Question about Frigidaire Dishwashers
Dishwasher wont completely drain and turns off
The dishwasher shuts off near the end of the cycle with water still in bottom. The display goes black
  • Official Brand Answer
  • 2,267 Answers
Good Morning Friend,
I understand that your Frigidaire dishwasher shuts off near the end of the cycle, leaving water in the bottom of the tub. I also see that the display is going black. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 20-30 minutes. When power is restored, run any cycle. If you are still noticing your dishwasher shutting off towards then end of the cycle and water being left in the tub, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to shut off and not drain. Hope this is helpful.
-Best regards-
WP
Posted on May 16, 2014
  • 183 Answers
SOURCE: shu9915uc dishwasher wont drain
it should have water just below filter tray, if it does not actually empty then you have a blockage ,remove left side panel to gain access to drain pipe and side chamber. Regards Engineer
Posted on Aug 05, 2007
  • 209 Answers
SOURCE: Water doesn't drain
simple one this, just clear out the waste pipe and the inside food filter and the outlet pump, also check the outlet where the pipe goes (under the sink?) its a simple blockage somewhere, if i have helped rate me, and work safe remove the plug etc
Posted on Sep 16, 2007
aborcass
  • 2651 Answers
SOURCE: dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
  • 530 Answers
SOURCE: Kitchen aide won't drain
look in your air gap first make sure there is no debrie in there this will make you dishwasher drain really slow.
Posted on Apr 14, 2009
SOURCE: Asko D3100 dishwasher wont drain completely
I think I see the problem based on "futureloginn"'s highly rated solution. You have a dishwasher. You need to stop washing clothes in it.
Posted on Aug 21, 2009
Why will my dishwasher Electrolux model #EIDW5905JS0A, not drain completely at the end of its cycle.
I understand your Electrolux dishwasher, model# EIDW5905JS, will not completely drain at the end of the cycle. It is not normal for water to remain in the bottom of the tub at the end of a cycle. If water remains in the bottom of the tub at the end of a cycle, the dishwasher may not be draining properly. Please follow these troubleshooting tips:
    1)If unit is hooked up to a garbage disposal, make sure the disposer is empty.
    2)If unit is hooked up to a new food waste disposer, check to see if the "knockout" plug located inside the disposal inlet has been removed.
    3)Check to see if drain hose is kinked.
    4)Make sure cycle is complete, not in a pause.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jul 03, 2014 | Electrolux EIDW5905JS Dishwasher
Why does my dishwasher not drain completely at the end of its cycle.
    -Best Regards-
    WP
Dishwasher won't drain at the end of the cycle
Whenever an appliance does operate its pumps/valves heaters correctly for part of a cycle then doesnt at another point, it is a problem with the controller of the sequence in the cycle.. On older devices this can be a rotating knob that slowly runs to end of cycle triggering events as it turns, by tripping blade switches near the rotating item. On these the switch trigger points can be inspected and sometimes repaired. On newer items the cycle is controlled electronically, and you have to replace the whole control unit, which is usually a large expensive part that includes the display and all buttons. Try getting a used control unit from Ebay and swapping it out, or consider replacing the whole appliance.
Dec 14, 2013 | GE Dishwashers
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Water left in bottom of dishwasher after cycle
a little water is supposed to remain in bottom so that pump will not lose prime
Nov 07, 2009 | Dishwashers
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water doesn't drain
Sep 16, 2007 | Kenmore 24 in. 15173 Stainless Steel...
Help Please
REMOVE THE LOWER DISH RACK. MAKE SURE THE SPRAY ARM IS TURNING FREELY AND SEATED DOWN SECURELY. MAKE SURE THE DRAIN LINE IS NOT PLUGED. IT HAS A WATER LEVEL SAFEY SWITCH ... I9F THE WATER IS NOT DRAINING ON THE RINSE CYCLE, THE WASHER WILL SHUT OFF IN THAT CYCLE. WHEN IT STOPS. SEE IF THERE IS ANY WATER IN THE BOTTOM ... THERE SHOULD BE NO WATER.
Apr 29, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
160 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
