Question about Dehumidifiers
Kenmore Dehumidifier 251.90701-automatic pump not empting bucket
Why doesn't the bucket empty automatically? It has been working for over a year. This is a new phenomenon. I have cleaned it, and it looks O.K. Could it be the hose?
  • 883 Answers
SOURCE: No water collection
compressor may be starved for freon or blockage in freon line...tech must troubleshoot.
Posted on Jun 08, 2007
SOURCE: Dehumidifier Error?
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
Posted on Nov 13, 2008
SOURCE: dehumidifier runs but does not collect water
I have dehumidifier Whirlpoot Gold Model #39R171E Serial #H/XE11M1K 6203A it was working fine last year, but this year it is not collecting any water, it is running for day. I opened it, cleaned the filter (which was mostly clean) & it still has not water in bucket. What is wrong & is it possible to fix it by myself.
Posted on Jun 10, 2009
  • 3 Answers
SOURCE: whirlpool dehumidifier drains into the bucket, not the garden hos
I had a sililiar problem. I think I tightened tthe hose after putting a new rubber gasket on hose fitting, Also checked angle of hose.
Posted on Sep 30, 2009
  • 420 Answers
SOURCE: 'bucket full' light on, but bucket empty
There is likely a switch operated by a float to turn that light on and turn off the compressor, sometimes manufactures use a rubber "O" ring on the float shaft and they can slip. take the cover off the pump and check the float or in some cases one of two floats are used. Once float turns the pump on and off and the second float shuts OFF the compressor and turns ON the full reservior light.
Posted on Jun 04, 2010
Www managemyhome com
faulty sensor in the bucket, probably stuck
Aug 04, 2014 | Kenmore Dehumidifiers
I have an LG energy star auto start dehumidifier (about 3 years old). It works fine. How can I hook it up to drain into my laundry sink automatically? It would save me the effort of emptying the bucket...
Unfortunately, draining into a laundry sink is not an option. As your model does not have a pump, it relies entirely on gravity to drain with a 48" length of garden hose. A floor drain is the perfect way to go, if you have one.
To further assist you, I have included a llnk to your model, which has been discontinued. You can download and print the manual for future reference if you like.
Hope this helped you and thanks for choosing FixYa.
Aug 18, 2011 | LG LHD45EL Dehumidifier
My Kenmore 580.54501 dehumidifier "Water Bucket
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
May 27, 2011 | Kenmore 54501 Dehumidifier
It ran for a couple days, went to empty the bucket and maybe a inch of water was in it. normally i'm empting it everyday. when i took the bucket out i noticed a little ice under the machine.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 07, 2011 | Fedders A7DH45B2A Dehumidifier
Empty bucket but bucket full light is flashing
heatman101
Mar 30, 2011 | Kenmore 54501 Dehumidifier
The unit is about 4 years old and the auto shut off light is flashing on and off and the unit will not run even tho the unit is empty can you help me out? Thanx Larry
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
heatman101
Sep 01, 2010 | Kenmore 54351 Dehumidifier
Hopper not seated right
I had the same problem with my Kenmore dehumidifier. The bucket couldn't be properly seated because the plastic cracked slightly at the site where the bucket normally is held. Because of this, the button that it is supposed to be pushed in to keep the dehumidifier running wasn't pushed in all the way. A friend has a Kenmore with the exact same bucket- tried hers, and it works perfectly.
The problem I have now is that I can't find the bucket for sale.
Jun 24, 2008 | Kenmore 5230 Dehumidifier
Dehumidifiers Logo
37 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
