Question about JVC Televison & Video
What is the solution to My LT32N330A 32" class JVC tv red standby light is not on, while plugged and when I used the remote to put the tv on, instead to bring up green light, it was red light on.
SOURCE: power light blinks red, TV doesn't turn on
if you are not technical i sugest you have this checked out by a professional most probably a fuse has gone from iside or your driver board has gone down. The blinking should be normal after you have turneds it off because some capacitors will be discharging.
Posted on Aug 24, 2007
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
Posted on Jun 24, 2009
dsacco86
  • 1077 Answers
SOURCE: The tv will not turn on with either the remote or
Hi, I own the same TV and had the same problem. It's the #1 plaguing issue with flat panel TV made by Funai corp. Emerson is made by them. Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board.
The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can'tactually look at the tv over the internet. I can only make guesses with the symptom. I'm willing to bet you have the same problem like mine. One of six Inverter Transformers when bad on my Power/Backlight Inverter Supply Board. I replaced it and it works fine again.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual at Tvtechcenter.com; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $6. And most cases the new part cost less than $15. The service manual at the site is under LC320EM82S.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 13, 2009
Raditronic
  • 196 Answers
SOURCE: AKAI 32" Power Malfunction
check all 1000mf-16v & 470mf-16v in power supply. may be blow.
Posted on May 06, 2010
Is the red light suppose to stay on when you turn off the tv with the remote?
Yes it is supposed to stay on. This is the standby light. The television still draws power as do many electronic devices when not turned on and when in standby. If you do not want the red light to stay on you will have to unplug the television.
May 09, 2011 | Samsung LN32A330 32 in. LCD TV
32 inch, hannspree tv.1080P I need code to get my sky remote to work.
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV (try 0206)
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Mar 15, 2011 | Hannspree XV32 32 in. LCD Television
Can't play dvd player on JVC tv; I don't have a JVC remote.
I hooked up a Pioneer DVD player to my TV and when I play a DVD the volume cannot be controlled by the TV. It just plays at one level and on the louder side. When I'm watching regular TV and the DVD player is on and playing a disc I start to hear the DVD soundtrack at the same time as the whatever I'm watching on TV. I should not be able to hear anything until I switch over to Video 1. Any suggestions?
Dec 31, 2008 | JVC AV-32F476 32 in. Television
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
TV REMOTE CONTROL NOT WORKING
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Oct 17, 2008 | Philips HDD065 MP3 Player
Sony KV-32S22 32" TV Problem
Intermittent dead with red standby light on, but won't switch back on, comes back on it's own, won't respond to remote or local controls
Low 5v standby supply due to diode D869 faulty, check by replacement
Nov 23, 2007 | Sony KV-32S22 32" TV
Televison & Video Logo
88 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
