Question about Kyocera Mita Office Equipment & Supplies
Kyocera km3050i error code C6000
SOURCE: Have error: C6000 on Kyocera
Have Kyocera FS-1118MFPF that is coming up with Error C6000. Can we fix this ourselves
Posted on Sep 25, 2008
  • 40 Answers
SOURCE: Error C6000 is showing, can you tell me if I can fix myself or call for service.
In some cases you can reset the C 6000 - when is a false error.
try this:
1. Go to Menu/System and browse till you see
"Service".
press and hold: # START ENTER
The "Service" will go away and browse to "Maintenance".
2. Press ENTER to go in maintenace mode - the display change to Maintenance mode.
3. browse to 0163 and press ENTER - reset fuser
4. pick EXECUTE and press ENTER
5. turn the copier OFF, wait 20 seconds and power up the machine.
If C 6000 goes away it was a false error if NO ...try again and if the C6000 persist means the thermal fuse it is blown so you have to replace the fuse = call for service.
Posted on Jan 12, 2009
rylee_smith
  • 8619 Answers
SOURCE: c6000 error code
Hi
Error C6000 is displayed when your machine fails to reach the correct temparature at a specific time.
This is a Fuser Unit Problem, try to reset it by--
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
If the reset doesn't work then get your unit checked for fuser unit and fuser unit heat issues.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 09, 2009
SOURCE: Kyocera Mita 1500 Error code 6000
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Henry
Posted on May 26, 2009
SOURCE: how do you reset a C6000 error on a Kyocera Mita
it is a error on your heater unit. it sometimes comes with power fluctuation. you need to enter service mode, it is a dangerous place to be if you do not know about copiers and their settings and i advice you to rather get a trained tech to do it for you.
to reset this error, do the following, but please take care and DON'T fiddle around.
type in 10871087
the machine will display U000 and be in maint. mode
type in 163 (this is the code to reset the error)
press ok/print
on some models it ask for "execute", select it if neede
the machine will now restart and be ok
** if however the machine restart and the error occure again, there is a deeper problem that need to be attended by a trained tech
Posted on Jan 19, 2011
How do I reset xerox C6000?
C6000 km-1820.3gp - YouTube
? 0:55
www.youtube.com/watch?v=Ef0WwaTXgtQ
Oct 6, 2010 - Uploaded by natasmanda01 Cancelamento dos codigos de erros c6000, c6400 e c6020 da kyocera ... HOW TO RESET AND HARD RESET KYOCERA HYDRO XTRM ...
Printer Resetter: Solving error C6000 on Kyocera Mita printers
pritner.blogspot.com/2013/08/solving-error-c6000-on-kyocera-mita.html
Aug 8, 2013 - c6000. error. Error Message Check Ink U041 ยท Xerox WorkCentre C2424 DADF Error ... SSC Service Utility Software to reset Epson printers.
Oct 19, 2015 | Xerox Phaser Office Equipment & Supplies
How to repair fixing unit of copier machine it replies Error C6000
Hi
I assume that your printer is a Kyocera Mita and probably one from their KM range. I proceed on this basis.
It is possible to reset this using U163 in Maintenance Mode to reset the code. If the error still persists it is to do with the fuser unit. I found many error codes for many printers and the particular page of relevance to you is here:
Error Codes Kyocera Mita KM2540 Code C6000
It is for the KM2540 but you can change models easily using the drop down menu in the centre of and near the top of the page.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 03, 2014 | Office Equipment & Supplies
KYOCERA FS 1118 MFP SHOW ERROR CODE C6000 WHAT B I CAN DO
replace the fuser will fix that. Or if you want to stip it down check the lamps and if their ok change the thermistor and thermostat. But your better off just replacing the whole unit
May 04, 2014 | Kyocera FS-1118 Printer
Kyocera 2050 errore code c6000 problam
Error C6000 is a fuser error.
Solution 1:
  • Turn it off
  • Wait 5 minutes
  • Turn it on and the code will be clear.
Solution 2:reset the fuser
  • First open top cover then turn on power.
  • press system menu/counter
  • arrow down to service
  • press and hold start, # then enter keys
  • arrow down to maintenance
  • press enter
  • arrow down to Sim 163
  • press enter
  • select execute
  • press enter
  • turn off power then back on
Solution 3:
  • You need to replace the fuser
Sep 25, 2013 | Kyocera Office Equipment & Supplies
C6000
http://fix-your-printer.blogspot.com/2012/05/solving-error-c6000-on-kyocera-mita.html see this
Feb 17, 2013 | Kyocera TASKalfa 180 Copier
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
My kyocera taskalfa 180 shows an error.call service c6000.what should i do
Jun 30, 2012 | Kyocera TASKalfa 180 Copier
Henry
May 26, 2009 | Kyocera KM-1505 Copier
Have error: C6000 on Kyocera KM-3050
Aug 02, 2008 | Office Equipment & Supplies
10 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
