Question about Weber Q Grill
Which symbols mean high or low on Weber grills
Treefrog15
  • 127 Answers
SOURCE: low flame on burner...
Remove the burner and check the flexible tubes for kinks or blockages. The flexible tubes usually just slip over the backs of the valves. Spiders love to get in there and block them. Also check that the holes in the burners are not clogged. Be careful when reseating the flexible tubes to be sure that they are properly seated on the back of the valves. Failure to properly seat the flexible tubes can cause leakage there, and the gas can ignite at the back of the valves and not reach the burner. Be certain that the replacement burner is designed to use with your grill and the flexible tubes mate properly with the back of the valves.
Posted on Jul 07, 2009
SOURCE: just bough weber Q200 grill. Is it normal that the
I have used the Q-series for 2 years. The blue and low flame is absolutely normal. Weber's philiosophy is of avoiding flare ups when grilling for best taste. I love this grill - very easy to clean, uses less gas and makes great food.
Posted on Aug 23, 2009
SOURCE: cannot get good flame on the burner of my baby weber grill. I've tried cleaning it checked hose, tank, regulator, seems to have good flow, but low flame only, even when set in high????????
I had this problem with a brand new grill so it wasn't grease in the hose. Due to the new propane regulators you have to turn the propane tank on for at least a minute before turning the grill to light. Let the tank sit in the light position for five seconds and then you light the grill. This will keep air from getting into the intake hose and will keep your gas flame roaring high.
I was only able to get the grill up to 250 degrees before I found this fix posted on the Weber site. It is listed as the number one solution in the FAQ section.
Posted on Oct 13, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have low flame on a weber gas grill. What are
Well it coulbe caused by these newer type propane tanks with the anti tip safety device installed inside them. To rectify you simply remove the tank to clear the pressure in the line and open all valve son the grill. Then close all valves on the grill and reconnect the tank. Then open the valve only just enough to allow gas into the grill, just crack it open a hair. Retry.
Posted on Oct 14, 2009
heatman101
  • 43501 Answers
SOURCE: My Weber Q grill worked great for 5 years but now
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Sep 05, 2010
Weber gas grill heats up high when on low settings
After making sure your knobs are installed properly examine the full length of all burner tubes. You will be looking for areas of corrosion or damaged metal. Holes that are larger than they should be will cause too much LP expulsion resulting higher temperatures. Replacement parts, schematics, customer support and much more is available at the official Weber site. https://www.weber.com
Mar 30, 2017 | Weber Grilling
FLAME WON'T TURN DOWN ON WEBER BABY Q
Sounds like the reg is letting too much gas pass
Oct 10, 2017 | Weber Baby Q Grill
Cant get a high flame on my weber q.... do I need a new regulator
disconnect and reconnect the tank...make sure it goes on straight and tight (the connecter).
Jul 16, 2012 | Weber Q Grill
My Weber Q grill worked great for 5 years but now it won't light on one corner and I can't get a high flame on any part of the burner. Even on "high" the flames are small & blue and the heat level is...
heatman101
Aug 26, 2010 | Weber Q Grill
My grate is rusting. I've never washed it or put it into a dishwasher. I's not supposed to rust!
Hello. You are correct. You could contact weber and state your case, or if you just want to get on with life, use some WD-40 penetrating lubrication to remove the rust, then cover those areas with some high temperature grill paint available at home depot, lowes, and most other hardware stores. Joe
Mar 18, 2010 | Weber Baby Q Grill
Silver C 2000 Model heats to 420 degrees with all 3 burners on Low. Normal? Weber support service has given me conflicting information. With 2 burners on Low it heats to 310-320 degrees.
That's fairly common with the lid closed and a day that is not too cool. Keep in mind that a gas flame is about 800F. Try using only one burner on low or between on and high to get a lower temperature. This is a grill, not a smoker or slow cooker.
It will run cooler with a large amount of food.
Feb 08, 2010 | Weber Genesis Silver C Grill
Rear Burner is hotter than the front burner on my Weber Grill
Since the grill is 15 years old, it is probably time to rebuild it. Replace both burners and anything else that is not working properly
Dec 20, 2009 | Weber Genesis Silver B Grill
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
Weber Q Grill Logo
152 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
