Question about Car Audio & Video
How do I bluetooth connect to Blaupunkt Cone speaker?
2 Suggested Answers
SOURCE: speaker repair
Contact MMats Pro Audio at 561-842-0600. They can re-cone it for you, or sell you the re-cone kit. If that does not work for you, contact MWA Speaker Parts in Tuscon - 520-647-7193. They can sell you a re-cone kit, or they can direct you to a speaker repair center near you. A third option would be to contact Sundown Audio in Troutman, NC. They may be able to re-cone it for you.
Posted on May 28, 2009
Tip
Home made electric megaphone
Making a regular home made megaphone using poster board or cardstock is easy and anyone can do it, but you can easily take it up a notch and make an electric megaphone.
All you need is a poster board / cardboard, scissors, tape, a battery-powered speaker and a microphone with a chord.
Start by making a regular megaphone. Roll the cardboard into a cone and take the sides together. You want to make the cone as big as possible, the overlap should be as small as possible. Trim the edges of your cone so that they are all smooth and round.
To make your megaphone an electric megaphone connect a small speaker to the small end where you would normally put your mouth. The best speakers to use are bettery powered ones like the kind you would use to connect to your ipod. Using a very strong tape to connect the speaker to the megaphone making sure that the on / off switch is on the outside of the cone and accessible.
Plug the microphone into the speakers and attach it to the bottom of the speaker. When you switch the speaker on and talk into the microphone you voice will be amplified by the cone and your megaphone is ready to go!
You only have to connect the microphone to the bottom of the speaker if you want to have a one-handed set up.
on Dec 23, 2013 | Sport & Outdoor - Others
Despite wiring speakers correctly they remain out of phase. I know that reversing the connections resolves this problem but it has caused problems when playing 4 speakers simultaneously i.e., I need to...
I have no idea how you determined they are out of phase. Normally if you change all of them the result is the same. Just change the one (swap the speaker leads) that is out of phase.
First assume they marked on the amplifier typically red and black connections. Then check the speakers to see if they are also marked the same way, if so match the colors.
If they are not marked you need to be able to see the cone, that use to be easy. Use a battery and connect it across the speaker leads, I use a flash light 1.5 volt battery. You may have to go to a 9v but try the 1.5 first. When you connect the battery the speaker cone will either move forward or reverse. If the cone moves in reverse when connected swap wires. When the cone moves forward just mark with the plus (red) coinciding with the battery.
Nov 28, 2014 | Audio Players & Recorders
Blaupunkt radio says protect
Chances are there is a blown or shorted speaker, if able disconnect all speakers and unplug radio, plug back in and see if protect goes away. If so, re-connect each speaker one at a time until you find problem.
Feb 27, 2014 | Blaupunkt Car Audio & Video
Bought the stereo 6 months ago, now the speakers won't work!!!! Please help!
Hi, when a speaker does not work, you might need to do some troubleshooting tips to know exactly where the problem is .
First you will need to test the speaker cone if it's working properly by using an AA battery and two wires to make sure the cone is working..
Connect one of the wires to the Positive side of the speaker, and the other on the Negative side, And after that use the battery to hear if the speaker cone will make a click sound.
If it doesn't make a click, that means the speaker cone is Bad, you will need to replace the speaker cone,
But if there is click from the speaker cone, that means the speaker is Ok, and you might need to trouble shoot your stereo to be sure if the sound IC chip is Ok in the stereo..
Hope it helped..
Aug 10, 2011 | Audio Players & Recorders
My blaupunkt rear right speaker just stopped giving out any sound ..it started with a tearing sound at high volumes with bass intensive songs. then next day no sound at all. left speaker works fine. Help...
As shown in the picture double check the vibration flexible wire connecting to the center, you cannot see it on your naked eyes, use tester to prove the connection, use soldering iron to reattached the broken circuit, be responsible for the connection, put in mind that it is vibrating too heavy...
Oct 21, 2009 | Blaupunkt GTx 693 Coaxial Car Speaker
Built in bluetooth carkit but my BB Bold won't connect
Sir you have to just on bluetooth visiblety from your phone settings
Jun 01, 2009 | RIM BlackBerry Curve 8310 Smartphone
Speaker repair
Apr 18, 2009 | Mmats Juggernaut 15'' Car Subwoofer
Blaupunkt antenna connection !
Yes - adapters are available in stores & online. Try here:
http://www.bluespot.co.uk/install.asp
Mar 13, 2009 | Blaupunkt Hamburg MP57 CD Receiver CD...
Need code for my bluetooth
you should put five times zero i.e 00000
Dec 11, 2008 | Blaupunkt Hamburg MP57 CD Receiver CD...
Car Audio & Video Logo
57 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
