Question about Panasonic KXTGA939T - - Phone
Set up initial voicemail on panasonic phone - Panasonic KXTGA939T - - Phone
4 Suggested Answers
  • 3 Answers
SOURCE: Voicemail box not set up
I have seen the same problem with some users (I look after the PABX) so I just go into the maintenance console and set up the foreward to the default voice mail number. Or you can try the following:
CALL FORWARDING HANDSET 1. Press the Speaker Phone Key on your handset 2. Then Press the FWD/DND Key 3. Then select the Forward type you desire - Key 2 - Immediate Key 5 - Busy/No Answer 4. Then dial the internal extension number (eg.444) or voicemail pilot (201) 4a. If forwarding to external number dial 0 then dial outside telephone number 5. Dial # then press the Speaker Phone key
Use the voice mail that is set for your system.
Hope this helps
Posted on Jan 16, 2009
cnavarro
  • 2460 Answers
SOURCE: need to access voicemail with no password-panasonic KX-T230 phone
Find the password to mailbox 999 or call a Panasonic dealer.
Carl
Posted on Jun 16, 2009
cnavarro
  • 2460 Answers
SOURCE: Phone is Panasonic KX-T7453, previous
The override comes from the Voice Mail System owner logging into mailbox 999 and resetting the extension password.
Carl
Posted on Oct 09, 2010
How do you reset the voicemail on a landline panasonic kx-t7633?
Jill,
It looks like your extension's voicemail mailbox is not set up. So without the mailbox not being set up, you do not have access to the mailbox. Once the mailbox is created, you should be able to add/change your password. If you are not sure how to create a mailbox, I would check and see if you are able to contact a Panasonic phone tech in the area to take care of your issue.
Mar 09, 2015 | Panasonic Lands Phones
Does a panasonic kx t 7731 have built in voicemail and if so how do i program it
You need to get a voicemail system. The 7731 is just a phone, but it can be used to access Panasonic VM or Built In Voicemail in a TA-824 system. The external product is a model TVA-50 and it comes with documentation on how to interface it to your phone system. If you have an old KXT-308 or 616, or any other older Panasonic system prior to a TD-816/1232, you're going to have a problem.
Carl
Carl
Dec 06, 2012 | Panasonic KX-T7731 Corded Phone
Need to access voicemail with no password-panasonic KX-T230 phone
Carl
Jun 16, 2009 | Panasonic Lands Phones
Help how to set-up a voicemail on panasonic kx-t7633
CLICK HERE for your owners manual in PDF format.
This phone does not have voicemail capabilities. Your company's voicemail system is seperate.
You can find Voivemail notification settings on page 10 of the manual.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 13, 2009 | Panasonic KX-T7633 Corded Phone
Setting up voicemail for base unit and handsets
Download a pdf instruction manual from panasonic.com od pdf on internet ....
Jun 11, 2017 | Panasonic KX-TG4500B Phone
Access voicemail from another line while away from home
The previous solution only works for older machines. I have the same Panasonic model and this works every time.
On your handset, hit the top center button(menu). Touch the arrow down button 7 times. Should say "Initial settings". Hit top right button on handset (display shows this is now the "select" key). Display now shows "Set Answering". Hit top right button again ( select key). Display now reads "Ring Count". Hit arrow down button 2 times. Display now reads "Remote Code". Hit select key again and enter your desired 2 digit remote code. Hit "Off" key. When you call the answering machine from the road, simply enter those same digits. Piece of cake. Enjoy.
Jan 01, 2009 | Panasonic KX-TG5632 Phone
Voicemail setup
No, it's an option with the system. If it's Panasonic, it has part numbers that begin with TV and they're a box just smaller than the phone system.
Carl
Aug 29, 2008 | Panasonic KX-T7630 Corded Phone
Outside calls are going directly to voicemail
there should be a switch at the side of the phone that controls this.
you need to set the amount of rings u want before it goes to voicemail.
sam !
May 12, 2008 | Panasonic KX-T7630 Corded Phone
Can't get to voicemail
Change the DTMF found in phone settings (Initial Set-up) to either short or long. When this is set to off, the voicemail cannot pick up the numbers you type.
Oct 25, 2006 | Motorola Mobility RAZR V3
Panasonic KXTGA939T - - Phone Logo
49 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
