Question about Dell 2335dn Multifunction Laser Printer
Dell 1815dn "Open Door" error persists after toner change
Wiired
  • 122 Answers
SOURCE: front door open message it won't print
There is a switch inside the front door that is not making contact when the door closes, making the printer think that the front door is open. The switch is recessed in the housing. Look for a plastic knob that protrudes from the front door that will mate with a hole in the frame. Inside this hole is the switch. Try activating the switch manually with a screwdriver to make sure the switch is functioning. If it is, you will need to take off the cover and reposition the switch forward. If it does not activate manually, the switch must be replaced.
Posted on Jun 22, 2009
  • 49 Answers
SOURCE: Dell 1815dn overheats
I'd just call Dell tech support. If you complain about a heat problem, it's part of their policies to simply replace the unit for safety reasons. :)
Posted on Mar 01, 2010
  • 525 Answers
SOURCE: dell 1815dn error code
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Posted on Jan 21, 2011
StevenC82
  • 160 Answers
SOURCE: Front door open message on display of dell 1815dn printer
Hey, make sure the front door is shut, if it is, you most likely need to replace the High Voltage Power Supply (Part# WH773). Iteminc.com has this part and can ship same day. The sensor which reads if the door is open can go bad and it is part of the HVPS. Good luck!
Posted on Jun 16, 2011
StevenC82
  • 160 Answers
SOURCE: dell 1815dn says Open Heat error.
This is usually a problem with the fuser. Iteminc.com has these in stock and ships same day. Hope this helps any1 with this error. Good luck!
Front door open
hi first make sure the printer has toner.
according to disassemble the power supply and assemmble again, put the sensor tab into position.
Aug 07, 2013 | Dell 1815dn All-In-One Laser Printer
How do you print an envelope on a Dell Laser MFP 1815dn
when printing enevelopes always ALWAYS THROUGH THE BYPASS open front door and feed thru there. on the bypass is image to let you know fce up or down follow that. also change settings on pc when printing envelopes or cardstock etc.
Jun 09, 2012 | Dell 1815dn All-In-One Laser Printer
My Dell MFP 1815dn has a paper Jam 2. I removed the toner cartridge and pulled the paper out, before I realized that I needed to open the back. I believe I thought I got the paper out, but the printer is...
After a paper jam occurs in the rear cover of a Dell Laser Multi-Function Printer 1815N, the printer will not resume when the jammed paper is removed. This is the normal behavior of the printer as there is no sensor on the rear cover of this printer.
To open the back cover and remove any stuck paper, perform the following steps:
  1. Open and close the front cover.
    The jammed paper may automatically exit the printer. If the paper does not exit, go to the next step.
  2. Gently pull the paper out of the output tray.
  3. If you cannot see the paper in the output tray or the paper does not move when pulled, open the rear cover.
  4. Skip to step 9. If you do not see the paper, go to the next step.If you see the jammed paper, push the two blue pressure levers up and remove the paper.
  5. Release the blue strap, the rear cover stopper, and fully open the rear cover.
  6. Unfold the duplex guide fully.
  7. While pushing the fuser lever to the right, open the fuser door. NOTICE: Make sure to unfold the duplex guide before opening the fuser door, or the fuser door may be damaged.
  8. Pull the jammed paper out.
  9. Return the levers, fuser door, rear cover stopper, and duplex guide to their original position.
  10. Close the rear cover.
  11. Open and close the front cover.
    Printing automatically resumes.
Jun 24, 2011 | Dell 1815dn All-In-One Laser Printer
How do I change the toner cartridge?
Click the download button here for the manual. There is a cover on the front you open. aaldrich29.png
Mar 02, 2011 | Dell 1815dn All-In-One Laser Printer
I have a Dell 1815dn all-in-one laser printer. I have a "open door front door' error message rendering my machine inoperable. Any suggestions on how to clear this?
Dec 30, 2010 | Dell 1815dn All-In-One Laser Printer
Currently have a Dell 1815 - keeps saying Front door is open and will not print. Have tried everything - from turning off printer, unplugging, changing toner, etc.
Sep 15, 2010 | Dell 1815dn All-In-One Laser Printer
Dec 31, 2009 | Dell 1815dn All-In-One Laser Printer
May 21, 2009 | Dell 1815dn All-In-One Laser Printer
Dell 1815dn says Open Heat error. How do I determine if the fuser or the power supply is the problem?
Apr 01, 2009 | Dell 1815dn All-In-One Laser Printer
Dell 2335dn Multifunction Laser Printer Logo
35 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
