Question about Garden
What size string for a JD T105S trimmer? - Garden
2 Suggested Answers
timothyburch
SOURCE: How to replace string on
http://manuals.deere.com/cceomview/OMPS05249_J2/Output/Index.html?tM=
Posted on Sep 07, 2012
What do i need for replacement string? Can i go heavier or stay with the smaller string? This is for mastercraft 20v grass trimmer. thanks
the size of the string is critical in electric driven trimmers
it does have mass and the thicker string will over load the motor
stay with the recommended string size and keep to the recommended distance to the grass being cut
string line cutters work on the principle that the tip speed of the string is what does the cutting and that means that the first 1/2" of string cuts the grass
the rest back to the hub acts like a brake as it is dragged across the grass and slows the cutting speed and loads the motor
remember that the machine is designed to trim edges and not to cut down growth-- that is a job for heavier duty units
May 13, 2016 | Garden
ST200 trimmer. What kind of spark plug to get and what size string does it take?
Hi Cherri,
I think this is the manual for your machine. It should tell you all you need to know:
file:///C:/Users/Jim/Downloads/Homelite-String-Trimmer-Parts-Manual-ST200-String-Trimmer-UT-20501-A.pdf
Good Luck!
Jim
Sep 02, 2015 | Homelite Garden
My string will not go into the hole and I removed the 4 screws. I can not get it apart. How do I remove this head part to see why the string will not push into the hole?
Hi, Try cutting the string with a knifing straight clean. Then try again.
It won't go if it is frayed or chewed up. Also make sure you have the correct size of string. Some trimmers only use certain sizes of string to fit the head unit. Good luck.
May 03, 2015 | Garden
What string size is best to use in this trimmer ? model UT21006
Most all of the Homelite trimmers use string that is .080" in size.
Apr 19, 2011 | Homelite Mighty Lite Lawn Trimmer
String for a Poulan Pro PPB330
Pull your spool off, and look next to the notches on the bottom of the spool. The decimal number is the size of line that you can use. Some spools will have more than one size listed; they can use either size.
Best regards, --W/D--
Aug 21, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
May 07, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
String breaking
Check to ensure that the string is the correct size as specified in the owners manual. If ok check age of the string. If old it has a tendancy to be brittle. If new and supple try letting the trimmer get up to full speed and let the tip of the string do the cutting. Avoid taking on too much at once with this trimmer as the electric and battery trimmers are not as powerful as their gas counterparts. I hope this helps.
Sep 11, 2008 | Toro& Electric String Trimmer
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
