Question about Danby 7 cu. ft. / 198 liter Chest Freezer Diplomat DCF718W
Electrical cord missing
Gruond wire color is?
  • 111 Answers
Green
Posted on Jun 23, 2009
How do i connect the wires on a westinhouse Freestyle upright freezer thermostat...ther is a five pin plug and it has the green earth wire connected but the ...blue .. brown..black..orange and red are not...
I'd be looking for a wiring diagram on the back of the unit or inside the bottom rear cover. The wire colors and numbers on the thermostat would guide on where to connect what
Feb 04, 2015 | Freezers
Will not turn off. Thermostat control clicks but refrigerator continues to run in the off position and therefore will freeze everything inside.
Check for a small wire sometimes copper color that ends in a small bulb in the refrigerator. Then check to make sure this sensor is not unplugged from its source. This if the thermal sensor that measures temp in the refrig
Nov 04, 2013 | Haier HSA04WNCWW 3.9 Cu. Ft....
I have a haier household freezer model #hncm035e replacing thermostat controller that connects to temperature control and two lights one red for power and one green for running. I do not remember how wires...
I could only find a diagram on a you tube video. Look for Haier Freezer Repair posted by marcibm1. He took a picture of a freezer wiring diagram just like yours only it is a bigger cu. ft. Yours is 3.5 and his is a 7.0. After you study this, if you still have issues, let me know. First thing is to determine what wires go to the indicator lights. Usually the large black wires are power in and out of thermostat to compressor. Take your time and study the diagram. Let me know if I can be of any further help.
Mar 07, 2017 | Haier Freezers
How to fix a Kenmore chest freezer model #255.19502010
Kenmore model 255.19502010 seems to have this problem where it will not get cold anymore, but it is a $12 solution and and easy wiring job. Easy like if you know colors and how to plug things in you should be able to do it. Get a Supco 3 n'1 Start (model RCO410) for a 1/4-1/3 hp compressor on ebay or Amazon. This one device replaces 3 different components (relay, overload and start capacitor) that all have a tendency to fail. When it arrives, make sure the frezer is unplugged, remove the metal panel on the side of the freezer. You will see a large black orb almost the size of a football, that is the compressor. On the left side there is a black plastic box that covers the connections on the side of the compressor. Open that up and you will find another black plastic thing plugged into the compressor that has a bunck of wires plugged into it. Pull it loose of the compressor by pulling straight back or gently prying it away with a flat screwdriver. You will see that it is plugged into 3 metal prongs that stick out of the compressor. You will see that all the wires go back to a Cylinder shaped device about 1.5 inch diameter and about 5 inches high it is secured to the bottom rail with a single bolt. Remove the black cylinder and all other pieces that were plugged into the compressor. You should be left with a white and black wire coming from the dial selector on the front. Follow the directions on the package of the SupcoBy connecting the white wire to the lower left prong on the compressor, the Black wire to the top center prong and the red wire to the bottom right prong. Connect the other 2 black wires to the black and white wire coming from the dial with the enclosed wire nuts. Put the new 3 in 1 next to the compressor andplug in your freezer to test. If it gets cold then unplug it and secure the new 3 n1 with a ziptie, duct tape' screw' or some other way (do NOT screw into the 3 n 1 just through the hole in the top.)
If this does not fix your freezer then put it on craigslist for a fermentation chamber for home-brewers and home wine makers because your compressor is probably shot.
One note: while I was repairing mine I took the dial thermostat out and int eh process unplugged one of the connection. The first time I plugged in my freezer it did not turn on but the green light was on. If this happens to you inspect all the connections and make sure they are on tight.
Feb 07, 2013 | Kenmore 5 cu. ft. / 142 liter Chest...
Fan runs but the compressor does not run no
While moving the unit you may have jammed or budged the start capacitor which is keeping your unit from turning on. It is located in the back of the unit near the compressor it is oval shaped and silver in color with two wires running out of it. Get the number off of it, go online and search for beverage-air commercial freezer parts. You will need to have the model number to make sure that you get the right parts. Please rate
Jun 03, 2010 | Beverage-Air 11.8 cu. ft. / 334 liter...
Compressor runs but internal fan isn't working, switch appears good what do I need to check regarding the fan?
Check to see if there is correct,complete power to the fan. If not, look for a fan delay that may be attached to the evap. It comes in many configurations. It may have two or three wires going to it. They may be two black wire or 3 wire of different colors. Power goes to the fan thru this device. It may not be working or the evap not getting cold enough to activate it. I will need model and serial to help more.
Let me know what you find.
Jun 01, 2010 | Traulsen 24.2 cu. ft. / 685 liter...
Pulled out wires from compressor on a servis freezer, r134 need awiring diagram to replace wires
Most of the time the compressor reads left to right Start common run. Black is common red is run the other one may vary in color. Rus
Nov 21, 2009 | Freezers
My 10 year old whirlpool side by side just stoped cooling. The fan is running but it's not cooling. What could be the problem?
I would check the relay/overload on the compressor. Pull the unit out and unplug it. At the bottom of the unit in the back remove the cover. Looking at the compressor, on the left side you will see wires. Remove the clip holding the start device in place. Remove the start device. They are usually white or a cream color. Shake it. If it rattles replace it.
Oct 14, 2009 | Freezers
Wiring diagram for danby thermostat freezer
Doesn't matter thermostat is just a switch operated by temperature.
Jul 10, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
New fan light running continuosly
lets see if i can help you out here, okay . Red is your hot power wire, Green is the ground which is screwed to mounting plate, black is negative, meaning no power.... connect your wires by color Red to Red , Black to Black , And if there is a green coming from the ceiling connect to mounting plate of fixture or vise versa. Remember to use eletrical scew caps, on all connections and do not leave any wires uncovered. Basically all your doing is a seperation of a wire from wires as you seperate a wire cap it off. then move to the next set and do the same. red to red black to black green to mounting plate . YOU WIL NOT BLOW ANYTHING UP IF THERE IS A WRONG CONNECTION, if all wires are of color follow these steps, if no color switch one wire try switch and vise versa YOU can do it
Jun 02, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Danby 7 cu. ft. / 198 liter Chest Freezer Diplomat DCF718W Logo
80 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Victor Nwachukwu
Victor Nwachukwu
Are you a Danby Freezer Expert? Answer questions, earn points and help others
