Question about Brother HL-5340DL Laser Printer - Monochrome - 1200 x 1200 dpi Print - Plain Paper Print - Desktop 30 ppm Mono Print - 300 sheets Input - Automatic Duplex Print - USB
Toner lamp lit
I have replaced the toner cartridge but the lamp is still alight suggesting it needs a new toner. I have taken power out and turned it on again
headstrong
  • 233 Answers
SOURCE: Blank pages after installing new drum
when replacing the toner did you remove the plastic film sealing the toner? if the drums receives no toner you will get blank pages. please check
hope this helps
good luck
Posted on Jan 07, 2008
jaylex
  • 417 Answers
SOURCE: Resetting Toner count onprint settings PRINT SETTINGS report
I don't suggest refilling cartridges as I work on printers every day but seems to me that you have done everything correctly the only thing I think you have done is either filled with incorrect toner thus giving a incorrect reading or when moving gear you have dislodged the pin that activates the reset procedure.
Thanks J
Posted on Feb 03, 2008
marked
  • 6487 Answers
SOURCE: Toner light on, replaced toner
unplug the printer for about 5 minutes thne remove the cartridges then after five minutes put the cartriodges back ion and power on the printer and after that check if you still have the toner light on if not try to print ....
Posted on Oct 30, 2008
  • 3 Answers
SOURCE: my broher 5250DN keeps showing toner needed, but i've replaced it
I just had the same problem. We have several of these in our office, but switching toner cartridges made no difference. Then I saw this site: http://www.oasis-imaging.com/images/pdf/cart_inst/TN580.pdf
I did steps 14-16, which takes 5-10 minutes. I put the toner back in the printer, turned it on, and it works perfectly now. Give that a try!
Posted on Apr 24, 2009
SOURCE: empty toner
Some people have had problems with the toner-count not resetting when installing a new cartridge because they did not turn the printer OFF while installing the cartridge. Re-install the cartridge with the printer OFF and see if that helps.
Posted on May 11, 2010
Why can't I keep my new heater alight?
Sounds like the gas bottle may be defective. I would suggest you try another before proceeding.
Mar 14, 2017 | Heating & Cooling
How do I clean the rollers on dell 1720?
First of all dirty rollers are not the cause of your problem as long as the printer is picking up the paper.
Black marks or streaks on a DELL 1700 series printer are usually caused by the drum assembly which, in this model, is separate from the toner cartridge. There is no repair, you need to replace the drum assembly and perform the drum reset procedure. In very rare cases a buildup of residual toner on the fuser can cause marks as well, but I have never seen this on a DELL printer.
To replace the drum:
1. After removing the paper tray, open the front of the printer.
2. Remove the toner cartridge by pushing down on the black release tab and pulling the toner up and out of the printer.
3. Pull the drum assembly straight out of the printer using the blue plastic handle.
4. Carefully unpack the new assembly and install in the printer. Be careful not to touch the photo-sensitive roller underneath.
5. Reinstall the toner cartridge, close the printer and insert the paper tray.
6. Perform the drum reset procedure exactly as follows:
power off and open front door hold down the continue button as you power on printer leaving front door open when error light comes on release continue and close front door. toner low, load paper, ready, and continue will all be lit. press cancel slowly 4 times or until just toner low lights up. each time you press cancel, the light sequence should change when just toner low is lit, press and hold continue button until lights cycle up and down in sequence. release continue.. toner low will be lit again turn printer off, wait 10 secs or so and then back on press continue button to print off settings page and check under cartridge information, photoconductor value is 0K (zero)
Aug 10, 2014 | Dell 1720dn Laser Printer
Recently had a low toner message for black. Next time I went to use a fault appeared - incoreect cartridge. I replaced black toner with genuine Lexmark cartridge - message still appears. Have turned...
Nice job on trying different ways to resolve the problem - turning off/on the printer, removing power source, reseating the cartridges and even changing the cartridge with a genuine Lexmark cartridge. You pretty much did the necessary. Genuine Lexmark cartridges shouldn't cause you that much trouble. I strongly suggest you contact Lexmark technical support to further investigate the problem.
Sep 01, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I need to change the cartridge on my HP LaserJet 1020, and I can't find the book detailing how to do it. All I need are the instructions................
Step one: Prepare the print cartridge CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print cartridge with a sheet of paper.Follow these steps to make sure the new print cartridge is ready to install into the product.
  1. Remove the new print cartridge from the packaging. Gently rock the print cartridge from front to back to distribute the toner evenly. c00382111.gif CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
  2. Pull the tab and remove all the tape from the print cartridge. Put the tab in the print cartridge box to return for recycling. c00382112.gif
Step two: Open the product
  1. Make sure you have turned the product on. Press the Power button if it is not lit.
  2. Open the print cartridge access door, and then wait until the carriage is idle and silent.
  3. Remove the old print cartridge. See the recycling information inside the print cartridge box. c00382110.gif NOTE: If you cannot remove or install the cartridges even though the power is on, check the product control-panel display for error messages. If none appear, turn off the power and then turn it back on.
