Question about Rheem Heating & Cooling
What size air filter do I use for the raheem RGDG-10EBRJR
What size of ac can i put on rheem furnace model ugph-10ebrjr
i need to know btu rating to give you a answer. more info.
Jul 18, 2015 | Heating & Cooling
What size filters do I need
the filter on the side will have a size on it such as 20x20x1 I recommend a fiberglass filter you get better air flow.
Aug 09, 2014 | Comfortmaker FVM4X2400A Air Handler,...
What sizes do air conditioner filters come in?
Air conditioner filters come in more than 100 differents. For the complete selection, check out this website http://www.aafilters.com/cgi-bin/filters.cgiand choose your desired air filter from the list down menu "find your "on the left side of the page.
Jul 15, 2012 | Heating & Cooling
Where do the 3 wires from the blower motor connect to on the control board for high speed use in the summer time? Black, Blue, and the Red one? The white is a no brainer. I can go to M1, cool, and heat....
Hello, the black wire is your high sped motor tap and it should be on cool as you have it. Blue is med-hi and red is your low speed motor tap. You have it wired correctly. Now the freezing can be caused by 2 things, low airflow or a low refrigerant charge. Low airflow can be caused by a dirty air filter, dirty evaporator coil, dirty blower wheel or the blower itself is running slow due to a weak capacitor. Anytime the motor is changed out the capacitor should aswell. If the airflow appears to be ok then the unit is low on refrigerant.
Jul 11, 2012 | Heating & Cooling
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
Feb 12, 2012 | Heating & Cooling
Where are the control board fuses for a Rheem RGVH-10EBRJR. Fan will not start at thermosat but will start with thermostat red and green wires jumppered.
Two possible locations, one would be a small glass fuse or automotive type fuse located on the PC board. The second would be in-line of some of the wiring. The wiring diagram will indicate where it is. Make sure you have the proper wires leading up to the thermostat in order to turn the fan on. You will need a minimum of 3 for heating (R, W and G terminals).
Mar 12, 2011 | Heating & Cooling
Changing Air Filter
In general terms an electric unit uses a 20 x 20 x 1 filter and a gas system uses a 20 x 25 x 1 filter. If the return filter is somewhere other than at the unit, it will very greatly in size. Its the descretion of the installer as to what size filter they choose to install.
Apr 07, 2009 | Intertherm P3RA-030K Air Conditioner
Weather King Air Conditioner
The best way to find the size of the filter is to use a tape measure to find the size of the filter cavity. Remmeber, most filters come in even numbered inches, and you can buy a "cut to fit" at The Home Depot. Ask for "Hogshair".
Jul 26, 2008 | Heating & Cooling
Filter size
Thats an A/C, what is the indoor unit model #? Does it have a filter box? If so what size? If not do how does your filters sit in the unit?
Jun 23, 2008 | Weather King 12AJA4801AH Air Conditioner
Heating & Cooling Logo
49 people viewed this question
Top Rheem Heating & Cooling Experts
jeff5may32
billconfused
Lawrence Oravetz
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
