Question about Maytag Neptune MDE5500AY Electric Dryer
Why does my Neptune moder number mce8000ayw dryer not tumble?
My neptune dryer center stopped tumbling. Do i need to replace belt or could it be something else?
  • 39 Answers
If the motor runs, but the drum doesn't rotate, check the belt, part # 341241. It's probably broken and off of the drum.
Posted on Jun 05, 2014
2 Suggested Answers
onthejob5130
  • 640 Answers
SOURCE: Gaining access to dryer
open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 clips...now at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
Posted on Jan 29, 2009
Neptune dryer makes noise
Check the blower to make sure it is properly secured on the motor shaft. Also check all of the bearings: motor, tensioner pulley and drum support rollers or drum bearings. You may have to disengage the belt to check the motor and tensioner.
Oct 06, 2014 | Maytag Neptune MDE5500AY Electric Dryer
The dryer is making a loud noise as it tumbles.
you need to open it most of the dryer need maintanace every 4-5 yars and if you keep runing it you may do more damage.
there are several parts that the drum is turning on them and they get bad after few years. like felts,riders,belt...
Apr 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer wont tumble
The standard drive system on all driers is a large belt that fits around the tub. These belt don't last forever and can brake or slip off if warn. It's not a super detailed job for someone with mechanical skills, but it will require braking down the machine to get to the belt.
May 07, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Dryer makes noise like a bird chirpping.
You'll need to access inside the cabinet and oil the tires and belt pulley. Hope this helps!
Maytag Neptune Drying Center MCE8000AYW
Email me a response to robert_fawbush@yahoo.com and I will be more than happy to provide you with parts breakdown illustrations and possible part numbers and locations to replace. The service amount verses the do-it yourself amount will be well worth the savings. Typical labor cost on appliances are 75.00 per hour and a mark up on the parts. If you feel you can do it yourself after getting the photos e-mailed to you, it will save you approx 200.00 if not a lil less or a lil more.
Please rate this solution "fix-ya" if it seems to satisfy your question.
Apr 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune DC Model# MCE8000AYW leaks water from the right side of drying center unit while using the "Wrinkle Release Hanging Dry Only" feature. The leak happens during the steam portion of the cycle....
Stop using the water bottle because the water is overflowing the heater steamer pan and will short the heating element and the part is no longer avaliable and the top will stop drying.
Mar 27, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
198 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
