I have a Frigidaire Gallery Series washer (GLTF294OFEO). After doing a load of washing one night, I found the indicator lights on the next morning with the Start light flashing. I pressed the cancel/ pause button. It beeped and I noticed that the temp indicator light moved to another setting. I then found that pressing ANY of the other buttons, the temp setting would change. I unplugged the machine and plugged it in again. The letters ERR flashed twice and then indicated the estimated time for the cycle that it was set to. The start button was flashing but when pressed, again the temp indicator light moved to the next setting. I unplugged again , got the ERR code again, start light flashing but won't start . I pressed And held Option & Control button for 10 seconds but it didn't change anything. Pressing any of the buttons changes the temp setting. The door is closed as well as the dispenser door. ??????!
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: wash cycle stuck
You can attempt to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main computer for the washer. Sometimes resetting it is all that is required to correct momentary program glitches. If the problem reoccurs following a CCU reset, then you have a legitimate problem. Let me know if you still experience problems. I hope this helps you.
Posted on Jul 05, 2009
Code e62 on frigidaire gallery series model GLTF2940FS2
Good Morning Friend,
I understand you are receiving an E62 code on your Frigidaire Gallery washer, model# GLTF2940FS2. The E62 code means that there is a communication problem between the different control boards in your appliance. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire GLTF2940F Front Load Washer
My frontload gallery series washer will start cycle, but only continues to fill with water and drain. It did this all night but didn't go on to the next stage of the cycle...is it a bad control switch
Sounds like a problem with the main electronic control board in the control panel but the only way to know for sure is to do some electrical testing with a volt meter and the wiring diagram from the machine.
Click here for: How It Works: Front Load Washer
Repair Parts: RepairClinic.com
Nov 06, 2013 | Frigidaire ATF6000ES Front Load Washer
My moms front loader is a frigidaire gallery series. when she tries to start a load itll bring in a lil water and then just stop. don't understand why it is doing that
Turn off the machine then unplug it for at least 5 minutes and plug it back. Turn on the washer then press any button and wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously and the most recent error code will appear on the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the error code to determine the problem and necessary actions to be undertaken in order to address it.
Jul 19, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire gallery series front load washer leaking water on side where soap dispenser is. Have had two different repair places take a look at it- replaced soap dispenser- still leaks - repair people can't...
turn down the water pressure on the water line to the washer if the water pressure is to high it will splash out of the filler. there should be a vale on the main water line to the washer.
May 19, 2017 | Frigidaire Gallery Supreme Series...
I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Jan 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Error code
'dr' is an error code that indicates the door is not closed. If closing properly the door lock may have to be replaced.
Jun 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
