Question about Exercise & Fitness
Eurosport T-1160 manual
Need to know how to lubricate belt and what to use.
How to configure dlink dap 1160
Ashraf, you could contact the manufacturer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info.
DAP 1160 Wireless Access Point
http://www.dlink.com/-/media/Consumer_Products/DAP/DAP%201160/Manual/DAP_1160_B1_Manual_v2_00_EN.pdf
How to factory reset your Link router
May 06, 2016 | AccessData Password Recovery Tool Kit (ftk...
Why does my treadmill stick when I'm running
Vernon, Time to lube the belt,Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DIY How to lubricate your treadmill belt
Treadmill Belt Lubricant
How to Lubricate Treadmill
Treadmills To lubricate or not to lubricate Insights
Apr 04, 2016 | Nordic Track Exercise & Fitness
My dap-1160 doesnt work. only power light is on
Try to unplug power cord and wait for 20 seconds then plug the power cord back in. If still the same problem your access point is no longer functioning and you may need to call your provider to help you with further troubleshooting or there may be a need to replace your device.
Feb 26, 2013 | D-Link DAP-1160 802.11g Wireless G Open...
I have a nordictrack 2500r treadmill and when i run on it the belt sticks to the board underneath. Any assistance would be very much appreciated thanks
hi,
Your treadmill walking belt need lubrication. For lubricating use Teflon silicon lubricant. To know how to lubricate the treadmill belt watch the following video.
OK
Aug 20, 2011 | Exercise & Fitness
The belt on my running machinet207 is sliping when you stand on it
Jo,
The most common cause of belt slippage is lack of lubrication. Most treadmill belts use lubrication on the underside of the belt to reduce friction between the belt and the platform. This helps the treadmill glide along smoothly under the weight of a person. If your belt is lacking in lubrication, it can catch on the treadmill platform. Apply lubrication every few months to the underside of the belt to prevent this from occurring.
A petroleum or silicone based lubricant is recommended, and most easily applied in a spray can. Simply lift up the belt about midway along the platform and spray a small amount of lubricant underneath from about the middle of the platform width to the closest edge. Repeat from the other side. Apply lubricant sparingly...it can be messy.
Next, turn on the treadmill and let it run for a minute, then check if the belt still sticks. A little more lubricant may be necessary.
Hope this helps.
Regards,
DIYpro
Apr 27, 2011 | Sport & Outdoor - Others
I can longer watch eurosport player as sliverline is blocking it. i have tried several times to downlot it fails as silver line but it fails every time with afinal comment extraction failed requires...
I am GLAD to HELP YOU!
If Silverline has stopped to broadcast EUROSPORT I'd suggest you to do something else instead.
Just access THIS website and you will be able to watch EUROSPORT NEws and EUROSPORT Live...
You may also try JLC Internet TV to download and to install on your computer [take it from HERE] or you can also try [for FREE] the ZIGGY TV from HERE.
My best regards!
Don't forget to RATE...
Apr 18, 2011 | Computers & Internet
I have an HP Laserjet 1160 that I need to know the procedure to determine the current page count.
Hi, you will need to use the manual for help.
Download manual from below link:
docstoc.com/docs/8784607/hp-laserjet-1160-1320-series-printer-manual
Hope it helped.
Take care..
Nov 08, 2010 | Office Equipment & Supplies
I was given the AT&T model 1160 from a friend who didn't want the phone, but there is no manual. The manual on line does not answer all questions, even simple ones like how to delete messages; how are...
This is the manual for your phone,
At&T Model 1160 Manual (You can download it or either read it online)
you will find the notes on how to delete messages on page 34.
Good luck.
Thanks for using FixYa
Jul 29, 2010 | AT&T 1160 2.4 GHz Cordless Telephone with...
It keeps shuting down
If your on it and the duration is every 15 min then the unit needs to have lubrication applied between the belt and deck with a silicon base lubricant. If that does not fix the problem then you may have damage the belt and deck and they need to be replaced. Since not knowing the manufacturer' name refer to your owners manual for contact info
May 04, 2010 | Proform Crosswalk 500 Treadmill
What should I do if the treadmill walking belt slows while in use?
Sounds like your walking belt is starting to get worn,.or you need to lubricate the walking belt. Try applying a silicon lubricant, or other lubricant called for in your manual, to the bottom side of the walking belt, and the surface it contacts. ( not the drive roller).
Jan 28, 2010 | Exercise & Fitness
Exercise & Fitness Logo
64 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
