Question about Electric Mobility 4 Wheel Power Electric Motorized Wheelchair Scooter
Scooter battery meter dips - Electric Mobility 4 Wheel Power Electric Motorized Wheelchair Scooter
    Master:
  • Electric Mob... Master
  • 401 Answers
After 10 to 12 hour charge, unplug the charger, make sure the freewheel lever is in drive mode, you will know if it is because you have a hard time trying to push the scooter. Turn it on and try to drive if the meter goes to above the middle on the meter, it should ok, but, if the needle goes to red right away time for new batteries. Will need more info to go any farther. or you could go to www.strege.com/BlueDoc it is an app to help trouble shoot scooter problems.
Posted on Apr 07, 2016
Battery says full charged but won't go?
Just because the meter shows full does not mean your batteries are in good condition. It is perfectly possible to have batteries that show 24volts on the meter but that do not have the amperage required to make your scooter move. You need to take your batteries to a dealer to have them properly capacity tested to ensure they are ok. Thanks Dave
FYI ....... (Most gauges on Scooter Tillers are a very simple voltmeter and are only supposed to give you a rough idea of the battery status not its remaining capacity)
Aug 29, 2014 | Health & Beauty
How to check scooter batteries
Remove the seat. Remove the cowling that covers the battery. Batteries should be accessible now. Use a Digital Multi- Meter or DMM. A simple battery meter will not take the 24v current. Set the meter on volt; at the 100 scale and read the meter. voltage output will read on the screen. How to Find Problems in 24 Volt Electrical System eHow Link is to page that explains how to use the meter to find your issue. If you have a 12volt system the procedure is the same.
Mar 04, 2014 | Pride Health & Beauty
I have a golden companion II 3 wheel scooter with new batteries, the problem isafter a complete charge the scooter starts off fine but gradually loses power as indicated by meter in 5 to 10 minutes. A
hi ,there are two parts to batteries holding power and preforming well, firstly how good are the batteries, secondly how good is the charger ?, good batteries and a bad charger will make the batteries appear bad...
Regards
Rob
www.gewizrepairs.co.uk
Feb 22, 2014 | Golden Technologies Golden CompanioN II -...
Pride GoGo Ultra X battery meter needle
you could have a bad throttle pot o speed pot possibly a key switch problem aswell. Hi I a Phillip the "DFW Mobility Specialist"send me a email at dfwmobilityspecialist@yahoo.com if you live in or near the Dallas Fort Worth area.
Apr 10, 2013 | Pride Mobility Products GoGo Ultra X...
Ultralite 480 lacks power, new batteries fitted 5 months ago, shows fully charged, dips down when accelerator lever pressed but stays in green area
The battery lights dropping down while the scooter is in motion is normal; the motors are drawing current from the batteries which is going to drop the battery level slightly. However, if you see the battery indicator lights dropping off steadily while the scooter is in motion (1 bar every few minues or seconds) this can indicate a battery problem. It sounds like this is normal operation!
Nov 07, 2010 | Ultra Products Health & Beauty
I don't think the charger is working
This concern will require a volt/ohmn meter. If I am not mistaken, this scooter requires two 12 volt batteries wired in series. That is, the positive post of one battery connects to the negative post of the other and vice versa. This then constitutes an operational voltage of 24 volts. On most scooter chargers there are 3 pins that plug into the scooter to charge the batteries. On mine, the pin in the center pin is "ground". However, it is easily identified by setting the voltmeter to ohmns reading (a horseshoe shaped symbol) and doing what ever dissassembly is necessary to reach the scooter side wiring then touch one lead of the meter to either of the negative posts and the other to the exposed wires until the meter reads 0 ohmns or very close to this. This is the charger ground. Then set the meter to read DC voltage. Disconnect the charger from the scooter. Place the black lead on the meter on the identified ground of the charger and the red lead on either of the other two leads. There should be 12 volts either location. If there is not. the charger may be the problem. If there is, the batteries could have an internal problem and any auto parts store will happily check them for you.
Good luck and good hunting. If I can be of further help my email is jimwntrs@hotmail.com
Oct 25, 2010 | Golden Technologies Buzz Around 3 Wheel...
It isn't charging ... I have a new charger and new batteries
Hi. Check the main battery fuses. These are under the black heat shrink half way along the red positive battery leads.
Also use a multi-meter, and plug the probes into the charger socket on the scooter. You should be able to read the full battery voltage on the meter. If you can't, there will be a faulty connection somewhere.
I service Pride scooters here in New Zealand, and I find them reliable.
Good luck. Neil.
Jun 16, 2010 | Pride Luxury Line Maxima Scooter - 4 Wheel...
Have new charger and cord. plugged in but charging led not lite.
Hi. Is the charger socket on the scooter in good condition. I have seen a few of these melted. They don't contact properly, and get hot.
Use a multi-meter and plug the probes into the charger socket on the scooter. You should be able to read the battery voltage on the meter.
If you can't read any voltage, check the battery lead connectors and the main fuses.
Most pride scooters have fuses under the black heat shrink half way along the red positive battery lead.
Does your machine still drive or is there other faults.
Good luck. Neil.
Jun 16, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Shop rider sovereign voltage indication. Brand new fully charged
hi Richard,
Does the scooter actually lose power after the 3 leds show ?
If it is losing power then a suggest to try some other batteries to confirm dodgy batteries, check the terminal connections etc.
If it does not lose power then the volt meter is at fault, if you can check the voltage before riding then after it shows only 3 leds , if there is a big drop, check the charger first to make sure the batteries are getting fully charged.
Regards
GeWiz.,
Dec 21, 2009 | Electric Mobility Shoprider Electric Power...
Batteries are charged, scooter won't move, no power to display
It is impossible to overcharge with the Pride charger. When the battery is full, it will stop charging and check about oncew a miute to maintain the charge.
Now, when you plug in the key (looks like an audio headset jack) does the battery meter indicate a full charge? Also, the scooter will not move if its in free wheel mode, and it will not move if the charger is plugged in. Beyond these first steps, you will need a voltage meter to troubleshoot.
Jan 18, 2009 | Pride Mobility Products Go-Go Elite...
Electric Mobility 4 Wheel Power Electric Motorized Wheelchair Scooter Logo
46 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
