Question about Williams 3003622 Ceramic Wall Mounted Panel Heater
Do you sell a holmes hch 4062 control knob - Williams 3003622 Ceramic Wall Mounted Panel Heater
I need a control knob for a Holmes space heater model #HCH405.
Sorry this site doesn't sell parts or have the software to look up part numbers.
Nov 11, 2016 | Heating & Cooling
Why does it have a different knob than listed?
New knob. Old manual. Someone forgot to update it when the new knob was installed.
Mar 05, 2016 | Holmes Products HM5125 Humidifier
I have a Holmes HAS1650 stand up fan and I need to know how to get it to quit rotating.
Not sure what you mean by "stop rotating"
I assume you mean to stop oscillating. There should be a knob on top of the motor housing that you push down to oscillate and pull up to stop oscillating.
If you mean to stop the blades from spinning there should be a fan speed control knob on the top of the motor housing that you turn to "O" to stop the fan.
Here is an instruction manual for a similar fan...
http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-holmes-products-Site/Sites-holmes-products-Library/default/v1405596036669/documents/instruction-manuals/HASF1515R_HASF1516R-UC_11EM1.pdf
Jul 18, 2014 | Dryers
Wintouch q75 firmware needed
Download This Firmware Made By HcH @ Techknow.T0xic.nl ' Thank Him If You Can
A13_Uberoid_v1.0_14SEP2012-HcH - Download - 4shared (http://www.4shared.com/archive/cI_qnZux/A13_Uberoid_v10_14SEP2012-HcH.html)
Flash This Firmware With LiveSuit, Then You Will have 1cm Shift Screen From Left Side.
To Fix This Issue, You Have To Follow The Steps I have Made:
[FIX][GUIDE] How To Fix 1cm Shift Screen (http://www.techknow.t0xic.nl/forum/index.php?topic=4245.0)
A13_Uberoid_v1.0_14SEP2012-HcH - Download - 4shared (http://dc592.4shared.com/download/cI_qnZux/A13_Uberoid_v10_14SEP2012-HcH.7z?tsid=20130220-085928-14e086bc&dsid=3ohbqa.958fcb82047451d925a8eb485c4595d0)
Feb 14, 2013 | Tablets & eReaders
Holmes Heater HCH 4163 purchased 2 years ago & has seen only light duty. Upon turning heater on there is a severe electrical smell allthough heater appears to function normally; cord & heater do...
I think the warrenty on this heater is one year. If the heater housing and cord are not overheating then I would remove back panel and clean fiter and brush,vacumn,or use compressed air to clean motor and fan blades. It's possible that if you have not been using very much that it's just burning off debris and causing the smell. I hope this helps you. Thanks
Dec 20, 2010 | Holmes Products HCH4163 Ceramic Compact...
My product is a Holmes oil-filled heater. The model # is HOH2505. There are two round control knobs and both are broken. Can I get a replacement? Frankie Moore
Hi and welcome to FixYa. I am Kelly. I don't have the answer to your knob problem other than to contact a Holmes Service Center. However, this particular heater was the subject of a recall (see link below.) Maybe you can get lucky and get a whole new heater vs the knobs should you have a unit with a product code listed at the bottom of this post..
http://www.holmesoilfilledheaterrecall.com
If you are in possession of a recalled model with a listed Production Code, contact us at (800) 306-2471 to confirm your eligibility and register for a replacement heater.
There is a 4 digit production code between 2 horizontal lines about 1/3 of the way down the product label.
These are the codes elligible for replacement:
Acceptable Production Codes 2305 0106 2405 0206 2505 0306 2605 0406 2705 0506 2805 0606 2905 0706 3005 0806 3105 0906 3205 1006 3305 1106 3405 1206 3505 1306 3605 1406 3705 1506 3805 1606 3905 1706 4005 1806 4105 1906 4205 2006 4305 2106 4405 2206 4505 2306 4605 2406 4705 2506 4805 2606 4905 2706 5005 2806 5105 2906 5205 3006
3106
3206
3306
3406
3506
3606
3706
3806
3906
Thanks for choosing FixYa.
Kelly
Oct 01, 2010 | Heating & Cooling
Williams 3003622 Ceramic Wall Mounted Panel Heater Logo
26 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
vance jones
Superior Maintenance
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
