Question about Neff W4380X1 Front Load Washer
Neff washing machine - barrel doesnt spin
I have a Neff washing machine and the barrel doesnt spin. I had an engineer come out and replace the motor and bearings? but it still doesnt work and he said it is an electrical problem with the wires leading to the motor.Is this common? does this mean I need to buy a new machine?
  • 11,896 Answers
I would recommend it. Otherwise they will have to run new wires from control module all the way down to the motor. I would get my money back since they didn't replace the right piece.
Posted on Jun 23, 2009
Neff washing machine not spinning at high speed even with 1400 selected!!
there is a coupler in be tween the motor and trans you need to change it
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Oct 23, 2013 | Neff Washing Machines
Washing machine will not spin
its probly either ur bushes on the motor that have gone and need replacing or the programer has gone. if it was my washing machine i would change the bushes first as it dont cost that much to replace them.
Jan 27, 2013 | Neff W4380X1 Front Load Washer
I have a Neff integrated washer/dryer. The machine seems to turn on and take in water but doesn't start to spin. It sit's for half an hour making clicking noises then will start spinning and finish the...
Assuming that it pumps out okay then could be the motor.....Check belt is okay not fallen off , next motor brushes, they wear out after around 6 yrs ,
Apr 01, 2011 | Neff W4380X1 Front Load Washer
Neff washing machine not spinning. Fine yesterday, slightly funny noise and now drum not moving on wash or spin! Any clues?
Could be worn Carbon brushes on the motor.Check belt has not fallen off though...some Neff you need to buy half motor to fit new brushes as it comes this way, perhaps a good test is to blow ut any dust next to the brushes this may allow the motor to Briefy run long enough to tell if brushes are worn ..Half motor cost to buy - 60 GBP......Happy new year...
Jan 02, 2011 | Neff Washing Machines
Neff washing machine not spinning. have drained water. is the white circular part bottom left the filter. could it be there is something in here that is preventing it spinning? i cannot open it.
You can check if the drive is struck or the motor is struck. It will be good to confirm with a voltage check to see if power comes to the motor during the program cycle. if not the program controller is faulty. If yes the motor must run, if with a starting capacitor it must be weak and replaced.
If the drive is tight remove and reset.
Sep 25, 2010 | Neff Washing Machines
Neff washing machine wont spin ~ drum rotates but not at speed
how old is machine if machine is bout 5 years will need motor brushes they need t be changed every 5,6 yrs, if its quite new will be ure motor pcb if its not rampin up to full on spin
Feb 03, 2010 | Washing Machines
Barrell doesnt spin
Check the drain hose if to low to ground if so raise hose up to even with the tub top or two thirds up on machine. Some washers don't spin until water is drain out first then the pressure switch turns the timer to spin. Hope this may help.
Jun 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
sounds like motor brushes have worn out will need to remove motor to replace they are inexpensive.the clicking is the relay telling motor to rotate clockwise or anticlockwise.
May 30, 2009 | Neff W4380X1 Front Load Washer
Needing to replace the brushes on a Neff W4380X1GB
not the motor but the program switch
the motor only gets instructions from that switch or program board and the motor is running well if it does the rest of the wash well
Dec 02, 2017 | Neff W4380X1 Front Load Washer
Front Loader spinning failure
check you can turn drum by hand if rotates freely then youre motor brushes will have worn out the motor needs to be removed to fit replacements but they are cheap to replace.
Aug 10, 2008 | Neff W5340X0 Washer
Neff W4380X1 Front Load Washer Logo
462 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Billy Detlefsen
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
