Question about HP OfficeJet 7110 All-In-One Thermal Printer
Scanner error 7 on HP Officejet 2840
I have turned the machine on and off 6 times with the same error every time.
  • ahenley Jun 23, 2009
    My machine is a LaserJet 2840. Resetting the printer worked. Thanks so much for your help.
    President:
  • HP Master
  • 1,996 Answers
You may need to reset the printer, by following these instructions. If it doesn't work the first time, try to wait longer before reconnecting and try again.
I can't get a hit on that error message, but here are links to some know error codes for your HP laserjet 2840 printer: here, here, and here. Here is the main problem troubleshooter for your model.
(There is some confusion in the header listing for your post, so if you have a different model printer, please write back)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 23, 2009
  • efs_perpends
    efs_perpends Jun 23, 2009
    You're very welcome. I'm glad it was such a simple solution!
I have an HP 2840 color laser jet that keeps presenting a Scanner Error Code 6. Might anyone know if and how I can repair this on my own? Thanks a ton! Mike
replace optical scanner assembly..(a unit located in flat bed scanner with florocent lamp moving left to right while scanninf & copying)
Sep 17, 2011 | HP LaserJet 2840 All-In-One Printer
I am getting scanner error 5 massage on hp 2840
A tech needs to look at it. It could be as easy as just reseating the 4 wire bundle connector that comes off the scanner and connects to the formatter.
But, in any event a tech has to check it out.
Jul 29, 2010 | HP LaserJet 2840 Printer
For my hp color laserjet 2840
You have a bad scanner assembly. Very expensive to get fixed
Mar 02, 2009 | Office Equipment & Supplies
Scanner error 6 for hp color laserjet 2840
After the hp color laserjet has finnished initiallizing it gives me error code 6
Dec 07, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 2840
The error your having caused by the scanner assembly in the Auto Doc Feeder. The part is not real difficult to replace however it is not cheap. Here's the part number: Q3948-60191.
The part is available through HP online at http://partsurfer.hp.com for $130.76 plus shipping. It is also available (probably a little cheaper) from Seattle Platen, Dale - 1-800-221-2388.
We have been sucessful a couple times in disassembling the lower (scanning) section of the Auto Doc Feeder and thoroughly cleaning all mirrors and lenses. It's about 1 in 8 that will clear up the issue. Replacement is 100% cure.
Here's a free copy of the HP 2820/2840 service manual that will help you in the disassembly.
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%202820,%202830,%202840%20Parts,%20Service%20Manual.pdf
Hope that helps solve your printer issues. :)
Aug 26, 2008 | HP LaserJet 2840 All-In-One Printer
Scanner Falure Issue
Clean Scaner Unit Properly its not easy to done
other wise all engineer
May 26, 2008 | HP LaserJet 2840 All-In-One Printer
Scanner error 6
Scanner errors are as follows for that model:
Scanner error #
1 = dark find
2 = LMW temp find
3 = bulb warm up from off
4 = bulb warm up from coarse
5 = cal label find
6 = doc original find
7 = LMW final find
8 = cal label find after scan
9 = cal label find prior to standby
10 = doc original find prior to standby
11 = bulb warm up from standby
I would see if there is an original on the flatbed glass (platen), or if something is obstructing the scanner view.
If the error persists, replace the scanner
assembly or the formatter pcb
Apr 22, 2008 | HP LaserJet 2840 All-In-One Printer
Scanner Error 6
clean glass. switch off. clean the lightsource bulb. keep fingers off the glass when cleaning
Apr 17, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 2840 Scanner Error
when poering on this HP 2840 it says" Scanner Error 5"
what does it mean? How to get a solution?
Apr 16, 2008 | HP LaserJet 2840 All-In-One Printer
Scanner error 6
in my network i have hp M1005 printer always i'm getting this msg "scanner error 6 turn off
then turn on"
when i make turn off and turn on again same msg comming
how can i solve this problem...
Jan 16, 2008 | HP LaserJet 3050 All-In-One Printer
HP OfficeJet 7110 All-In-One Thermal Printer Logo
702 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
