Jul 31, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: rheem tankless ecosense code 11, calls for 3 wc
Sorry to read about your problem, I hope this helps you out.
your WC pressure is fine it needs 3 and you have 5, can handle 8
The gas company adjust at meter, you have other issues
Check gas solenoid valves for open or short circuits.
Ensure igniter is operational.
Check igniter wiring harness for damage.
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY
Posted on Jan 05, 2011
SOURCE: I have a Rheem EcoSense tankless water heater that
1) The best place to find this information in your manual.
Typical Rheem manual in my files shows temperature is adjusted by pressing UP and DOWN temperature buttons on remote.
2) Manual says: Temperatures of up to 140°F
(60°C) for Light duty models and up to 180°F
(82°C) for Heavy Duty models can be
achieved with the MAIN (UMC-117) remote
control and a dip switch adjustment. Only
qualified service personnel should perform
this adjustment. Only factory authorized
remote control(s) should be used.
3) Typical manual shows information on page 22-23. Search pdf for 'temp'
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
4) This information squares with what I heard before that trained service technician is needed to adjust water temperature.
I think Rheem does this since tankless will not achieve that rise in temperature if incoming water is cold.
BTUs put out by tankless burner has limit.
If incoming water is colder than certain temperature, then tankless cannot raise temperature quick enough as water passes through burner.
5) You might also need a tempering tank, to modify cold water in winter:
http://waterheatertimer.org/Tempering-tank.html
6) Suggest you also read the yearly maintenance required for tankless.
For example tankless are prone to lime build up and need to be de-limed each year with vinegar.
Lime build up will certainly affect water temperature.
7) Following 2 links might be helpful for tankless owner:
http://waterheatertimer.org/pdf/Delime-tankless-water-heater.pdf
http://waterheatertimer.org/pdf/Paloma-Tankless-Error-Codes.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 04, 2011
Testimonial: "Thanks for all the links. This is good info."
Error code c7 and 12 on an ecosense natural gas water heater
Before calling service technician, copy following link for ecosense tankless troubleshooting resources.
C7 is communication failure with remote, and C12 is flame failure.
Multiple error codes could mean bad circuit board, loose wire, low gas pressure, or simple communication problem with remote control.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Jul 24, 2012 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I am getting a C2 11 code on my eco sense tankless water heater. There is also a flashing 24, any ideas? Thanks
Multiple error codes can mean PC board failure.
C2 11 is no ignition.
Error 24 is malfunction of operational switch: "press max or mim button on PC board, or replace PC board." On some models, max and mim button can be located just above dip switches, and rotates with screwdriver. See diagram in manual.
Before calling service technician, open following links for troubleshoot resources including error codes, Rheem chat, and possible manual.
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Aug 10, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
We are getting multiple codes. Can someone help us. Last year we got cod c2 11 which we found out we just have to clean the probes in the unit. So we did that yesterday again and everything worked great,...
Rheem, Richmond, Ruud, and Paloma are all the same manufacturer. After about 9 months, my tankless RTG-74PVN started giving me error code 11 and cold water!. I fixed it by cleaning the burner, as shown in this video:
www.howtolou.com/clean-a-burner
Jul 31, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
Have an Ecosense Tankless Water Heater with error code C7. It then flashes to 76 degrees and gives cold water. How do we remedy?
Before calling service technician, open following links for troubleshooting resources and typical manuals.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Tankless water heaters require yearly maintenance.
Many causes for common error codes are covered in the yearly maintenance.
Jul 18, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
How can I tell how many BTU's my natural gas meter is rated to supply? I'm getting an error code 12 on my Rheem EcoSense 9.5 GPM 199,900 BTU Natural Gas Indoor Tankless Water Heater, so I'm guessing the...
I have a Rheem PTG-74XP tankless. I had the same code 12, low/inconsistant gas problem (assumption). In my case the gas (propane) pressure coming in was fine, the reason the flame rods/electrodes would not burn correctly was residue on/in them. It hasn't happened since they were cleaned. Hope this helps, dj :)
Feb 03, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
Our water heater (model # PTG-74PVP-2) is flashin C7 76. THe water is cold. If we turn it off and back on it is hot for a while but then turns off again. We can't find our manual. WHat does this mean?
I have a Rheem PTG-74XP tankless. When the water was turned on the unit would engage briefly then turn off. After (much) troubleshooting, it turned out to be caused by a decrease in the flow of gas (propane in my case). The cover panel had to be removed and the flame rod/electrodes had to be cleaned. I did call for a service tech to do this but in retrospect I probably could have researched enough online to do it myself. The other possibility reported to me (and in my case not the prob) was a lack of consistant pressure from the gas source. Good luck!
Jan 16, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
I am have a error code 72 C4 on a Rheem tankless water heater
Error 72 is Flame sensing Device fault.
Flame rod could need replacement or be out of line, or tankless needs to be cleaned using maintenance outlined in manual.
Read manual.
Open following link for Rheem tankless troubleshoot resources including error codes, parts links, typical manuals:
Oct 25, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a natural gas eco Sense tankless hot water heater.I will turn it on and it will work fine. then I shut it off and if I turn it back on I will get an error code c2 will blink then 11. I will then...
try cleaning your spark rod inside the unit and the other rod next to the spark rod on the side of the unit. Takagi use a emery cloth, rheem brass brush, noritz a emery cloth. but make sure that both of the rods that are in the flame chamber are very clean. It miss reading because of build up on the rods.
Oct 05, 2010 | Rheem EcoSense by 4.2 GPM Tankless Water...
Rheem EcoSense by  7.4 GPM Tankless Water Heater Natural Gas High Altitude Logo
130 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
