Question about Harman Kardon CDR2 2-Disc CD Recorder
How to replace belt on yamaha cdc 665 - Harman Kardon CDR2 2-Disc CD Recorder
How do you replace the belt drive in the Yamaha CDC 615?
The drive belt on my CDC-615 stretched out this year too, and needs to be replaced. Unplug the CDC-615 from power. Remove two screws on the left side of the housing, two screws on the right side of the housing, and one screw from the middle top of the rear panel. This will allow the top panel to be removed.
Temporarily re-connect the CDC-615 to power and power it on. Press the "PlayXchange" or "Open/Close" button, which will drop the laser pickup/play head and spindle, and start the open/close motor. Power the CDC-615 down while the motor is running, to leave the laser pickup/play head and spindle in the "down" position. You should now disconnect the CDC-615 from power once again.
From here, you can simply push on the CD tray from behind, until it's in the fully open position. This will reveal the drive wheels (one large and one small pulley) just beneath the tray on the left side, with the tray facing you. This is where the replacement belt goes.
Reverse the steps to put it back together.
Oct 02, 2012 | Yamaha CDC-615 Natural Sound Compact Disc...
CDC-735
Part Number VQ776900. I got it online for 99 cents but other places can be up to 7-8.00 dollars. I removed 5 screws on the sides and rear of the case. Took case off. Press the open button and help the drawer open with your hand while the motor tries to. Then remove old belt with pliers or paper clip, etc.
I did not take anything apart on the inside to replace the belt. Push the belt into the player over the larger wheel and then I pulled the belt with a paper clip over the smaller drive wheel.
Mar 17, 2012 | Yamaha CDC-755 5-Disc CD Changer
Need drawer belt for Yamaha CDC-805 CD changer - the one needed that opens and closes the changer's door - not sure where to get it or the part number. I thought I ordered the right one and got the 'drive'...
Any decent repair shop should have a large supply of replacement belts. The Part number isn't necessary. Just take the old one in and get a new one just 2mm smaller than the original. Some repair shops won;t sell them because they don't want you repairing your own property but a decent shop should sell you one.
Apr 07, 2010 | Yamaha CDC-745 5-Disc CD Changer
The disc tray of my Yamaha cdc-745 CD player does open properly.
It's the belt inside the machine - open tray and look in front left side and you will see it. Easy to change out with new one.
Dec 13, 2009 | Yamaha CDC-745 5-Disc CD Changer
CD tray is not moving in and out easily. Grinding
unplug the unit and open it. the tray is usually controlled by a belt driven by a motor. look and see if the belt is broken. Hopefully yours is not driven by gears.
Oct 24, 2009 | Yamaha CDC-665 CD Player
Good day - I moved for my work and upon
First clean the laser head with a Qtip and alcohol. It gotta be perfectly clean, so wipe with fresh brand name qtip and make sure there is not a single dust particle on it. You gotta remove the cabinet with star screwdriver. Your beam might be tired. First try with the clean up! Unplugg before opening!
Oct 12, 2009 | Yamaha CDC-665 CD Player
Harman Kardon CDR2 2-Disc CD Recorder Logo
271 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
