Question about Furniture
How do you take apart a C0886F29 chair - Furniture
Can the two middle row captain chairs be switched out for a 3 seater bench in a 2007 Kia Sedona?
If you have third row. Look at the slots in the floor. If the outer slots are the same distance apart, front and back, then you can. Some vans you can, but some the captains chair are spaced further apart.
Jun 07, 2015 | 2007 Kia Sedona LX Minivan
KA4iup, thanks for the answer but that is not what I need. On page 40 of Pride jet 3 ultra manual, the picture shows a quick disconnect cable. I need to know how to pull that apart without damaging...
The quick disconnect normally has a tab that when pushed will allow the connectors to come apart. You will have to look. The connectors normally are white nylon, but they could be any color. It should be there if the manual is correct for your chair.
Best I can do without seeing a picture or the chair itself.
Mar 03, 2015 | Pride Used Mobility Jet 3 Power Wheel...
I am a quadriplegic and have had my Everest and Jennings shower chair since 1987. it is literally starting to fall apart. but it is the best shower chair, I have ever seen or used.And I would like to
Is it similar to this?
http://www.ebay.com/itm/Everest-Jennings-E-J-19-Transport-Chair-Wheelchair-/400197450577?pt=LH_DefaultDomain_0&hash=item5d2da07b51
Feb 03, 2015 | Drive Health & Beauty
My Innovex C0886F29 Student Task Chair gas lift broke and i just bought it 2 weeks ago and i want a replacement!!!
While it is a wheeled chair, it is not a wheelchair. You should contact the factory or whoever you bought it from... which, for this sort of problem, is the same answer if it HAD been a wheelchair.
May 01, 2014 | Health & Beauty
Gaming chairs
If you are good at soldering you can pull it apart and see if you can find the right parts.
Nov 11, 2013 | Cohesion XP 11.2 Gaming Chair Ottoman with...
Cannot figure out how to take apart jazzy elite power chair for traveling
hi, you find all the information you require clicking on the link below.
http://www.pridemobility.com/resourcecenter/Downloads/Product_Owners_Manuals/product_owners_manuals.asp
Regards
GeWiz.
Feb 24, 2013 | Pride Mobility Jazzy Select Elite Power...
Are there any modular designed outdoor chairs?
There are some companies that sale outdoor chairs that have some pieces that are designed to collapse or come apart for easier storage and transport.
Sep 02, 2012 | Alpine Garden
How much room should I leave between chairs in my kitchen?
In order to make the seating comfortable for your diners,each chair should be at least 20 inches apart. Keep in mind that your guests will need to be able to access their seatand be able to leave without squishing themselves too much. I would say the ideal length between chairsis about 30 inches.
May 29, 2012 | Furniture
How do you take an office chair apart?
To disassemble an office chair you must first turn it upsidedown. There is likely either a bolt thatneeds to be removed with a screw driver or a small circle that can be opened byturning it counter clockwise. Once youhave removed the bold or opened the circle you can remove the rest of the cogswith a screw driver.
Chair will not go up or down
The clicking is the mechanical part of the switch, but the electrical part may still be bad. In all the chairs I have serviced, it has always been the switch. The switch itself goes for about $25 plus labor to change it, and the whole control unit retails for about $100. the best test is to take the controller apart and short out the center wire to either side and check the chair for movement.
Jan 22, 2009 | Pride Mobility Products Casual CL30KD Lift...
Furniture Logo
51 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
