Question about VAX Appliances Vacuums
Vax model 221a07
I need necessary filters
Vax action 602 manual
There are several models of the Action 602 by VAX. The manuals are available on the company's support site: http://support.vax.co.uk/ . Use the search feature to find your particular model. The direct link to the manual for the Vax Action 602-AN-Be is http://library.vax.co.uk/resource/1086/u86-an-range/user-guide.pdf .
I hope this helps.
I hope this helps.
Aug 12, 2016 | Vax Vacuums
Vax manuals
Visit this site and enter the full model number. diagrams help to identify the model number.
Aug 13, 2014 | VAX Appliances Vacuums
Vax customer support
They can be purchased straight from their website! Depending on what type & model you have, select it on their home page and then choose filters/accessories. FOLLOW LINK BELOW:
Air 3
May 07, 2014 | Vacuums
Vax turboforce not picking up
Hello Guest, Please check that your brushbar is turning, if isn't then your belt has broken, once replaced your machine should be fine.
If you need further help or advice, please call the Vax Customer Careline on 0844 412 8455 with your machine available, and an Advisor will be able to help you. The Vax Careline is open every day, from 8.30am until 6.30pm, Monday to Friday, and 9am until 5pm on Saturday and Sunday. Outside of these times please check the website support section which includes videos to demonstrate how to deal with everyday problems such as changing filters and belts and checking for blockages. With best wishes, The Vax Team.
May 11, 2010 | Vacuums
I need a user manual for a vax rapide deluxe v-026
Hello robin143, the user guide is available here: http://www.vax.co.uk/downloads/pdf/VaxGuideNo22a.pdf
May 12, 2010 | Vacuums
How do you use vax 2000 to shampoo carpets. do not have a manual
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
http://www.vax.co.uk/downloads/pdf/VaxGuideNo8a.pdf
Jun 15, 2009 | VAX Appliances 2000 Canister Vacuum
I was using my vax rapide washer earlier and it blew my trip however noticed that the filter is disintergrating do you think this can be repaired?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=553164
Generic problem for all Vacuums
I was using my vax
Posted by paulxlyn on Apr 28, 2008
I was using my vax rapide washer earlier and it blew my trip however noticed that the filter is disintegrating do you think this can be repaired?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Yes, you can contact your local vacuum cleaner dealer and if they don’t carry the Vax Model then feel free to contact the Vax Rapide Factory Manufacturer phone number or the website for further information and to order parts if needed. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.vaxusa.com/
If you have specific questions and you can't find the answer you’re looking for here, please call our Customer Service Department at 877.894.2031
M-F 8AM-7PM EST or check out our Contact Us page for more information.
Thanks, Don – The Vac Man
Apr 28, 2008 | Vacuums
I have a vax rapide carpet washer was using earlier and blew my trip switch noticed that the filter is falling to bits doyou think it can be repaired?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=553160
I have a Vax Rapide
I have a vax rapide carpet washer was using earlier and blew my trip switch noticed that the filter is falling to bits do you think it can be repaired?
Go Ahead. Use Us.
Vax X5 clogged
http://www.vax.co.uk/downloads/pdf/VaxGuideNo87a.pdf
This is the user manual for the X5/VX1 and shows you how to dismantle the sections necessary.
Nov 18, 2007 | VAX Appliances Vax X5 Bagless Upright...
Vacuums Logo
29 people viewed this question
Top VAX Appliances Vacuums Experts
richie46
Jim
Are you a VAX Appliances Vacuum Expert? Answer questions, earn points and help others
