Question about Steam Fast SF-450 Iron
I love my SF450, the plastic steam wand assembly fell & shattered. Can I buy replacement parts?
Mysteamfast model450 works GREAT I BROKE THE PLASTIC HEAD AND ASSEMBLY.CAN I GET REPLACEMENT OARTS? It is a professional clothing steamer.
3 Suggested Answers
SOURCE: Steam Fast SP-660 Iron will not steam with distilled water.
Steamfast Brand SP-660 steam press
Mfg by Top Innovations
Phone 1-800-711-6617
Posted on Dec 09, 2008
  • 3 Answers
SOURCE: Steam Press sp-660 will not steam with distilled water
My Steam Press (SP-660) the Mercury switch went out. An electrician looked at it to find out the problem. The question is now, how to get a mercury switch since most hardware stores do not carry them any more. Due to certain state regulations.
Posted on Nov 29, 2010
Rowenta steam iron fell down and top part is broken can it be replaced
Rowenta Iron Parts - eReplacementParts.com
www.ereplacementparts.com/rowenta-iron-parts-c-180639_180647.html Fix your Rowenta Iron today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide ... DE0554 Rowenta Steam Iron Parts.
Aug 08, 2015 | Rowenta Irons
My rowenta steam iron fell down and top part has broken any chance it can be replaced
Conair GS95 upright steamer will not steam just beeps
There is a float in the tank thy after 3 weeks stopped floating. Symptoms include; getting hot, no steam, light lights on wand but no sound or steam production. Mines covered under replacement policy with Amazon but temporarily I was able to use a metal fork, to slide on magnet up and carefully put the tank back into unit. It works. I'd imagine a better fix , get that plastic top off of tank without destroying it, unscrew float, and see why the boyancy is off? Adding more foam or cork just to stop it from going down. Of course I don't suggest to rig it in the up full position just in case it breaks
Sep 11, 2014 | Irons
Parts for Model DG8030
Google Rowenta repair. They have stations all over the US.
Jul 25, 2014 | Rowenta DG8030 Expert Pressure Steam Iron
Steam button broke?
I've looked up parts for this iron. Sorry to say the steam button is not listed. The button may be able to be repaired at a small apliance repair center, but I do not know what the cost would.
May 07, 2014 | Rowenta DG8430 Pro Precision Steam Station
The green light does not come on and it does not steam
follow this adjustment and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in wa
Nov 04, 2013 | Oreck Steam-It Steam Wand
Oreck Steam-It diagram?
You have probably already found the solution, but I've had this problem as well. The steam head has a hard plastic tube that directs the steam and disperses it across the head. This tube breaks and the result is what you are experiencing. The last time this happened to me I drilled out the tube and glued a new tube in the hole and reattached the flex tube. But this is only a short time repair. I couldn't find the part sold separately and we had to purchase a new steam head. Hope this helped
Oct 02, 2013 | Oreck Steam-It Steam Wand
NO STEAM COMING OUT....IRON IS HOT AND WATER IS HOT, BUT PUSH SWITCH FOR STEAM??NOTHING COMES OUT
you need to use a descaler, the holes have become clogged. you can buy this in most hardware stores
Mar 23, 2010 | Rowenta DG-980 Iron
Steam Fast SF-450 Iron Logo
37 people viewed this question
Top Steam Fast Irons Experts
Are you a Steam Fast Iron Expert? Answer questions, earn points and help others
