How to reset the drum count on a bizhub b754 - Office Equipment & Supplies
Konica minolta bizhub c253
what is the question?
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Aug 21, 2014 | Konica Minolta Minolta Bizhub C253 Copier
How do you reset drum and developer counters
Press the Utility/Counter button then meter count then details then stop 00 stop01 to access service mode then clear drum and developer do not exit out all the way once counters are cleared touch end then power off the main PWR ON/OFF switch located on the left hand side of the machine in the rear then remove the Drum Cart and replace drum and Developer then reinstall drum cart. Enter service mode again Run Function F-8. Do no print or copy before doing this. So disconnect FAX line and Network cable.
Apr 08, 2014 | Minolta bizhub 350 Black and White Copier
Bizhub 750, i put new developer, is there any setting that i have to do after this job?thx
After you change the developer enter in service mode press Utility key- Meter count- Details-Stop-0-0-Stop-0 -1press Counter select Special(optional)parts counter select Developer and reset the Developer counter value by pressing C.After reset the developer counter enter in Imaging Process adjustment mode select Drum pecularity mode and select Cartridge installation mode press the Star button.The process duration is 2-4 minutes.Whwn thw ok appears press Exit and return the copy mode,make a test page.
Mar 24, 2014 | Konica Minolta Dv710 O2xk Black Developer...
Need to replace the drum on a minolta bizhub 350 copier
First get into service mode. Utility/Counter then meter count then check details. Then Stop 00 stop 01. Counters. Clear Drum and Developer. Then touch end do not exit all the way out of service mode. Turn off the machine using the main on/off rear of machine left hand side. Then remove the image cart. and replace the drum and developer. then turn machine on reenter service mode. Run F-8 found under Function. Do not print copy or allow fax to print before this is done. Or you will have to replace the developer again. So remove network cable and fax line if machine is as printer and FAX. after powering off
Jan 15, 2014 | Minolta bizhub 350 Black and White Copier
I want to change the setting of my drum unit on a konica minolta C-360
Enter in the service mode by press following keys:
Utility - Meter count-Check details - Stop - 0 - 0- Stop - 0 - 1 - Stop -0 -C - setting IU life stop setting and select NO STOP.
Feb 20, 2013 | Konica Minolta bizhub C250 All-In-One...
My bizhub 250 said the drum needed to be replaced, which i did, however the printing is so light and the machine still says to replace the drum. What am I missing?
The drum counter must be reset by using the service mode. But that is not your bigger issue here. The drum section is part of the Imaging Unit. When you change the drum section you are also suppose to change the developer (starter) in the developer section. So when you reset the drum count this also "resets" the atdc (automatic toner density control) ratio which must be recalibrated using the F8 mode. The 2 are tied together. You can try doing F8 without replacing the developer but this is just asking for trouble. Just resetting the drum count will mean you have at least a 50% chance of getting a COF32 code which is an atdc sensor failure because of the ratio mis-match that will occur.
You either need to find Imaging Unit rebuilding instructions or have a service tech come out and take care of this properly.
Good Luck and Thank You for using Fixya.
Jan 24, 2011 | Konica Minolta bizhub C250 All-In-One...
Change PC Drum Message on Bizhub362.How do you resset this message?
You are going to need to call your service company and have them replace the drum unit for you. Don't listen to anyone that gives you the service mode entry procedure and drum count reset. This WILL screw up the AIDC (Automatic Image Density Control) and the machine will shut down with a COF32 code. There is a very specific procedure which must be followed when replacing/resetting the drum counter on these machines as there are several "counts" that are tied together. Trust me on this as a 27 year Minolta Tech, spend the money and have the drum unit replaced. They are good for 100,000 copies so even tho it may cost some money to do. Divide that cost by 100,000 pages and it gets pretty cheap.
Sep 09, 2010 | Konica Minolta Bizhub 362 Copier
How to reset DCP 7030 drum unit
Reset DCP 7030 drum unit : -LCD-
Press MENU and turn on printer - MAINTENANCE
arrows 81 and OK -RESET DRUM COUNT
press OK -RESET LIFE COUNT
press CLEAR / BACK
arrows 99 and OK
ready
Oct 26, 2009 | Brother DCP-7020 All-In-One Laser Printer
In minolta bizhub 350 pc drum change
Two Options:
1) Reset the PC/life; I/C Life and DV counter and run F8.
2) The same than before but change the PC drum.
by : George Rivas ( OSI )
Feb 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Displaying mualfunction detected (bizhub 250)
i will like to know how to reset the page count and service my konica myself, also my konica bizhub 250 is showing C-0204
Feb 22, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
19 people viewed this question
jasbo
jasbo
