Diesel DZ4259 Black Stainless Steel Case and Bracelet Black Dial Logo
A
Anonymous Posted on May 14, 2014
WHAT IS THE POINT OF CHRONOGRAPH - Diesel DZ4259 Black Stainless Steel Case and Bracelet Black Dial
How do I zero the stopwatch hands on my Nautica A 29504 chronograph watch
try www.watchshop.com/mens-nautica-bfc-chronograph-watch-a29504g-p9...
My new analog american exchange watch has buttons and chronograph but wont or cant set, can someone help???
Watches are the best, I often take it as a gift. If you like online shopping, I can recommend to you my favorite, very good!
Jul 23, 2012 • Watches
1helpful
Watch is about 3 yrs old. Has always run for weeks w/ min wearing. It is now stopping after sitting for a short time & the large red/white 60sec hand for the chronograph no longer works & sort of...
According to the instructions for similar models in the same range, these watches should be serviced ever 3-5 years.
Perhaps yours has now reached that point.
If you wish to find the nearest service center, go to Boluva.com and after selecting your region, click on "service center".
6helpful
Fossil Chronograph--need to know what the two buttons on the side do
Two push buttons is for chronograph function. When you push the upper button - chronograph starts, second push on same button - stops the chronograph. Push on lower button - chronograph resets to zero. Rate me, plz.
Feb 03, 2010 • Watches
1helpful
On a Invicta Men's Off-Shore Russian Diver Quartz Chronograph Silver-tone Watch, the big min hand does not stop at the 12 clock position but instead stops 2 mins before the 12. It stops on the 62 instead...
It isn't a fault and can be adjusted. Follow this link and find out how to.... http://www.invictawatch.com/ Point at COLLECTIONS and click on INSTRUCTION MANUAL. If you don't know which one of movement makes you have, try both (RONDA first, then MIYOTA). When sorted with type of movement, check how to reset chronograph to 0 (zero).
Rate me, please.
Reset tank franchase cartier
Not completely sure what is being asked.
If what is being asked is how to reset chronograph hands to their zero point on a quartz watch then do the following:
1) Pull the crown out to the setting position.
2) press the chronograph buttons. Each one will move a different hand.
3) Once the hands are set push the crown back in.
Normally the zero point needs to be reset after a battery change or if the battery in the watch is getting weak.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
2answers
Tachometer Chronograph Operation.. HELP?
a Tachometer chronograph is a time and speed measurement.
10 year old alarm chronograph
good morning ! your anadigi chronograph 388 is veery easy to operate,just change the battery then short the reset button the fix the case back and set the time use the crown and the button to set the time calendar and the alarm !thank you ! god bless !....
5helpful
Nixon super rover..need to know how to reset the chronograph
Pull the stem all the way out...like your setting the date. Then hit the upper button and that will move the hand 1 second at a time until it gets here you want.
Top Diesel Watches Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Diesel Watch Expert? Answer questions, earn points and help others