Step three: Replace the old print cartridge
  1. Insert the new print cartridge in the product. Make sure the print cartridge is in position. c00382113.gif
  2. Close the print cartridge door.
CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric .
Dec 09, 2009 | Office Equipment & Supplies
I JUST CHANGED THE TONER AND THE COPIES ARE PRINTING OUT WITH A HEAVY THICK LINE ON THE SIDES
Indication Cause and remedy Page
Drum replacement
required indicator
Steadily
lit
Replacement of drum cartridge will be needed
soon. Prepare a new cartridge. 70
Blinking Drum cartridge must be replaced. Replace it with
a new one. 58
TD cartridge
replacement
required indicator
Steadily
lit
Replacement of TD cartridge will be needed
Blinking TD cartridge must be replaced. Replace it with a
new one. 57
Misfeed indicator Blinking
A misfeed has occurred. Remove the misfed
paper referring to the description of "MISFEED
REMOVAL".
63
SPF misfeed
indicator Blinking
An original misfeed has occurred in the SPF.
Remove the misfed originals referring to the
description of "D: Misfeed in the SPF".
67
Power save indicator is
steadily lit.
The unit is in the preheat mode. Press any key to
cancel the preheat mode. 54
The unit is in the auto power shut-off mode.
Press the start ( ) key to cancel the auto power
shut-off mode.
54
The paper tray indicator is
blinking.
The paper tray is not installed properly. Push the
tray into the unit securely. –
"CH" is blinking in the
display.
The TD cartridge is not installed. Check if the
cartridge is installed. 57
"CH" is steadily lit in the
display.
Side cover is open. Close the side cover
securely by pressing the round projections near
the side cover open button.
"P" is blinking in the display.
The paper tray or multi-bypass tray is empty.
Load paper. 15, 17
A misfeed has occurred in the paper tray or
multi-bypass tray. Remove the misfed paper. 63
A letter and a number appear
alternately.
The scan head locking switch is locked. Unlock
the scan head locking switch. 9
alternately.
The unit will not function. Turn the power switch
off, remove the power cord from the outlet, and
contact our Technical Assistance Department at
1-(630)378-3590 in the USA or 905-568-7140 in
Canada.
May 13, 2009 | Sharp Office Equipment & Supplies
Brother HL 2140: Toner ledlight lit, stopped printing. Cleaned Coronary Wire. Toner Cartridge new - 2 weeks old.
Hi Adsl34xg,
The cartridge that comes with the printer (or starter cartridge) has a yield of 1,000 pages @ 5% coverage. It probably really has run out of toner. Replace with a new cartridge to see if you can print. A replacement cartridge should give you 2,500 pages @ 5% coverage.
Dec 17, 2008 | Brother Office Equipment & Supplies
CC and drum Icon will not go out after changing toner cartridge
This Machine needs a copy cartridge. Replacing the toner will not clear it. The copy cartridge is the drum unit which is why the drum light is on. With the new copy cartridge a chip on the cartridge will reset the counter and clear the "CC" and the drum light. If you cant find this I can send you one. I believe on this model it is user replaceable.
Oct 31, 2008 | Office Equipment & Supplies
I have a brother HL 2040 laser printer. The toner and drum light were lit, so I replaced both the drum and the toner cartridge, but the toner light remains on. I have tried everything, but the toner...
Two things I could suggest you check. First, make sure you have removed all packing from the drum and toner. Sometimes there is a plastic strip on the toner that has to be removed before installation. Also, make sure you are using a Brother brand toner. Some generic brands do not replace the chip in the cartridge and they will not work,
Sep 19, 2008 | Office Equipment & Supplies
Replaced Toner and Still Wants it to be replaced
You need to manually reset the CRU counter in the service menu to reset the toner count. This is designed so the xerox tech can come in and get paid for work. What you do is the following:
Enter the service mode by turning the machine off....then hold the (i) button and (<) arrow button simultaniously while turning the machine on. Then go down to nvram access enter menu, then go to CRU menu. Then go to the Toner CRU count menu, then select the toner you wish to reset and allow the machine to reset.
IF you need any parts feel free to come to my store
Andrew www.Getthatpart.com
Apr 23, 2008 | Xerox Phaser 7300DN Laser Printer
Brother HL-5340DL Laser Printer - Monochrome - 1200 x 1200 dpi Print - Plain Paper Print - Desktop 30 ppm Mono Print - 300 sheets Input - Automatic Duplex Print - USB Logo
15 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
