Question about Brother HL-5470DW High-Speed Laser Printer
How to print double sided - Brother HL-5470DW High-Speed Laser Printer
Double sided printing
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jul 14, 2012 | HP Photosmart Plus All In One Printer b210
How can I do double-sided printing with my Canon MP460?
Hi there!You printer does not have an automatic duplex(double-sided printing)so you have to make a manual double-sided printing.When you start to print something , in the widow of the printer click on the preferences and look for the option "Print on both sides" or "Manual double-sided printing".When you start the printing the printer will print page page 1,3,5,7..... on the one side of the paper.After the printer finish you have to take the papers and put them back in the printer with the other side of the paper.Then the printer will start print page2,4,6,8,.....If you need any other help please replay!Tghaky for using Fixya!!
Dec 18, 2010 | Canon PIXMA MP460 All-In-One InkJet...
How do i print double sided?
No unless your printer has an add-on or built-in mechanism that allows for double sided printing,
Feb 18, 2010 | Computers & Internet
How to print double sided?
Most hp deskjet printers are not enabled for double-sided printing. This feature is common with laserjet printers. So if you are using a deskjet, please you may to manually print your double sided.
If your printer is a laser jet you will find the selection under your print menu. Press ctrl P (keyboard) and the print menu appears. Click on each tab to see which one is contains the double-sided selection button. select it and print. The tab should be titled "Basic" depending on the your printer.
If your printer is a deskjet, go through this procedure to see if your model is enabled for double-sided printing and enable it.
Sep 21, 2009 | Canon Pixma iP4500 InkJet Printer
Double Sided printing of PDF files
you have to set the printer properties to do double sided printting
Sep 11, 2009 | Canon ImageCLASS MF4350d Laser All-in-One ...
Printing everything double sided
go in youre ip address, log in as admin, chooce print tab and there is a print tab, there is a default options, and choose double printing off
Oct 29, 2008 | Konica Minolta bizhub C250 All-In-One...
Double side printing issue with HP 2420
Try to default on your page setup.
May 23, 2008 | HP LaserJet 2420 Printer
Can the 420CN print double sided pages
There is only a manual double sided printing avaiable:
After the first side was printed you have to turn the page into the papertray again.
Canon bubble jet printers can do double side printing but the back side black print will be mingled through C/Y/M ink!
Jan 07, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother HL-5470DW High-Speed Laser Printer Logo
12 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
