Question about Bissell Lift-Off Pet Deep Cleaner
No suction when canister on securely - Bissell Lift-Off Pet Deep Cleaner
We have a dirt devil that when the canister is engaged, it no longer has suction. The canister is empty. Thoughts?
you turned the switch to blow instead of suction
remember them days .. no .. i do
Jan 12, 2015 | Hoover Vacuums
Red light indicator comes on with suction only
Hi there Christy! It sounds like you possibly have a clog in your main hose. To check the hose for clogs remove the hose completely from the vacuum from both ends. Use a broom stick or something similar to loosen and remove any clogs from the hose. Remove the bottom plate and the brushes. Use a wooden spoon to gently break up and remove any clogs from the lower hose. Hope this helps!
Jun 16, 2014 | Hoover Nano Cyclonic Compact Bagless...
Nothing going into dirt canister
Is there suction at the hose? If not it is either blocked or the suction fan is broken. If there is, then there is a blockage in the pickup section, something is lodged across the channel after the brushes and before the place where the hose plugs in.
I think there is a safety switch to prevent it from running with the canister out so hard to check for suction at the top of the motor/suction fan. Make sure nothing is over that part under the canister too! If you can figure out how to bypass the safety switch (if there is one), you should have good suction where the canister sets on top of the motor base.
Oct 06, 2012 | Dirt Devil UD40270RM Quick Power Compact...
My dyson dc08 has no suction when i put the canister back on, however i can feel the suction without the canister on. why is this doing it and do i need to replace this unit. I have thouroghly cleaned the...
It sounds like the motor is functioning properly and the filters are fine. Check very thoroughly for clogs in the parts after the canister (down where the brush is, etc.)
Feb 28, 2010 | Dyson DC08 Cylinder Bagless Canister...
No suction to the canister
Sounds like you have a blockage somewhere. I would take the hose off the canister and test for good suction. if ok then you have an issue with the hose and wand assembly. follow this to determine where you lose suction.
Oct 20, 2009 | Vacuums
No suction up into the canister
Try cleaning the Hepa filter and the rear filter behind the motor
May 17, 2009 | Bissell CleanView II Plus Upright Bagless...
No suction for use of crevice tools, running hot, then shut off
Obviously no suction in hose would indicate a blockage, over heating is a breaker that shuts off the machine when it over heats. There is no way to clean hose the on this model because the hose does not detach at either end, therefore I had to employ the use of the good old wire hangar. Job complete up and running, with good suction. It is amazing what a prayer to God can do.
Nov 17, 2008 | GE 106766 Bagged Canister Vacuum
Little suction in craftsman canister style carpet/floor cleaner
you might have a leak on the suction side...perhaps the housing is not properly secured, or there is a **** in the black plastic hose.
Sep 10, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
No suction.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=663890
Generic problem for all Vacuums
No suction.
Posted by awil2 on Jun 11, 2008
No suction.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. My question would be does the vacuum turn on and if it does are you getting any suction? Sometimes the uprights and the canisters - if the top or front cover are not on securely you will not get suction, but your question does not tell me what brand, model or serial # it is and other wise I could give you a website address and phone # to try to further assist you in your question with FixYa. Otherwise we need more information to further assist you with your question.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 11, 2008 | Vacuums
Bissell Lift-Off Pet Deep Cleaner Logo
49 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
