Question about Moen TL3450/3600/3371 Kingsley Handle Tub and Shower Faucet....
No hot water moen exactatemp - Moen TL3450/3600/3371 Kingsley Handle Tub and Shower Faucet....
    Problem Solver:
  • 15 Answers
Your cartride may may need to be changed if you have any damage to the o-rings on your cartridge it will mix the cold with hot automaticlly. this could be caused from a calcium partical getting in the line cutting the o-ring just the smallest little cut in the o-ring will cause this problem if the cartridge has been recently changed. it could be the o-ring was cut in the installation. this is easy to do if stem grease was not used in the insallation.
Posted on Oct 26, 2014
4 Suggested Answers
hessmar
  • 5 Answers
SOURCE: hot water dribbles thru shower head when turned to hot
Replacing the cartridge should solve the problem, the balancing spool is stuck, replacing it will solve the problem. The valve should look like this http://www.moen.ca/shared/pdf/3170pt.pdf . I have unstuck the spools in the past, soaking it in white vinegar will help to remove build up.
Posted on Dec 04, 2008
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
Posted on Sep 03, 2009
motor1258
  • 6674 Answers
SOURCE: moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Posted on Dec 29, 2009
I've been given an old (10+ yrs) Moen shower control valve that I want to use (it does apparently have pressure balancing built-in), but don't know which side is hot and which is cold. Does Moen always...
Moen and all shower valve manufacturers follow american federal guidelines. Hold the unit in your hand with the handle facing you - the left side is the hot water inlet and the right side is the cold water inlet.
Nov 25, 2010 | Moen & Posi-Temp Single Handle Shower Or...
My moen single lever faucet problem is no hot water. The water is warm at most and when you turn it off and on it goes to cold. The faucet is only 8 months old. The only way to get real hot water is to...
The hot side sounds like it has some junk in the hot side blocking the hot water from coming through check hot water line to make sure that it is coming through down below and if so you would need to take it apart and try to get the junk out of that side of the faucet.
Nov 14, 2010 | Moen 7437 Chateau Single Hole Kitchen...
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
My Moen Posi-Temp tub valve runs only very cold or very hot. whats wrong?
Your Moen valve is equiped with an anti-scald device (as part of the valve cartridge) which prevents someone from getting scalded by hot water if there's a sudden demand for cold water, i.e. a toilet flush, washing machine filling, etc. Fortunately Moen stands behind their products and will provide a new cartridge.
Contact Moen and describe your problem.
Jan 26, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Moen single handle kitchen faucet, Hot water and
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Moen T2113 shower faucet no hot water
Aug 22, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Hot water faucet turns wrong direction
You have a cold side valve part assembly in a hot side. Order for free@
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Apr 03, 2009 | Moen Plumbing
Replaced a moen cartidge and now the water is not hot in shower
make sure when you turn on the hot and cold shut off valves all the way and turn the moen on after that. Some times I would get that problem if I turned one(either hot or cold) off then tried the shower.
Feb 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Hot water dribbles thru shower head when turned to hot
Nov 17, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Moen TL3450/3600/3371 Kingsley Handle Tub and Shower Faucet.... Logo
66 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
