Question about Asko Dishwashers
Doesn't advance through cycle
Knob does not keep turning. will keep running at one stage unless manually advanced
futureloginn
  • 734 Answers
SOURCE: Washer won't advance from cycle to cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never
advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace
the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates,
drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Posted on Dec 12, 2008
SOURCE: Dishwasher won't cycle
Sounds like you need a new timer. Costs about $50 - $60. I had the same problem. The knob now turns. Hope this helps.
Posted on May 21, 2009
  • 10865 Answers
SOURCE: Dishwasher stalls
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Posted on May 31, 2009
erpaalai
  • 999 Answers
SOURCE: Kenmore Dishwasher 587.15163401 knob stuck mid-cycle
See if it is stuck on a water heat cycle. if the heater circuit or the thermostat is not working properly it will continue to run looking for a rise in temperature. If these are in working order the timer it self could be sticking and not advancing.
Eric
Posted on Oct 23, 2009
Testimonial: "Thanks for the help! We were able to run a normal cycle successfully without the timer catching!"
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Posted on May 25, 2010
DWSR483EAWW GE Dryer doesn't turn off when set to "Optimum Dry"
Does the timer advance to the end or does it stop advancing in the middle of the cycle?
If the unit does advance to the end on timed but it won't advance on auto, that means your cycling thermostat isn't triggering. First, make sure your vent is cleaned and the best way to do that is just run a cycle without the vent hose connected to the back of the dryer to see if things change. If your dryer still won't dry properly, then the cycling thermostat will need to be replaced because it's not cycling properly.
Try it on the timed cycle. If it doesn't advance, then you have a bad timer and the timer will need to be replaced.
The cycling thermostat is mounted to the front of the blower wheel housing.
Here is the timer if it is found bad.
Here is the cycling thermostat if it is bad.
Keep me posted!
Nov 30, 2012 | Dryers
Kenmore model 110.24642300 will not cycle through wash cycles...will stay stuck in wash cycle until the knob is manually turned to rinse/spint/etc. Would this be a bad knob or timer or both? Thanks!
Start a cycle and remove the knob. If it still stays in agitation mode and won't advance to the spin, then you have a bad timer, or no power to the timer motor(very unlikely). If your washer goes through the cycles with the knob off then you have a bad timer knob. I have seen stripped knobs causing the timer to bind up and not advance. Good Luck Appliance Specialists
Dec 31, 2009 | Washing Machines
The Timer Knob on my Maytag Dryer does not move. The drying just goes on and on unless I notice and stop the dryer.
While the dryer is turning slowly advance the timer knob to the end of the cycle. The dryer should stop. It sounds as if the timer motor has died or is not being powered for some reason and is not advancing the timer.
Nov 12, 2009 | Maytag Clothes Dryer Almond Timer Knob...
Eric
Oct 23, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher get stuck and will not advance on its own. It does rinse and drain if I manually advance the control knob.
Without a model number I can't direct you to the exact replacment part you need. However, it would appear, based on what you've described, that the timer motor is faulty and should be replaced.
Since you can manually advance the timer/cycle knob and the dishwasher will function at each stage of the various cycles, it can only be the timer that is bad.
You can go to www.searspartsdirect.com and enter in your model number and you'll be able to see an exploded line drawing of your unit and all the parts in it. You can then order the replacement part from them or use the info to find the part elsewhere, if you wish.
Hope you find this Very Helpful and best regards!
Aug 28, 2009 | Bosch Dishwashers
My Kenmore Washer 110.92281100 won't stop
I purchased a new timer, installed and solved the issue.
May 13, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
KITCH AID DRYER
It sounds like the timer motor isn't advancing. You will have to replace the timer.
Oct 15, 2008 | Whirlpool GGQ8831L Gas Dryer
Rinse cycle problems
ckd cold water inlet may be full of sand ..most washers have a cold only rinse and will not advance to rinse unless fills with water..if good water flow to cold water inlet but still won't let water in suspect inlet valve
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
My Indesit won't advance, won't complete a cycle
Suggestion: Try cleaning your outlet filter. This needs periodic cleaning, according to your usage. Refer to user's manual re. the cleaning. When it is the rinse problem it usually is the filter block. W
Oct 05, 2007 | Washing Machines
Dishwashers Logo
20 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
