Question about Kenmore Washing Machines
Adjator doesnt work properly. skips - Kenmore Washing Machines
    Problem Solver:
  • 11 Answers
My washer was doing the same thing. I replaced these http://www.repairclinic.com/SSPartDetail.aspx?s=b6a11c201i3109&PartID=3109
Posted on Jun 26, 2009
GE Washer wds2080d8ww will not adjatate
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Nov 22, 2011 | GE Washing Machines
Our whirlpool washers agitator doesn't agitate during the spin or wash cycles
I would asume you mean it does not adjatate during the wash or rinse cycles.If it fills and you can here the motor run after it fills/then it drains and does not spin and fills again for the rinse but does not adjatate ? I would guess you have a broken motor coupler ..Most shops will do that repair for under 100.00....If I had more info I could be more sure...anyhow if more info is needed just repost....I hope I help you if I did please give a vote...thank you good luck
P.S mod # helps so much
Feb 02, 2011 | Whirlpool Washing Machines
I have something stuck under the adjatator. How
Hi, depending how old you GE washer is will determine how difficult the agitator will be to remove. However, all GE made ( hotpoint, baycrest, some kenmore, moffat, mcClary, etc. ) washer's of the past 50 yrs. or so have agitator's that are pressed onto a drive block and need to be pulled off, sometime's by hand, sometimes by a greater force, i.e. "agi-tamer" or "hammer". ( of course the hammer method will require you to by a new agitator ). The "agi-tamer is a real tool which slides under the agitator and by way of being pressurized with "cold" water ( hot will burst it ) will push the agitator up off the spline/block...don't stand over it looking down or you'll potentially get "knocked out" ha ha ! Hope that help's. At least you know it does "pull off" and it isn't bolted in place. Good luck, macmarkus :)
Feb 16, 2010 | GE Washing Machines
Transmission is not shifting properly on my 2000 nissan frontier 2wd pick up, auto It revs at 3-4000 rpm instead of a nice consitent 2000rpm, revs real high and doesnt change gears intill 20 mph, it doesnt...
You could have a bad valvebody in your transmission or a bad pump in your transmission or your clutches are bad. In any case you have a bad transmission. Please rate my answer.
Nov 17, 2009 | 2000 Nissan Frontier
My kenmore washer will not adjate.
You probably have a broken drive coupling. The part is cheap enough. here is a pdf:
http://appliancejunk.com/motorcoupler.pdf
Here is one from Jimbo:
http://repair2000.com/coupling.html
Here is one I made:
Direct drive coupling replacement by
TheMobilian
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 16, 2009 | Washing Machines
Washer is not washing the clothes properly. Skipping cylcles
If it's new - check if it's under warranty. Let them solve it. Save you money. You've already paid for it once.
Mar 21, 2009 | Whirlpool Washing Machines
GE WJSR2070B won't agitate
There is a drive block under your adjator. You must pull the adjator off. Get your fingers ( Man Friend LOL ) under edge of adjator & pull. You will see a plastic pat with screw in it . if you can spin with hand , replace it .
Mar 01, 2009 | GE WJSR2070B Top Load Washer
Adjatator not turning
your pump or outlet pipe might be blocked if n ot then the pump will be faulty
Nov 19, 2008 | Hoover Washing Machines
Whirlpool Thin Twin Washer
Sounds like the transmission is gone the thing you call the spinning mechanism is call the adjatator it should move left to right I can tell you right now to replace the dog ears if it is a kenmore washer they go bad all the time they cost about 5 dollars they are under the cap on top of the adjatator you will need to pull it off to do the job good luck Ron
Jun 10, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
42 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
