Question about Refrigerators
I used a knife in our refrigerator. The wire is affected. What should I do??
    New Friend:
  • 14 Answers
Unplug it now
do not let any touch it, it could be electrocution.
wire needs to be repaired properly
Posted on Jun 05, 2014
WHEN IT DISPLAYS 5Y CE WHAT DOES THAT MEAN?
The SY CE error indicates that the user interface (key #2) and the main control board (key #38) are not communicating properly. You can check the wiring. Unplug the refrigerator and gently pry the the dispenser away from the refrigerator. (Use a putty knife and work around the edge of the dispenser.) Check that the connections are clean and tight. Check the connection under the hinge cover, as well.
If the wiring doesn't have any damage, one of the above boards needs to be replaced. Additional testing will be needed. If you add a comment with the model of your Frigidaire, I may be able to provide information about the parts.
I hope this helps.
Mar 12, 2015 | Frigidaire Refrigerators
I used knife in our refrigerator. The wire is affected. What should I do??
You will need to replace the thermostatic temperature wire.... you should never force defrost fridges or frezzers.... sods law... something gets broken
May 15, 2014 | Refrigerators
Knife puncture
This mean the refriregant is not sufficient to cool down your refrigerator now. You need to weld the leak point and refill the gas to its normal pressure / capacity. Remember : never use use sharp metal / knife to clean your refrigerator compartements to prevent recurrence.
Regards,
Aug 23, 2011 | Refrigerators
I punctured the freezer with a knife moving ice I put silicone on the small hole will the freezer work
as long as you did not cut a wire or refrigerant line it will be fine.
Aug 08, 2010 | Refrigerators
How do i replace the light switch in my RTD1900D?
I am guessing that you mean the door switch, so: remove power then using a sharp knife slip it under the switch flange and, pry up gently then: do the same thing on the other side and all around the switch until it comes out; remove the spade wire connectors
Jul 22, 2010 | Maytag Refrigerators
How do I open the plastic shield covering the appliance bulbs in my LG french door refrigerator to change the bulbs? I can't seem to open it without breaking the plastic. What's the secret?
Use a butter knife and insert it in the slot between the cover and white plastic holder and pull the knife lightly twords you.
Do this on both sides and the cover should come out.
Use 40W bulbs for replacement.
Jan 13, 2010 | LG LRFC25750 Refrigerator French Door
I need to replace the light switch on the refrigerator side. Help!
USUALLY YOU PRY THE SWITCH OUT WITH A PUTTY KNIFE UNPLUG THE UNIT FIRST AND SLOWLY PRY IT OUT REMEMBERING THERE IS WIRES CONNECTED TO THE SWITCH SO BE CAREFUL NO TO DAMAGE THEM
Jan 13, 2010 | Maytag MSD2651 HE Side by Side...
How do you strip insulation form uf electrical wire
I use a sharp knife and slice off the outer covering on each side of the cable. With practice you can "feel" the outer insulation of the conductor and make the knife slide along it without damage. At that point I simply pull the two conductors out of the covering and use my wire stripper to expose the bare ground wire. When stripping the ground, I use a oversized hole on the wire stripper to keep from scoring the wire.
2 conductor is easier to strip than 3 conductor.
here's another
I've never tried tearing it apart. That sounds like it would be hard on the conductors to me.
steve
Dec 13, 2009 | Hardware & Accessories
My Haier compact frig runs all time, at #1 setting: freezes all
no 1 setting is close to zero degrees C the setting should be around 4 for normal every day use
call a technician to fix /replace the thermostat
if you continue to use a metal object ( screw driver , knife, fort etc ) when defrosting , you problems with the fridge will soon be over as you will puncture the evaporator section and that is not repairable so you will require a new unit
Jul 05, 2017 | Haier HSB03 Compact Refrigerator
Light switch on a older kenmore refrigerator, how to replace
Most light switches snap in place. If there is no apparent screw and the switch seems to have an adequate lip all around it, use a putty knife or butter knife push under that lip at one of the shorter sides and gently try to pry it up. It should pop out. the two wires are usually attached by spade connectors that just pull off. Doesn't matter which wire goes on each. Sears should be able to get a new one. But before you go that far be sure the bulb is not burnt out first. You should also take the switch with you to sears or have a friend test the switch to be sure it is truly bad..
Feb 14, 2008 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
